Question about Hitachi NV45AB2 Roofing Coil Nailer
Hitachi repair kit - Hitachi NV45AB2 Roofing Coil Nailer
Seeing double- almost like a shadow or 3-d when you aren't wearing the glasses
Thats a convergence issue. You can get the repair kit for that model hitachi from www.tvrepairworld.com under the Hitachi Repair Kits page.
Mar 22, 2013 | Hitachi 51F500 51" Rear Projection...
My red green and blue colors are not aligned
thats a convergence issue you can get the convergence repair kit which contains the parts and instructions from the www.tvrepairworld.com just click on the Hitachi Repair kits catagory then scroll down the page to your models convergence kit.
Jan 02, 2013 | Hitachi 46F500 46" Rear Projection...
Hitachi 53uwx10b
thats the sign of failed convergence. You can get the Hitachi DP14G convergence repair kit which also contains instructions from the following link http://www.tvrepairworld.com/hitachi_repair_kits then just scroll down to the DP14G convergence repair kit.
Aug 04, 2012 | Hitachi Televison & Video
You say you have a link for convergence ic's with instructions?
yes its at www.tvrepairworld.com and is listed under the Hitachi repair kits category as the DP14G convergence repair kit.
Oct 20, 2011 | Hitachi 43UWX10B 43" Rear Projection...
Hatachi 42inch hd projection whole left side has shadow effect blue and red 3d images without 3d glasses
Thats a convergence failure and will require installing a convergence repair kit. You can get convergence repair kits for Hitachi models at www.tvrepairworld.com they come with the ICs low ohm resistors and the CD with repair instructions.
Jun 17, 2011 | Hitachi Televison & Video
Hitachi rear projection TV Model 43FDX11B with convergence problem
You will need to install a convergence repair kit. You can get the repair kits with instructions at www.tvrepairworld.com
Sep 21, 2010 | Hitachi Televison & Video
Colors converge will not adjust. What can be done?
Xpertis,
When the convergence will not adjust after you know you have set them correctly using your TV's convergence adjustment, your convergence board went bad. You can either repair it yourself with kits sold online (links below) but unless you know how to solder very well, opt for a repair guy. Your model will cost between $350 and $450 if you hire someone.
http://www.tvrepairkits.com/xcart/product.php?productid=20095&cat=0&page=1
http://servicemanuals.vstore.ca/product_info.php/pName/hitachi-dp-14g-43uwx10b61uwx10b-convergence-repair-kit/cName/convergence-repair-kits
http://servicemanuals.vstore.ca/product_info.php/pName/hitachi-dp15-convergence-upgrade-kit/cName/convergence-repair-kits
If you like to tinker but not dwell into the soldering world, try finding the same model for free or dirt cheap on a web site like www.craigslist.org that still works but like where a kid jumped into the screen!, and swap out the board.
Good Luck!
-Chris
Sep 07, 2010 | Hitachi 57F500 57" Rear Projection...
Convergence problem on a 60 Hitachi
As long as the repair kit is a complete repair kit with the ICs and all 6 resistors plus detailed instructions. The best place for repair kits is www.tvrepairworld.com since most places dont offer the instructions and free online tech support while doing the repair as they do.
Jan 07, 2010 | Televison & Video
My picture just started having doubleimage like shadowing
T
your convergence ic's are Shorted
They have a kit for this tv it is available through local parts distributors
If you can't find it locally just Google HITACHI CONVERGENCE KIT
If you are not good with de-soldering and soldering do not attempt this repair. Remember to replace all the resistors in the kit
If you are not sure about doing this repair you should have your local tv guy do it for you
Dec 03, 2008 | Hitachi FDX Series 43FDX10B 43" Rear...
Hitachi NV45AB2 Roofing Coil Nailer  Logo
44 people viewed this question
Top Hitachi Tools & Hardware - Others Experts
John Trevino
yoopertech
Joe Garcia
Joe Garcia
Are you a Hitachi Tool and Hardware - Other Expert? Answer questions, earn points and help others
