Question about Canon PIXMA iP1800 InkJet Photo Printer
EROR 5100 PRINTER CANON MX 397 - Canon PIXMA iP1800 InkJet Photo Printer
SOURCE: Error 5100 on my canon mx 310.
the 5100 is the carriage error and can be caused by 4 different sensors. First off the "Timing Strip" that passes through the back of the Carriage Assembly can be contaminated with ink spots and this needs to be cleaned. Open the cover and use your flashlight to examine the timing strip as much as you can see. You really don't have much access to this strip unless you remove the covers,..and doing that is considerable work. The other items that can cause this error are the sensor inside the carriage unit, the drive motor for the carriage asm, and of course the main logic card. However, 99.6% of the time it is the Timing strip which is easitly contaminated with splattered ink.
Posted on Apr 02, 2010
pineworks
  • 4041 Answers
SOURCE: canon eror 6000
Error 6000
Hi there it is ink error.
You can try to reset the cartages this may do it Please call back let us know if it worked for you, PLEASE.
  1. Start with printer off
  2. Press and hold resume Button (triangle in the circle) and click “Power” button. Green led should be on
  3. While holding the Power button, release the Resume Button.
  4. Without releasing the Power Button, click “Resume” button for two times and release Both Buttons.
  5. Click “Resume” for four times then soon click “Power” button, to confirm the selected action (reset counter absorber).
  6. Turn off the printer and turn on again
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Apr 28, 2010
  • 284 Answers
SOURCE: HOW TO CLEAR ERROR 5100 ON A cANON mx 850 MF
after replaced the faulty parts then the error won show again.
Posted on May 28, 2010
alpug
  • 1961 Answers
SOURCE: i am using canon mx
remove cartridges. clean the contact surface of the cartridge where the contact terminal inside the printer touches. You can use a cotton moistened with alcohol. After that return the cartridges and restart the printer.
If different errors appear, try to reset
1. Turn off your printer
2. Press and hold the STOP/RESET button
3. Press and hold Power ON button
4. While holding the Power ON button, release the STOP/RESET button
5. While holding still the Power ON button, press twice the STOP/RESET button
6. Release the Power ON button
7. Wait until it display an "idle" message. It will take about a minute.
8. When "idle" appear, open the top cover to expose the cartridges.
9. Lift up the cover for cartridge holder and take out both the black and color cartridges
10. Return the cover of cartridge holder and turn off the printer
11. Return the top cover and turn on the printer again
12. After the printer initialize, return the cartridges.
If another errors appear, try to press the STOP/RESET button for at least 5 seconds and wait until the printer self restart.
I hope that helps. Just post back when you still have questions.
Please rate this answer and leave some testimonial too.
Thank you for using Fixya.
Posted on Nov 22, 2010
  • 5387 Answers
SOURCE: have a 5100 error on
There are a few issues that cause a 5100 error code. 1) The encoding strip may need cleaning. 2) There is a paper jam. 3) The printer may need to be reset by turning it on and off. 4) The ink tanks may need to be properly snapped into their carrier. 5) The printer may need service.
The solutions to try
1) Cleaning the encoder strip. Use a cotton swab and isopropanol (rubbing alcohol) or window cleaner. A flashlight will help you see any grease on the encoding strip. With the printer on, open the printer by lifting the scanner unit until it locks. Unplug the power cord from the printer and wait until the LEDs are no longer lit. At this point you will be able to slide the cartridge carrier back and forth. To start, slide the carrier to the right. Look for the clear plastic strip (the encoding strip) in front of the carriage drive belt and look for any grease or other dirt on the strip. Remove the grease with a cotton wab moistened with the isopropanol. Look at the strip from several angles to check for any grease along the entire strip. Make sure you do not remove the grease from the chassis (metal rail). Move the cartridge carrier to the left and check the right side of the strip. When all of the grease is removed, lift the scanner unit support and close the unit. Plug in the power cord and turn the unit back on. Often grease gets on the encoder strip when you remove a paper jam. If you proceed to the next step, you may have to repeat this cleaning.
2) A paper jam
Carefully pull any sheet from the rear tray or paper output slot. Detach the rear cover and fully extend the rear tray support and try to pull the paper out slowly. Otherwise try turning the printer off and on - the sheet may be ejected. Remove the paper cassette and pull any paper out slowly that is in the front area. If needed, try removing the paper cassette and any paper in the rear tray. Then turn off the printer and unplug it. Set the unit upright on the left side and try to pull the paper out. Return the printer to the usual position when done. Replace the cassette, plug in the power cord and then turn on the printer. This will delete any documents in the printer queue. Check for foreign objects around the paper output slot. Remove any foreign objects with the unit off. Close the rear cover completely. Make sure that the paper isn't curled up.
3) Turn the unit off, unplug the power cord and wait 10 seconds or longer. Plug in the power cord and press the On button. Wait until the printer completes the cycling process before trying to print again.
4) Verify that the ink tanks are properly seated. With the printer on, lift the scanning unit up until it locks. Press on the black circle on each ink tank until it snaps firmly into place. Check if the ink lamps light up red. Make sure the protective shipping covers was removed from the ink tanks. If the unit has the remaining ink level detection feature disabled, replace the ink tanks. Close the scanning unit.
5) If none of the above solutions work, contact Canon if the unit is under warranty. Otherwise, decide if the service is worthwhile for an out-of-warranty printer.
I hope this helps.
If the paper tears when you try to remove it, open the scanning unit with the printer on and unplug the printer. Then look for and remove the paper. Use a flashlight to check for paper and other foreign objects in the corners. Slide the cartridge carrier back and forth to check the corners completely.
For pictures check the support site: http://www.usa.canon.com/cusa/consumer/products/printers_multifunction/office_all_in_one_inkjet_printers/pixma_mx860#ServiceAndSupport . Search for the error code 5100 and then follow the links.
Posted on Jan 09, 2011
Kertas tidak bisa masuk
Canon PIXMA iP1800 InkJet Photo Printer problems
Jan 13, 2014 | Canon PIXMA iP1800 InkJet Photo Printer
Mx 397 error 5100.
error support code 5100
Sep 24, 2013 | Office Equipment & Supplies
Cara perbaiki ix 6560 error 5100
printer saya canon ix6560, mengalami eror 5100, mhn bantuannya,,trmksh,,
Sep 07, 2013 | Office Equipment & Supplies
Eror 5100 canon pixma mg 2170
Lepaskan kedua cartridge, bersihkan pin2 carriage sekaligus pin2 konektor pada cartridge. selanjutnya pasang kembali kedua cartridge.perhatikan tampilan pada display, jika tertera angka 1 itu berarti masalah error 5100/ P02 telah teratasi dan insya Allah printer dapat beroperasi kembali. (Wahana Computer Masamba)
May 06, 2013 | Canon Pixma MG5220 InkJet Printer
How to solve this problem bout my printer?
go to this link...........
http://mallcom.wordpress.com/2007/10/23/canon-mp150-reset-codes/
Jan 07, 2010 | Canon MP140 PHOTO AIO All-In-One InkJet...
MP 145 Eror code 5100?
MY CANON MP 145 IS ERROR PLEASE SOLVE MY PROBLAME
Jan 05, 2010 | Canon PIXMA MP150 All-In-One InkJet...
What is eror 5100
LED DISPLAY
Here is a list of possible problems for the error 5100. The main thing is the carriage for the cartridges. Remove both and power off the printer. Power it back on and reinstall cartridges.
E 2 2
Error (5100)
- Carriage unit (main unit)
- Timing **** strip film
- Logic board ***’y
- Carriage motor (main unit)
E 2 3
Timing sensor ***’y
Aug 22, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Canon PIXMA  iP1800 InkJet Photo Printer Logo
41 people viewed this question
old marine
old marine
