Question about Coleman Lantern Fan Radio (841.321) AM/FM
My lantern/fan/radio doesn't work when its not plugged in?
Everything works fine when the unit is plugged in, but when it is not plugged in it doesn't work. What the heck is the deal, do they take monthes to charge the battery
  • 39 Answers
The battery probably isn't taking a charge anymore because it needs to be replaced. These batteries will sometimes last a few years but then a replacement is needed and they will likely run like new. You can check out http://www.batteryinternational.com/lantern-battery.html to find a replacement battery, or you can call 1-877-28-BATTERY if you are having difficulting finding the battery you need.
Posted on Jul 07, 2009
Coleman Lantern TV #D269 appears to be DOA
If it doesn't work with batteries, and the correct power cord is being used, then it's fried. Try wiggling the lantern end of the plug slowly, to put it in a bind at each end. As long As it's turned on, you should see some sign of life if it's not fried. The plug shouldn't move much, but if it moves, the solder points inside of the lantern to the circuit board could be broken off. If none of that works, it's fried.
Oct 15, 2017 | Cars & Trucks
Swissgear rechargable lantern won't light up, even though the green led light indicates it is fully charged
There are several different models of the Swiss Gear rechargeable lantern. On most though, you can remove the top portion of the lantern and check the lighting element inside. In most cases the elements can be removed and replaced. I have a dual filament lantern and from experience I know that every so often you may have to go buy a replacement light piece. If the lantern has been bumped or even just strapped to the outside of the pack while walking, it's possible for those elements to become loose and need repositioning or replacement so do check that. I'm sure that it should be unlikely your charger is malfunctioning unless you left it plugged in for some very extended period of time, in which case I would say the light would be more likely to burn out. But definitely try that and if that doesn't work the battery pack on the lantern itself may have an issue in which case you can always get a replacement.
Aug 29, 2012 | Camping, Backpacking & Hiking
I have a Bosch PB10-CD and everything works fine when it is plugged in with the battery charging. I can unplu it and the radio still works with the battery in it just fine, but when I plug the unit in and...
I have seen in some cases where the rechargeable battery is part of the B+ circuitry when adapter is combined, this maybe normal for this model. But you might be able to go online to Bosch and find out more information from customer support or the technical department.
Mar 08, 2012 | Bosch Audio Players & Recorders
The am/fm doesn't work but when i plug in my mp3 its fine, any tips on fixing this.
The AM/FM tuner has been damaged. Ask Dewalt support if they can repair it. If the unit is under warranty, have it replaced.
Aug 25, 2011 | Dewalt DC011 AM/FM Radio
In reference to the Coleman Lantern/fan/radio #841-321 .....where is the battery compartment located? where can I purchase an adapter since this one is missing?
Type this URL in the box- http://www.fixya.com/support/t955738-coleman_lantern_fan_am_fm_radio. As for the adapter, you should probably check the camping section or electronics section of Wal-Mart or, you can call customer support for Coleman. Their phone number is 1-800-835-3278. Ebay, Amazon or other online shopping companies might have the adapter in stock. Hope this helps.
Oct 08, 2010 | Coleman Lantern Fan Radio (841.321) AM/FM
Coleman lantern/fan/radio won't take a charge any more.
Yes there is, you can check out http://www.batteryinternational.com/lantern-battery.html to find a replacement, or call 1-877-28-BATTERY if you're having difficulty finding the battery you need. Hope that helps.
Jun 14, 2009 | Coleman Lantern Fan Radio (841.321) AM/FM
Coleman lantern fan am/fm radio
This lantern/fan/radio combination does not use/accept batteries. It is recharged using the black A/C adapter provided with the lantern. I hope you received the adapter with the lantern when you bought it @ the garage sale? You plug the adapter into the little circular opening just above the round spotlight on the lantern. Hope this helps!
Aug 22, 2008 | Coleman Lantern Fan Radio (841.321) AM/FM
Rechargeable Camping Lantern
you need to coldsolder the pc board.
Apr 09, 2008 | Dryers
Coleman Lantern Fan Radio (841.321) AM/FM Logo
673 people viewed this question
Top Coleman Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Coleman Audio Player and Recorder Expert? Answer questions, earn points and help others
