Question about Gaiam Exercise & Fitness
Need directions for hand exercise balls - Gaiam Exercise & Fitness
2 Suggested Answers
  • 19 Answers
SOURCE: What's an exercise ball construction?
An exercise ball is constructed of soft elastic material with a 14 to 34 inches diameter, filled with air. The air pressure is changed by removing a valve stem letting the air inside the ball to deflate.
Posted on Aug 02, 2012
Can I use an exercise ball if I am overweight?
Yes you can, you just need to find the right ball. Most exercise balls can only hold up to 250lbs, so you depending on how much you weigh you may need to do some searching around. The key is to look for a burst resistant ball; so that if the ball is punctured the air will leak out slowly, rather than exploding. If you are concerned about your weight being an issue, you may want to take a look at buying an exercise ball from Ball Dynamics. Some of their balls can hold up to 1000lbs.
http://exercise.about.com/gi/o.htm?zi=1/XJ&zTi=1&sdn=exercise&cdn=health&tm=158&f=21&su=p284.13.342.ip_&tt=12&bt=0&bts=1&zu=http%3A//www.balldynamics.com/fitball.php
Aug 06, 2012 | Exercise & Fitness
What exercises can I perform using an exercise ball?
There aredozens of exercises and variations that can be done with the exercise ball.Whether it's core strength, balance, or stability you want to work on, theoptions are extensive. For a complete list of exercises, go to these websites: http://exercise.about.com/cs/abs/l/bl_core.htm,http://www.ball-exercises.com/exercises/index.html,and http://www.fitnessmagazine.com/workout/gear/equipment/best-stability-ball-exercises/.
Can I inflate/deflate an exercise ball?
Ofcourse youcan! Check out these two informative websites to learn how to inflate/deflatean exercise ball: www.livestrong.com/article/22214-inflate-exercise-balls/and http://www.livestrong.com/article/73718-deflate-exercise-ball/
Can anyone explain to me hot to perform the Rocky solo exercise?
Start with sitting on the floor with your legs straight, and hold a medicine ball with both hands above your lap then twist your torso to the right and place the ball behind you. Then twist all the way to your left and pick the ball up and bring it back to the starting position. You should repeat it ten times and then switch directions (to your left).
Aug 05, 2012 | Exercise & Fitness
How should I perform the standing Russian twist exercise?
Hold a medicine ball with both hands in front of your chest and your arms straight. Pivot on your right foot and rotate the ball and your torso as far as you can to the left keeping your arms up. Then reverse direction.
What are some simple exercises I can do using a medicine ball?
There are so many uses for a medicine ball. I have found a couple of very simple exercises you can do. The first is called the "woodchopper". Stand with your feet slightly wider than shoulder-width apart and hold the medicine ball above your head. Then bend forward at your waist and bring the ball down between your legs. Here is what it should look like:
A second exercise you can do is called a "squat to press". Stand straight holding the ball. Next you need to bend your knees and lower your body until your thighs are parallel to the floor. Then you need to drive your heels into the floor and push your body back to the starting position and bring the ball up over your head. Here is what this exercise should look like:
There are so many more exercises, I highly recommend researching them online or contacting a trainer for assistance.
How do I perform a ball push-up exercise?
You should lie prone with your thighs on top of the exercise ball, legs and back fully extended and hands on the floor, elbows bent. Then you'll need to push yourself up by extending your arms and slowly lower yourself back down after a short pause.
Aug 02, 2012 | Exercise & Fitness
How many different Exercise Balls are they?
There are plenty of Exercise Balls each serves for a different purpose. Including balance ball, birth ball, body ball, ball, fitness ball, gym ball, gymnastic ball, Physioball, Pilates ball, Pezzi ball, sports ball, Swedish ball, stability ball, therapy ball, or yoga ball.
Exercise & Fitness Logo
66 people viewed this question
Top Gaiam Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you a Gaiam Exercise and Fitnes Expert? Answer questions, earn points and help others
