Question about Health & Beauty
My A&D UA 702 wont shut off
Power button turns off monitor but it comes back on after a few seconds
SOURCE: optiquest q9 turns off
read the solution I have wrote on th Q7
display goes blank after few second
the fix is about 5 $ the supply is almost dead
Posted on Feb 01, 2009
SOURCE: Powers on a few seconds and shuts off.
check inside the battery compartment. mine did the same thing i check and the middle battery contact had fallen out
Posted on Nov 06, 2009
  • 732 Answers
SOURCE: Viewsonic VX1940w monitor comes on for a few
vmesa, Do not feel alone! Your monitor's problem same as ten thousand other CCFL back-lit LCD monitors all over planet earth!!!! Yes, and I mean the exact same symptom as you have stated. Yes, it can be fixed, but you shouldn't look to software or drivers to do it. Read my and other monitor guru's FIXYA profiles to find out if you have what it takes to attempt DIY repair on your unit!!! Follow all links you find and visit YOUTUBE!!! After an hour or two of reading you will understand your monitor and what might be the real cause for it's Black or Blank n Black screen symptom and how to fix it. If your pocket is deep enough, then skip all the reading and use VX1940w for trade-in on new unit. 12fixlouie
Bye for now.
Posted on Feb 19, 2010
  • 5 Answers
SOURCE: monitor ACER 24" stop display after few seconds
This is not a Fix to the Problem, If you read some of the other "fixes" that relate to this you will see that it is a more serious problem and one that Acer should Do the Honorable Thing and have a Recall.
I actually went in side on three of the Same Monitors and one that was a 21 inch and found the problem is "HEAT"
You can see where a Board actually shows Browning on the Circuitry I am Going to try to order a new board P/N:AS08B360411.
I will update as soon as work is completed.
Posted on Mar 18, 2010
  • 732 Answers
SOURCE: Monitor turns off after a few seconds. Have to
my_secret_mb, Stop pressing the ON/OFF switch! It's broke!!! The unit's internal power supply will need some work done on it. Unit will need to be evaluated first!! This is a common problem for ALL LCD monitors. If unit out of warranty period, then you will need to do some intense speed reading of my higher page number responses in my fixya profile to understand the problem your cold-cathode-fluorescent-lamp back-lit lcd monitor has and the options that you have. You will also need to base your decision on the age and total number of "ON" hours unit has seen during it's lifetime. Do not dispair or feel sad about what has happened to your monitor. A low side guess would be 50 units/day fail world-wide. Your unit may have failed filter capacitors or possible failed solder joint on printed circuit board. (thermally intermittant) I hope this helps you. 12fixlouie north of "Windy City" USA
Posted on Apr 02, 2010
How do I turn off the Samsung sync-master p2050 monitor?
If it doesn't turn off by holding the power button down for 10 seconds, then it cannot be turned off by the power button alone, like most modern lcd monitors. Most modern monitors goes into standby mode. To completely cut power, you must unplug the power cable.
I've enclosed a link to the install manual for reference.
Samsung SyncMaster P2050 User Manual Page 7
Nov 24, 2014 | Samsung Computers & Internet
I have a Mitsubishi TV model WS-48511 it was working fine, I shut it off came back a few hours later & when I turn it on the green light will come on for about 3 seconds but turns back off. What can I...
Unplug it from the wall for about 5 minutes.
with it unplugged, Press and hold the power button for around 30 seconds.
This should discharge the unit and allow it to come back on.
Jul 02, 2011 | Mitsubishi WS48511 48" Rear Projection...
Apr 02, 2010 | Dell E176FPB 17" TFT LCD Flat Panel...
I clicked reboot not my iphone wont turn back on what do i do????
Iphone Connect With Itune
Turn Off Your Phone
Press Home Button for 5 Second
After 5 Second Press Power Button for few second
Release Power Button
Still Holding The Home Button
Itune Detect Your Iphone In D.f.u Mode
Release Home Button.
Jan 20, 2010 | Apple iPhone Smartphone
Gateway monitor FPD1975W won't display
Same problem - unplug both computer and monitor - hold power button for monitor for 15-30 seconds...then power it back on and then power on the computer. Seems from other sites there is a power issue with the monitor - this worked for me.
May 23, 2009 | Gateway FPD1975W 19" LCD Monitor
Wont boot/start
Turn off power, unplug, hold power button for 30 seconds, take out memory, or if you have more than one stick only take all but 1, plug the power back in and start the computer. If a screen pops up that bios has changed press F2 to continue once computer is completly loaded click start, shut sown, unplug power cord again, hold power button 30 seconds, insert other memory and restart
May 13, 2009 | E-Machines eMachines Desktop PC
Optiquest q9 turns off
Jan 18, 2009 | ViewSonic OptiQuest Monitor
E-machine 210 shut down and wouldnt come back on
try a different power supply first if this does not work
post here meage will go through other possibilities
May 21, 2008 | E-Machines eMachines Desktop PC
Health & Beauty Logo
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
