Philips home theatre
SOURCE: Philips LX3600D Home theatre always returns to standby mode
There is a 1ohm resistor on the 4x4 pcb as soon as you take off the cover. ( I forget the ID # ) It supplys the -15volts to the control bd. The resistor will not looked burned. It was under rated. An ohm meter will find it ( open ). Rreplace it with a 1/3 watt. I believe the orig. was a 1/4 watt.
SOURCE: Region Unlock code for Philips HTS 3152
Thanks dude,
Not sure which trick worked, but i did ur classic 7,3,4,4,6,6,0 trick, got no message from the player. So i did pressed 0000 after that. Still no message appeared. But when i pressed start....it worked!!!!!!
Thanks a ton!!!!!!!!!!!!!!!!!!!!!!!!!!!!! God Bless...
SOURCE: Philips Home Theatre System - no sound or power light on sub woof
reset the device to factory settings, it is written in your manual how to do this. If that doesnot work, unplug the powersocket for about 30minutes, it will cause an internal reset which might solve it.
Edgar
SOURCE: Philips HTS3410D home theatre system.
Power off the system
Unplug the power cord
Wait 5 minutes
Plug back the power cord
Power up the system
Press the open/close button
Load a DVD and play
If the tray still will not open, the cover will have to be removed and manually operated. You may have to have a technician look at the unit.
Please rate this solution - Thanks
SOURCE: Just bought a Philips home theatre system HTS3544 low sound?
You may also need to change the speaker set up. Go to DISC setting (one of the top selections on the remote) make sure you have no Disc in the DVD player. When in this mode press setup on the remote. On this menu you will have a option to adjust the speaker volume.
I had to increase my speaker volumes to get better sound. This setting is not accessible if you try to do the set up in other than DISC setting. Be sure to check the SURROUND setting. The SURROUND button on the remote will toggle between stereo and surround as stated in a previous post.
ST
