Reset vidikron 70 after bulb replacement - Office Equipment & Supplies
Vidikron projector Crystal One
Try Googling (Vidikron)(model)(manual) without parens.
May 06, 2017 | Vidikron Crystal One Lcd Projector
Vidikron 30 projector will not turn on. Power light is lit.The remote flashes red when on button is pushed but projector does not turn on
According to the user manual it must be returned to the manufacture for repair
you can contact them
Vidikron
2900 Faber Street
Union City, CA 94587
510-324-5900
Fax 510-324-5905
1-888-4-VIDIKRON
www.vidikron.com
Jul 14, 2015 | Vidikron Office Equipment & Supplies
WHY DOES MY HD OPTOMA DLP 70 TURN OFF AFTER FEW MINUTES?
If you have recently replaced the bulb you may need to reset the lamp counter in the projector menu.
If you have not replaced the bulb, the projector may be shutting down due to over-heating. Check that the projector is clear of as much dust and debris as possible.
Sep 03, 2014 | Optoma Hd70 Dlp Hd High Definition 720p...
How do you reset lamp timer
This is usually accessed from the projector's main menu. Use your remote by pressing 'MENU'. Navigate around each menu option until you find something referring to 'RESET'. (ie: reset lamp, reset, reset to zero)
No remote? - You'd have to use the onboard projector buttons.
-GWOOD
Jul 15, 2014 | Vidikron Office Equipment & Supplies
Only half a picture
"the vertical lines" is not correlated with the lamp
1,the interface between the mother board and DMD drive board
2,to clean the the interface with some alcohol
3,securely plugged
any questions, feel free to contact me
We supply original projector lamp,bulb,accessories,Lcd panel,Lens,DMD chip,color wheel,motherboard,powersupply,ballast... with high quality and competitive price.
have a nice day!
Jerry,Lampdeng Limited
skype:lampdeng
Feb 16, 2014 | Vidikron MODEL 65 Lamp
Vidikron vision 40 2003 Power will not come on now and no power light. Occassionally will come on after 10 minutes after turning on but then shut down
The capacitors on the power supply need to be replaced. When you take apart the projector, and then remove the power supply (it's the section that the power cord goes to) and open it up. Look for the little can capacitors and see if any of them are bulging on top. That is the sign that they've blown. Replace the big ones (about 5) for about $5 in parts. Reassemble and test by turning it on. Search for YouTube video For similar problem on Runco projector. Very easy fix.
May 23, 2011 | Vidikron Office Equipment & Supplies
I had the bulb blow out in my Sony 60" projection TV. I replaced the bulb and with in 2 weeks I had the on screen notice appear that the bulb was failing. I returned that bulb for another one but the on...
Have you reseted the lamp timer of your tv? if not, you should do it, because it's just adding more and more hours to it to the ones it already had and it's indicating the tv that the lamp is going out, reset the lamp timer and you should be fine, if not, it's probable you might have a defective ballast which are not expensive, they're way cheaper than a lamp, they're running around 70 dlls
Jun 29, 2009 | Televison & Video
27 people viewed this question
jasbo
jasbo
