Question about AO Smith Pool Pump Motor Hayward Swimming Pool Pump Full Rated Motor / Cen
Can a pool pump copasitor destroy the motor - AO Smith Pool Pump Motor Hayward Swimming Pool Pump Full Rated Motor / Cen
    Top Expert:
  • AO Smith Master
  • 8,163 Answers
Replace capacitor it could have shorted armiture
Posted on May 10, 2015
Can you leave an automatic pool cleaner in permanently
Not a good idea, unless it is a self-contained or using a separate pump, even then only run it when it's needed.The kind that use the pools circulation pump should only be used when needed. pool screened in ? use the cleaner 2 times a month for a few hours,
running a creepy crawler every time the pump comes on restricting the flow DRASTICLY reducing flow and will cause chemical imbalances eventually destroying the pools finish.-pump -filter ...
Jan 07, 2017 | Pool & Spa
My Intex Pure Spa will not turn on. It is about 4 months old, just makes a high pitchd squeal and nothing on the display. Help.
Most likely something to do with the pump or motor. If it has a clean-out basket check that and make sure nothings blocking the way. Your impeller might be destroyed/jammed or it could be motor failure, bearings any number of things.
Jul 22, 2015 | Intex Pool & Spa
How do I backflow a Jaccuzi pool pump model CFR150-S15TBU9-3-HK6?
**DO NOT** attempt to backwash/backflow a cartridge filter. You will destroy it if you do. Instead, you need to remove it from the canister and wash it per the manufacturer's directions.
Here's a video too:
https://www.youtube.com/watch?v=1N1e0CFDcNo
Jul 23, 2014 | Pool & Spa
Working but no water pressure
my favorite pump ! remove stainless steel band this will allow you to split the pump, pull back from plumbing portion remove diffuser 5 small screws inspect impeller for trash or if it's broke.
if it has trash in it the hair basket or it's pot may be broke. these in my opinion are the best pump! and are easy to service.
option # 2
search your area for your local pool pump motor repair guy with free testing, bring it in and let him have a look-see at it.
never ever never touch the 4- 9/16 bolts, tightening them will destroy the seal plate (not stop the drip !)
would you like to know how to make the pump last longer ??
shhhhh don't tell no one, it's our little secret. DON'T STARVE THE PUMP FOR WATER !
J the pool pump doctor longwood Florida 32750
Feb 22, 2013 | Sta Rite 1 HP Sta-Rite Pump: 1.5" in/out,...
Smoke coming out of pool motor. Capacitor replaced, internal parts look ok
WHEN this motor catches on fire it will destroy the rest of your pump and probably take out your filter also. Maybe your house while it's at it.. Replace the motor. You are literally playing with fire.
Jan 12, 2013 | Hayward 2HP Pool Pump Motor A O Smith...
Do u have to prime all pumps
YES all pool pumps need to be primed, failure to do so will destroy the shaft seal AND could cause serious damage to the pump and motor. starving pumps is bad also. Make sure they have water, it makes them happy.
Apr 28, 2012 | Sta Rite 1 HP Sta-Rite Pump: 1.5" in/out,...
How do you change the rotation from anti cw to cw at the impeller end of a 1081 emerson pool pump
You can not without destroying the motor.
Why? The rotation is set at the factory during construction and the leads necessary to reverse it in the field are not brought out of the winding. You would have to strip back the leads, determine where the start winding terminates, and then we configure the leads to allow for extensions on the start winding to be brought out to the terminal area.
Like I said...you cannot reverse it.
John
Jan 26, 2011 | Emerson THREADED SHAFT UP RATED - 1.00 HP...
Very noisey pump
needs bearings asap.. search your local area for pool pump motor repair with free testing and get it repaired before you destroy the motor and pump ..click here is how to remove your pump
Jan 09, 2011 | Pool & Spa
Need ao smith replacement motor for anthony pool pump not sure what motor fits that pump
a rebuilt motor is the cheap way $85 ,new around 200, the impeller will need to be ID to get the right size motor. search for your local pool pump repair guy with free motor testing, use your zip code in the search. you might get your old motor rebuilt and thats even cheaper .. CLEAN POOL IS A SAFER POOL .. VOTE COMMENT .. thanks jay
Aug 16, 2010 | AO Smith Pool Pump Motor 1HP Square Flange...
The motor unit leaked and is destroyed. Where can
Thank you for posting your question here on Fixya.com.
For a quote on replacement parts as well as having the unit repaired, please use the dolphin button found on the bottom of our site at www.arrowpools.net. Please understand that in order to retain warranty coverage assigned to a new motor it needs to be installed at an authorized service center.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Mar 20, 2010 | Smart Pool Inc Dolphin Diagnostic...
AO Smith Pool Pump Motor Hayward Swimming Pool Pump Full Rated Motor  / Cen Logo
47 people viewed this question
Top AO Smith Pool & Spa Experts
Jay Finke
Jay Finke
Steve
Colin Stickland
Colin Stickland
Are you an AO Smith Pool and Spa Expert? Answer questions, earn points and help others
