Question about Maytag MDB7100AWB Dishwasher
Maytag mbd7601aww says yu
Display says yu dishwasher won't start
3 Suggested Answers
KevinWhite
  • 1902 Answers
SOURCE: My maytag dishwasher won"t start
Hello & Welcome to FixYa
First clean the drain filter pump assembly located inside the front bottom access panel. If the problem is still there after cleaning the drain filter assembly then it means the control board is bad and needs replacement. Please get back to me if you have any other questions.
Kevin
Posted on Jun 14, 2011
binghampaul
  • 23 Answers
SOURCE: My Maytag QuietSeries 400 dishwasher won't
Dishwasher will not start Is the door open or unlatched?
Make sure the door is completely closed and latched. On models with a dual-digit display, the control displays "- -" during a cycle if it believes the door is not latched. Check for obstructions (spoons, etc), interfering with the door operation. A lower dish rack that is installed backward will also cause incomplete door closure.
Check your household electrical box to see if a fuse has blown or if the circuit breaker has tripped. If the unit has a plug-in power cord, make sure it is plugged in.
Does your dishwasher have a rotary timer knob? (Some Models)
The cycle selection must match the position of the timer knob. Turn the timer knob to the beginning of the preferred cycle. The timer knob should click when you reach the start of the cycle.
Is the control lock option activated?
Press and hold the Heated Dry option (button with lock icon) for three to five seconds and the light should turn off. Instructions are also placed on the label on top of the inner door to unlock the controls.
Is the delay start option activated?
To cancel the delay and cycle, press Cancel/Drain.
Has the motor stopped for less than 10 minutes?
The motor may have stopped due to an overload. If this is the case, the motor will automatically reset itself within 5-10 minutes.
Is the Start/Resume indicator flashing?
Opening the door or interrupting the power can stop the cycle. Close the door and press Start/Resume. If the Start/Resume indicator flashes three times when you press Start/Resume, the dishwasher is waiting for you to open the door after the last cycle. Open and close the door, and then press Start/Resume.
On models where the controls are on top of the door be sure to close the door within 3 seconds of pressing the Start/Resume to start or resume the dishwasher cycle.
Is the water shutoff valve (if installed) turned on?
Make sure that the water shutoff valve is turned on.
Posted on Jun 19, 2011
Maytag dishwasher Model MDB7749AWB won't start/respond
Either the start switch, the start relay, the wires between them, the wires to the motor, or an internal fuse inside the panel, or the door safety interlock could be the problem. Even, any combination of the above could cause this. This is a real troubleshooting problem. Are you game?
Dec 28, 2012 | Dishwashers
Maytag dishwasher won't start but other buttons work
It's probably your Circuit Board (CB)! My dishwasher is on the second CB and it keeps blowing the dispenser transistor. This needs to be brought up to the MAYTAG goons to see if they will start recalling this crappy thing. My machine is barely a year old and will have it's third CB!
Jun 23, 2012 | Maytag MDB7749AWM Builtin Dishwasher
My maytag W10199645 dishwasher won't start
Maytag model w10199645 was starting intermittently, and sometimes only when we pressed and held the start button for 10-15 seconds. Finally tonight it just wouldn't start, period. I unplugged it for 15 minutes, then used the Heated Dry/Normal/Heated Dry/Normal and it started back up on its own.
Mar 23, 2012 | Maytag Dishwashers
My dishwasher won't start at all
There could a number of reasons why it won't start but start with the locking mechanism first. Make sure the locking mechanism is in the "Locked" position. It will be the lever at the top of the door. If that isn't the problem try describing everything you have tried and post your question again.
Jan 20, 2012 | Maytag Dishwasher
I have a maytag dishwasher theres a 3 second button to hold in order for it to start but it won't start it's stuck on 3 second lite
hold the heated dry button for till that light goes out. then try to start. it is a child lock that is on
Oct 08, 2011 | Maytag MDB7100AWB Dishwasher
Maytag mdb/c-2 some lights are blinking and won´t stop. I can´t start the cycle of cleaning, well really i can´t start anything. Please any sugestion ?
press the "off" button and hold it down for several seconds. this worked for me when i encountered the same problem on my maytag jetclean this weekend. it reset my control panel and now it's working great!
Sep 11, 2010 | Maytag 24 in. MDB5600A Jetclean II...
Maytag MDB-3 won't start, display flashes
Hold down the lighted "3" for five seconds to unlock the child safety lock
Feb 15, 2009 | Maytag 24 in. MDBH970AWS Built-in...
May Tag Dishwasher
http://www.cpsc.gov/cpscpub/prerel/prhtml07/07094.html
I think you should review this webpageThere have been over 2 million maytag dishwasher recalls due to them being a fire hazard. The chart below came from the site and Im not sure what your serial number is but your model number is on there.
Brand Model numbers MUST
begin with… AND serial numbers MUST end
with… Maytag® MDB3, MDB4, MDB5,
MDB6, MDB7, MDB8,
MDB9, MDBD, MDC3,
MDC4, MDC5, DWU9 SM, SQ, SS, SU, SW, SY, SZ, UB,
UD, UF, UH, UK, UM, UQ, US, UU,
UW, UY, UZ, WB, WD, WF, WH, WK,
WM, WQ, WS, WU, WW, WY, WZ,
YB, YD, YF, YH, YK, YM, YQ, YS, YU,
YW, YY, YZ Jenn-Air® JDB3, JDB4, JDB5,
JDB6, JDB7 UB, UD, UF, UH, UK, UM, UQ, US,
UU, UW, UY, UZ, WB, WD, WF, WH,
WK, WM, WQ, WS, WU, WW, WY,
WZ, YB, YD, YF, YH, YK, YM, YQ,
YS, YU, YW, YY, YZ
Mar 30, 2008 | Maytag 24 in. MDB3700 Built-in Dishwasher
Maytag MDB7100AWB Dishwasher Logo
20 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
