Question about RCA HD52W56 52" Rear Projection HDTV
RCA HDTV 52# is zoomed in
The picture is sooo big, it doesn't fit on the screen and we can't seem to fix it.. the menu and format buttons on the remote don't work on this channel.
  • Anonymous Nov 26, 2007
    Had the same problem....If you have a digital cable box through Comcast there is a setting on the box that will fix this problem.
  • Anonymous Mar 25, 2014
    How do you adjust picture to fit screen
  • 4,402 Answers
Had the same problem....If you have a digital cableRCA HDTV 52# is zoomed in - 1.gif box through Comcast1.gif there is a setting on the box that will fix this problem.
Posted on Dec 15, 2007
Why is the picture is to high or big and cuts off the heads of the people on my RCA HD52W59 rear projection HGTV
its setting the screen format . take the factory remote and by using the cursor left or right you can scan the size changes
May 23, 2014 | RCA HD52W56 52" Rear Projection HDTV
I have a sony bravi xbr ;the picture is sooo big i can't read the subtitles . i tried ti fix it ( from the instruction manual ) but nothing work . thank you !
Hi: Check you screens format button to change screen sizes, this button may also be labeled Aspect. Seems you are in ZOOM Mode, these buttons can also be found on cable boxes remote as well try pushing them to see if screen size change. If this does'nt help then do this with the TV in off posistion. Press the Display key on your remote, Then the Five key, then the Vol up key, then press power key. This will turn set on in service mode, you will see service options do not do anything but press the number 8 on remote and hit enter. This will rest tv to factory settings. All video setups and parameters you have set in user menu will result back to factory and will need to be redone. TV should shut down on its own and come back on on channel 3.
Dec 10, 2011 | Sony BRAVIA KDL-52XBR3 Television
Go to menu then got to picture then go to advanced picture settings and turn off the auto format button
Nov 07, 2011 | RCA D52W23 52" HDTV CRT TV
Picture does not fit into 52 in as if there is a zoom on can't see writing at bottom of screen, for example basketball scores
You have to press the hd zoom# or format or wide (or etc.) button on your cable tv or satellite tv remote. If that isn't doing anything then you might have your cable box or satellite tv receiver set on the wrong resolution for your television. Your television's remote might also have a wide or format button on it that needs to be pressed. Also make sure your television is on the right input.
Apr 04, 2011 | RCA R52WM24 52" HDTV Projection Television
Picture does not fit screen. People head is chooped off.
I have heard that using the directional buttons on the remote left or right changes the picture format. I believe you should also be able to go into the menu and change it there.
May 30, 2009 | RCA D52W19 52" Rear Projection Television
My tv zooms in and changes the format.
This is normal - you are zooming in on the picture. Most people use the zoom feature to "stretch" a widescreen movie so it will fit the screen.
Dec 19, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Screen is to big
Either the TV or the cable/satellite receiver has Zoomed in to the image when parts of the picture are cut off. Look at both remotes for a Zoom feature or the onscreen menu's for any settings. Usually TV settings don't change on their own but cable/satellite receivers can receive updates and it may need to be reset afterwords, much like a PC.
Oct 17, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Your TV set may have settings for picture size ratios but also if you have cable or sattelite service, they too may have these settings. Try both TV and cable remocons for proper adjustment
Jul 26, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Picture to big for the screen
sounds like you have the zoom feature on. use the left and right arrows to set the picture.It will also set the picture format also.
Nov 07, 2007 | RCA HD52W59 HDTV Projection Television
Projects picture bigger than screen..
This must be a duplicate, and since I'm not sure which one you'll be checking back with: Go into the menu and select picture settings and then advanced picture settings. I'm not sure on that model that you can manually change the aspect ratio from zoom to 16:9 or 4:3 ect... But select Auto Format and the TV will pre-select the correct format for viewing..... Any questions just let me know. Bill
Jun 11, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA HD52W56 52" Rear Projection HDTV Logo
104 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
