Question about Jenn-Air Kitchen Ranges
Lights won't work on Jenn Air Range Hood - Jenn-Air Kitchen Ranges
VANMAN69
  • 23 Answers
SOURCE: F1-1 error on Jenn-Air Range
if it is the stove that is in the picture the fault codes are in the door under the oven door.
Posted on Jun 02, 2007
jsrock516
  • 5911 Answers
SOURCE: jenn air jgr8850adw won't bake
This usually is an indication of a bad igniter. If this is the standard glow type igniter, it could appear as if it is working, but may not be providing enough current to open the gas valve. This is a safety feature on gas ovens. The gas valve requires a current potential of .32 to .37 amps through the igniter before it will open and allow gas to flow. This prevents gas leakage if the igniter fails to light. The reason your broiler works is probably due to the fact that the broiler gets used less and the igniter is probably in better condition. You can test this theory, if you like, by swapping the igniter for the bake and broil burners to see if the symptoms change. Or, you can simply just replace the bake igniter with a new one. Make sure you secure the power before attempting, though. You shouldn't have to turn off the gas for this. Chances are that's all it is. I hope this helps you.
Posted on Jul 14, 2007
SOURCE: Jenn-Air JXT8030ADS kitchen hood has stopped working
Although there was still power going to the hood, my husband decided to try flipping the breaker. This must have reset something in the fan as it is now working.
Posted on Jun 02, 2009
erpaalai
  • 999 Answers
SOURCE: jenn-air electric range model JES9800AAB some kypad # not working
Unless they start working again after it has a chance to dry out the touch panel will have to be replaced. This happens when excess moisture gets between the very thin layers of the membrane.
eric
Posted on Jul 03, 2009
manhandy
  • 146 Answers
SOURCE: JENN AIR RANGE HOOD JXT8136ADS
make sure the fan blade not touching anything. make sure are clean the grease sticking to the blades can make the fan go out of balance
Posted on Jul 05, 2009
Jenn Air gas range- burner not fully lit
Can you verify which burner it is that won`t ignite/burn properly ?
I should be able to help, but I just need some clarity. I`ll watch for your reply.
macmarkus :)
Jan 24, 2010 | Jenn-Air PRG3610 (NP) Gas Kitchen Range
Jul 04, 2009 | Jenn-Air JXT8136ADS Kitchen Hood
Jun 01, 2009 | Jenn-Air JXT8030ADS Kitchen Hood
Lights won't go off
We will have to contact a technician.
Jan 03, 2009 | Jenn-Air JXT8030ADS Kitchen Hood
COOKER HOOD STOPPED WORKING. FAN AND LIGHTS
Power problem....controls ...on going replace
Apr 11, 2008 | Jenn-Air JXT8136ADS Kitchen Hood
The lights dont turn off anymore
On line....sound control board to me...
Dec 29, 2007 | Jenn-Air JXT8136ADS Kitchen Hood
Jenn-air slide in range/convection
its not a loose wire. jenn-air is famous for having to replace the display board. once you replace it it will be fine
Nov 28, 2007 | Jenn-Air SVE47100 Slide-In Electric...
How to reset my Jenn-Air Jxt8836ADS kitchen hood?
According to Jenn-Air (Maytag) if you remove the power from the hood for 15 minutes it will reset the board. So depending on how long the power was out the outage would have done this. There is a good possibility that the outage ruined your board.
Oct 31, 2007 | Jenn-Air JXT8836ADS Kitchen Hood
Kitchen Ranges Logo
75 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Craig Butler
Craig Butler
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
