Question about Acer Aspire One D257 Netbook
Will not power on
Notebook is plugged in to a power sourse that is working, no lights will come on and the screen will not come one, there is just no power getting to the notebook?
2002 VW Jetta won't start
Check the battery out put to see if it is at least 12.25 volts(may need to have it load checked).If the battery checks good,remove battery cables and clean them real shiney,also the battery terminals,and replace them back on the battery,WARNING,DO NOT DISCONNET THE BATTERY WITHOUT PLUGING A 12 VOLT POWER SOURSE INTO THE CIGARET LIGHTER PLUG,OR EQUAL.If you do not plug in a power sourse to the car,the computer will loose all it`s memory,and will have to go to the dealer to be reflashed.
Sep 21, 2009 | 2002 Volkswagen Jetta TDI
Blue screen, dvds wont play. cant change the sourse.
check you wire connections if not then you can get a originald remote from partstore.com good luck.
Jul 12, 2009 | Televison & Video
Completely blank screen when power is on.
do a hard reset....remove charger>remove peripherals>remove battery> press and hold the power button for about 30secs, while batt and charger is removed> then plug in the charger only and turn ON!
Please vote, thanks!
Jun 27, 2009 | Acer Aspire One Netbook 8.9" Notebook
My 52 inch flat screen hdtv made by samsung won't turn on. The light blinks like its coming on but nothing happens for about 5 min
YOU HAVE A FACTORY DEFECTIVE POWER SOURSE CALL SAMSUNG AND GIVE THE SERIAL NUMBER AND MODEL THEY WILL SEND OUT A TECH TO REPAIR FREE OF CHARGE
Jun 10, 2009 | Samsung LN52A850 52 in. LCD HDTV
My wii console does not turn on.
well that happened to my wii but all i did was unplugged the power wire for like half a day then plugged it back on then it worked. If that don't work then call nintendo
May 14, 2009 | Nintendo Wii Console
HP DV2036ea i have a blank screen on the computer
Hello there
Description.
When pressing the notebook power button nothing is displayed on the screen or display. The cause of this problem may be a failed AC adapter, the memory modules (RAM) need to be reseated or a failed notebook system board component which will require an HP certified repair.
Below steps will assist in identifying the cause of the problem and suggest the best solution. Test the AC adapter Follow the steps below to determine whether the problem is related to the AC adapter or your notebook system board.
  1. Remove the battery and disconnect all external devices from the computer.
  2. Hold the Power button for several seconds, with all power sources removed. This drains residual power from the system, and may correct many problems.
  3. Connect the AC adapter to a wall outlet and plug the other end into the computer.
  4. Press the Power button to start the notebook PC.
If the notebook does not start or the display is blank then check the power indicator light or power socket LED. Check the power indicator light or power socket LED On newer models of notebook PCs, there is an LED or indicator light around the power socket on the notebook. Check to see if this light is on or off, when the notebook is plugged into AC power.The power indicator light or power socket light should turn on when the AC adapter is connected.
  • If the light does not turn on then the problem is most likely related to the AC adapter or the electrical source in your home or office. Go to the Light does not turn on section on this page.
  • If the light does turn on but the notebook does not start or the there is a blank screen then continue to the Light does turn on but the notebook does not start section on this page
The light does not turn on when the AC adapter is connected If the power indicator LED is off, the AC power adapter may need to be replaced. To determine if the AC power adapter needs to be replaced follow the steps below:
  1. Ensure that the AC adapter is plugged directly into a known working wall outlet.
    NOTE: To check the wall outlet, plug in a different known working device like a light, radio etc.
  2. Check all of the following connections:
    • The connection from the power cord to the wall outlet.
    • The connection into the power adapter from the power cord.
    • The connection from the AC adapter to the notebook power socket.
  3. Press the power button again to test the notebook PC.
If the power indicator light still does not turn on, then the AC Adapter needs to be replaced. Contact HP Service and Support for further assistance. Power socket LED or power indicator light is on but the notebook does not start If notebook power indicator light (LED) is on, the AC adapter is working correctly. The problem is a result of a hardware failure in the notebook itself. In some cases, reseating the memory module (RAM) may solve the problem.
Feb 02, 2009 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Removing all power including cmos battry did not work
what was he problem with your laptop b4 you removed the power sourse?
Aug 15, 2008 | HP Pavilion dv2000t Notebook
Back up Light Not Working
no try:ck fuse,switch adjustment if any try jumper wire from 12v sourse to switch.there has to be power cut between switch to power or from switch to lights
Aug 03, 2008 | 1993 Geo Tracker
Axis 9 CD Deck
did u buy new take it back man bad power sourses no good make sure u plug into a good power sourse witha good monster power strip ok ect did u buy on ebay get refund with paypal make a claim
Jan 29, 2008 | Nu Mark AXIS 9
Acer Aspire One D257 Netbook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
