Question about ESA EF402E 20" TV
Can't change to video channels to view DVD player
Finding the AV Channel on a TV
There may not be one on your TV. If your TV has audio and video input jacks then keep changing channels going from high channels to lower ones. When you get to Channel 2 then the next one down should be AV. If your TV doesn't have the A/V input jacks, then you'll need a modulator. This will take the audio and video outputs of the DVD player and put them on TV channel 3 or 4 and insert it into the antenna connection of the tv.
Jan 23, 2014 | Televison & Video
Can't change channel 3 to video for dvd playing - video won't come on to use with dvd player
I SUGGEST YOU USE AV CABLES( RCA ) AN CONNECT TO THE AV INPUT OF THE TV
Jun 20, 2013 | Panasonic CT-36D32 36" TV
My dvd player doesn't support wmv, avi, dat, mpeg, mp4 or 3gp. What should i do
This DVD player is supposed to support:
Supported Audio Formats Audio CD, MP3
Supported Video Formats DVD
Number of Audio Channels 4 Channels
Included Units In-Dash Player, In-Dash Monitor, Amplifier
Supported Media Types DVD-R, DVD-RW, CD-R, CD-RW
Monitor Size 6.5 inch
Touch Panel With Touch Panel
Just stick with these formats and it should work fine...are you trying to view burned movies or something. From the looks of it, it should play any DVD or CD just fine. Try to steer clear of those formats you listed.
Oct 18, 2010 | Pioneer AVIC-N2 Car DVD Player
I can view the video, but there is no audio playback....what's up?
check the leads,perhaps you have connected the audio cable wrongly.usually yellow is video out from DVD player,red is left channel audio & white is right channel audio.
Aug 23, 2010 | Apex Digital AD-1200 DVD Player
How do you get DVD picture to show up? Power is
You DO NOT use "Channels" to View a DVD player it usually connected to the AV External input. via AV, Yellow, (Video) Red & White, (Audio) or Component Video, Blue, Red & Green. (Video) + Red & White (Audio). These are selected via the External Inputs.
Feb 18, 2010 | Zenith ZDA311 DVD Player
I need playback channel for tv to be ch.4 -
Solution 1
How to set the DVD Recorder+VCR’s RF output channel
Turn off the DVD Recorder+VCR, then press and hold
CH (v/V) on the front panel for about five
seconds to change the RF output channel (CH 03 or
CH 04). “RF 03” or “RF 04” appears on the front panel display.
Solution 2
Cable Service With Cable Box
If a cable box is required in your cable system, follow the
instructions shown below. This hookup permits both TV and
DVD Recorder+VCR operation.
To view or record a CATV channel:
1 Tune the TV to the correct video input channel.
2 Set the DVD Recorder+VCR to the output channel of the
cable box using the CH (v / V) or the 0-9 keys on your DVD
Recorder+VCR (e.g., CH3).
3 Select the channel you wish to view on the cable box.
Please rate this a fixya
Jan 30, 2009 | GoVideo Go Video DVD/VCR Combo
Record a digital channel while watching and analog channel
Take a red, white, and yellow AV cable and plug it from the AV out of the cable box to the red, white, and yellow In of the dvd recorder (change cable box to the channel you want to record). Then change your TV to the channel you want to view.
Have fun!
-Tha Mp3 Doctor
Nov 23, 2008 | Panasonic DMR-ES30VS DVD Recorder/VCR
Is there an input select?
I can view channels but cannot view a DVD from the TV/DVD Disney Princess Combo. Only see static on the screen with no sound. I wonder if I need to change the input select to view a movie but cannot find a button on the TV or remote control. I have a 6 button remote which I am sure operates the DVD and another remote with 39 buttons I thought would operate the player as well as the TV. However, so far only the player functions from it. The buttons only have small pictures without words which sometimes leaves some question about purpose. This is a second hand unit. I do not have a manual. It did play movies at first. I think the trouble may have started when I programed cable channels. Any help will be greatly appreciated
Apr 24, 2008 | Disney DT1300-P 13" TV
Cannot view channels higher than 10 and cannot get DVD to come on
Dear althea, I cannot help you with the first problem, but as for the second, "DVD does not come On" and "Do not understand Video 1, 2, & 3 settings." it is very simple. YourTV has the sockets at the front Marked Video 1, Audio L and audio R, The y are in three colors - Yellow for video, red for audio right and White for Audio Left. Similarly, you have 2 such sets of 3 sockets - they are Video 2 and Video 3. This allows your TV to be connectod to three different Video sources - maybe a VCR, A Video game, and a DVD player. To view the pictures generated by your DVD Player, all you gotts do is connect the supplied AV cord from the rear of the DVD player to the front three sockets in the proper order - Video from DVD to Video of TV, Audio L & R from DVD player to Audio L & R of TV. Now press Video on the TVs remote. Press repeatedly till you get Video 1 displayed on the screen. Then, if you now play your DVD player - make sure there is a disc in it - you will be able to view the picture / movie. Good Luck
Mar 05, 2007 | Sony KV-32XBR100 32" TV
Can I play the video and a dvd without the remote control?
Your set should have external video and audio imput jacks besides the tuner imput for antenna,you can use the video and audio outputs from the vcr or DVD and conect them to the video and audio imputs in the tv then you can select a channel below 1 or push the switch that says Video/antenna.
Oct 02, 2006 | Samsung CXD2512 25 in. Combo
ESA EF402E 20" TV Logo
22 people viewed this question
Top ESA Televison & Video Experts
Demonic-2011
Demonic-2011
Are you an ESA Televison and Video Expert? Answer questions, earn points and help others
