Question about Cub Cadet Riding Lawn Garden Tractor 25hp Kohler 50"
Sold wrong battery and crossed terminals
Hooked up battery on cub cadet 1040. I thought I was sold a dead battery. I tried to jump start to prove that battery was dead. Wires started sparking so I disconnected. Then realized the terminals were wrong. Exchanged for correct battery and got no response when I turned ignition key. Did I burn up the selonoid?
  • Cub Cadet Master
  • 2,760 Answers
I doubt that jim, but i don't know anyway quicker to kill a charged battery than to hook it up backwards to another battery (sparks you mentioned) try using a spare car light bulb to verify that battery is charged up , also look for inline fuse someplace close to the battery location, you might have blown that , continue using car bulb to "walk" thru circuit to verify presants of voltage (key/starter/dashlghts)
Posted on Jun 26, 2014
  • 1015 Answers
SOURCE: 54" cub Cadet mower... difficuly
I would srart by removing the negitive battery cable then the positive and clean posts and terminal ends with wire brush or sandpaper. I would then go through and one by one clean each cable you can get to on the starter and solenoid and any grounds to frame. Clean one at a time and replace as you go.If you have had the same battery for more than two years I would replace it to. A good battery will cost you about $40.00
Check gear on starter to see if teeth are badly worn. If so most of the gears can be replaced without replacing the starter. Make sure you have a good clean plug with the proper gap, clean fuel and air filter and vent hole in gas cap.Hope this helps you and thanks.
Posted on Jun 01, 2011
  • 640 Answers
SOURCE: I have a series model 1018 cub cadet with electric
If you have access to an electric voltmeter, with it running check voltage at the battery. The engine should charge the battery and maintain system voltage so that the electic PTO will function. The electic PTO will not pull in if system voltage is too low.
Posted on Jul 08, 2011
BAMOUT
  • 2478 Answers
SOURCE: switch shuts off cub cadet but will not start it if u jump solioid will start
The fuse good? 20 or 30 auto fuse.
Posted on Apr 01, 2012
yakuzza2
  • 68 Answers
SOURCE: cub cadet model 1520 won't start.
Sounds to me like you might be having a problem with either your key switch, or more likely your starter. Although I have never had a starter go out on any riding mower Ive ever had, thats really what is sounds like. On the other hand, I have had many a key switch go bad and they act alot like your symptoms. So I would start at the simplest and work backwards.
Also, make sure blades are disengaged and also they are not bound up on the underside of the mower deck. also check the belt and its not in a bind. These thing could be dragging down your motor keeping it from starting. Let me know if I can help further. Have a Great Day! Good Luck!
Posted on Jun 11, 2012
Testimonial: "This all sounds logical to me and I had already checked to make sure the pto was off and consequentially no belt bind. Kinda leaning toward the key switch more so than starter I'll do some more checking and let you know .thanx for your suggestions."
  • 2239 Answers
SOURCE: Cub cadet will not start
The click you normally hear is the fuel shut off solinoid in the bottom of the carb, if there is no power here and no click you have either no power in the battary, the battary terminals are loose, or there is an inline fuse gone.
Posted on Jun 19, 2012
I need a picture showing the placement of the 2 springs on the mowing deck of a 2011 Cub Cadet Ltx 1040.
Cub Cadet LTX 1040 and LTX1045 Riding Mowers - YouTube
? 2:24
www.youtube.com/watch?v=XLT1v7h4at4
Jun 10, 2013 - Uploaded by CubCadetCA Cub Cadet LTX 1040 and LTX1045 Riding Mowers. CubCadetCA ... How to Change the Deck Belt on a Cub Cadet Riding LawnMower: Using ...
Jul 25, 2015 | Cub Cadet Garden
Did you mean: i have a cub cadet 1040 ltx that is running rough and loud?
Head Gasket possibly
You should be able to find out where
the noise is coming from
Oct 11, 2014 | Cub Cadet Garden
Cub cadet 1000 series LTX 1040 riding lawn mower
Check the pully alignments with a straight edge. Make sure the belt is tight.
May 19, 2013 | Cub Cadet Lawn Mower V belt Replaces CUB...
My Cub Cadet LTX 1040, has no power to anything and will not start
check the battery cables bypass them with your jumper cables the check the safety switches
Apr 12, 2012 | Garden
Starter generator turns over slow with new full charged battery on a 124 cub cadet when trying to start. It is a new starter generator - suppose to have been tested. I have checked wiring - acts like it...
With the battery going dead on its own like that, I think you have a short circuit somewhere that is causing this problem. This could be anywhere in your wiring system so check everything out. Hope this is helpful to you. Best regards and good luck.
Jan 08, 2011 | Cub Cadet Lawn Mower Electric PTO Clutch...
Cub cadet 2140 wont start or turn over
check the cilanoid or the stater , you may also have a lose conaction, try cross jumping the cilanoid
Aug 16, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Cub cadet z54 will no start
one of the safety switches are bad it could be the seat are the clutch are the blade switch you can try jumping a wire to the posts after you unplug them one at a time
Jun 09, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Cub Cadet Riding Lawn Garden Tractor 25hp Kohler 50" Logo
121 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
Matt Olenzek
Matt Olenzek
dannydoesita
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
