Question about Vital Signs UT4000A Patient Monitor
DISPLAY LESS BRIGHTNESS - Vital Signs UT4000A Patient Monitor
Flicker at startup, wakeup, and battery power
some latptop do not like the brightness lowered... open control and set brightness to max... this should stop that... sorry
Apr 02, 2015 | Computers & Internet
Faint picture screen
Press the reset switch to reset the garmin, is the backlight turned off in the settings or is it possibly faulty?
Oct 27, 2008 | Garmin StreetPilot c530 GPS Receiver
I have a NP470RSE-K01UB that has been upgraded to Windows 8.1 and I am having display brightness issues. I have all the Windows power settings set to max brightness regardless of whether the computer
Go to samsung website and go to support section. Download and install the samsung hotkey software. This should fix your hotkeys to turn brightness up and down.
Aug 11, 2014 | Samsung Computers & Internet
How do I adjust brightness and contrast
On a MacBook try hitting F1 and F2. You'll notice they have small little icons to signify less bring and more bright.
Also doable via the display Preferences (Apple Icon top left, Preferences, Display).
Jan 30, 2014 | Computers & Internet
ACER ASPIRE BRIGHTNESS STAYS AT EITHER 100% BRIGHTNESS OR 0% NOT INBETWEEN
You are correct in thinking it may be a driver issue. Check the device manager and see if the drivers are installed. Under "Display Adapter", you should see the make and model of your device. If it shows up as Standard VGA Adapter, then you are using built in drivers and should look for the right drivers.
If everything looks good otherwise, then you are probably looking at a faulty LCD/LED. A faulty LCD/LED can yield all kinds of problems, and replacing the entire unit is usually the easiest option. On average an LCD/LED is more or less $50.
Sep 17, 2012 | Acer Aspire 5735 Notebook
At start up my viewsonic va1912wb display blinks several times then i can see the picture but it is dark almost unreadable. Today it went darker than yesterday. HELP!
If it is dark due to brightness adjustment, get that adjusted. Usually when you adjust the brightness by pressing the menu button, the menu screen would not be dark. If everything is dark dark dark and you can only see some display but in very pitch darkness, then your monitor is a goner, backlit for the monitor is dead, and your monitor will need to be replaced. You can fix the backlit tubing, however it is risky, and expensive, and would cost less if you bought a replacement.
Jan 30, 2011 | Computers & Internet
My display is very dark - can barely see pictures on the display. The fn brightness button doesn't respond. Gateway laptop model M305CRV. Please help
control panel,display,settings you can make adjustments for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general
dpi normal size,larger size or custom settings
hope this helps
Nov 11, 2010 | Gateway M305CRV Notebook
Laptop display light not working
It may be the inverter whick is a small board located at the bottom of the LCD panel and plugs into the backlight. Usually you can get them off of eBay for less than $20
Hope this helps
Apr 25, 2009 | Dell Inspiron 9200 Notebook
Dim monitor
I am assuming this is on your laptop display and not a monitor connected. If this is the case, you most likely pressed FN + the DOWN ARROW. You can use the FN key (usually on the left side near CTRL and/or ALT) in combination with the UP and DOWN arrows to increase/decrease the brightness. This is real handy when you want to have longer battery life as the lower the display brightness is the less power it uses.
Hope this helps,
Chris
Mar 23, 2009 | Dell Latitude D600 Notebook
Vital Signs UT4000A  Patient Monitor Logo
29 people viewed this question
Top Vital Signs Medical Experts
Electro Med Services...
Rhonda Webster
Rhonda Webster
Are you a Vital Signs Medical Expert? Answer questions, earn points and help others
