Question about Matsushita DD73C14GAU6 1/4 HP R134 Compressor 115V/6Compressor
Insufficient power at -15°C
Where can I find the caracteristics of the compressor Matsushita 5JS330DAD01 for temperatures between -10°C and -18°C.
The comprssor is used in a heat pump
  • 35 Answers
CALL MATSUSHITA
Posted on Jun 18, 2009
  • NINEHOUSER Jun 18, 2009
    CALL MATSUSHITA
How do I get the fault codes up on a Panasonic split air conditioning system CUE24FKR
14.2.2 To Make a Diagnosis1 Timer LED starts to blink and the unit automatically stops the operation.
2 Press the CHECK button on the remote control continuously for 5 seconds.
3 "- -" will be displayed on the remote control display.
Note: Display only for "- -" (No signal transmission, no receiving sound and no Power LED blinking)
4 Press the TIMER ? or ? button on the remote control. The code "H00" (no abnormality) will be displayed
and signal will be transmit to the main unit.
5 Each press of the button (? or ?) will increase error code
number and transmit error code signal to the main unit.
6 When the latest abnormality code on the main unit and
code transmitted from the remote control are matched,
Power LED will light up for 30 seconds and a "beep" sound
(continuously for 4 seconds) will be heard. If no codes are
matched, Power LED will light up for 0.5 seconds and no
sound will be heard.
7 The breakdown diagnosis mode will be canceled unless
pressing the CHECK button continuously for 5 seconds or
operating the unit for 30 seconds.
8 The LED will be off if the unit is turned off or the RESET
button on the main unit is pressed.
Diagnosis
display Abnormality / Protection control Abnormality
Judgement Emergency operation Primary location to verify H00 No abnormality detected - Normal operation H11 Indoor / Outdoor abnormal communica
tion > 1 min after starting
operation Indoor fan operation
only • Internal / external cable connections
• Indoor / Outdoor PCB H14 Indoor intake air temperature sensor
abnormality Continue for 5 sec. - • Intake air temperature sensor (detec
tive or disconnected) H15 Outdoor compressor temperature sensor
abnormality Continue for 5 sec. - • Compressor temperature sensor
(detective or disconnected) H16 Outdoor Current Transformer open cir
cuit - - • Outdoor PCB
• IPM (Power transistor) module H19 Indoor fan motor mechanism locked 7 times occurance
continuously - • Indoor PCB
• Fan motor H23 Indoor heat exchanger temperature sen
sor abnormality Continue for 5 sec. O
(Cooling only) • Heat exchanger temperature sensor
(detective or disconnected) H24 Indoor heat exchanger temperature sen
sor 2 abnormality Continue for 5 sec. - • Heat exchanger temperature sensor
(detective or disconnected) H27 Outdoor intake air temperature sensor
abnormality Continue for 5 sec. O • Outdoor temperature sensor (detec
tive or disconnected) H28 Outdoor heat exchanger temperature
sensor abnormality Continue for 5 sec. O • Outdoor heat exchanger temperature
sensor (detective or disconnected) H30 Outdoor discharge air temperature sen
sor abnormality Continue for 5 sec. - • Outdoor temperature sensor (detec
tive or disconnected) H33 Indoor / Outdoor wrong connection - - • Indoor / Outdoor supply voltage H38 Indoor / Outdoor mismatch (brand code) H50 Ventilation motor abnormality 7 times occurance
• Ventilation motor H51 Nozzle lock abnormality 2 times occurance
continuously - • Nozzle H52 Limit switch abnormality - - • Indoor PCB H97 Outdoor fan motor mechanism locked 2 times occurance
within 30 minutes - • Indoor PCB
• Fan motor H98 Indoor high pressure protection - - • Air filter dirty
• Air circulation short circuit H99 Indoor heat exchanger anti-freezing pro
tection - - • Insufficient refrigerant
• Air filter dirty F11 Cooling / Heating cycle changeover
abnormality 4 times occurance
within 30 minutes - • 4-way valve
• V-coil F90 PFC control 4 times occurance
within 10 minutes - • Voltage at PFC F91 Refrigerantion cycle abnormality 2 times occurance
within 20 minutes - • No refrigerant
(3-way valve is closed) F93 Compressor rotation failure 4 times occurance
within 20 minutes - • Compressor F95 Cool high pressure protection 4 times occurance
within 20 minutes - • Outdoor refrigerant circuit F96 IPM (power transistor) overheating pro
within 30 minutes - • Excess refrigerant
• Improper heat radiation
• IPM (Power transistor) F97 Outdoor compressor overheating protec
within 10 minutes - • Insufficient refrigerant
• Compressor F98 Total running current protection 3 times occurance
within 20 minutes - • Excess refrigerant
• Improper heat radiation F99 Outdoor Direct Current (DC) peak detec
tion 7 times occurance
continuously - • Outdoor PCB
• Compressor
Note:
"O" - Frequency measured and fan speed fixed.
The memory data of error code is erased when the power supply is cut off, or press the Auto Switch until "beep" sound heard following by pressing the "CHECK" button at remote controller.
Although operation forced to stop when abnormality detected, emergency operation is possible for certain errors (refer to Error Codes Table) by using remote controller or Auto Switch at indoor unit. However, the remote controller signal receiving sound is changed from one "beep" to four "beep" sounds.
Oct 13, 2017 | Panasonic Heating & Cooling
I need the cooling capacity of a matsushita cnr05-980270 compressor. can anyone please assist?
I would need more information to properly answer your question.
What are you removing this compressor from?
The cooling capacity can vary greatly depending on the Evaporator size, the Condenser size and the fan speed that is moving the air. Also there are some other figures needed.
But if you could give me the application that you are using the compressor in I might be able to better answer your question!
Oct 11, 2013 | Matsushita DD73C14GAU6 1/4 HP R134...
I need the capacitor size for a Matsushita compressor model #2P19C3R126A Thanks
It just so happens that I am about to replace the compressor,on a marine A/C unit that uses the Matsushita 2p19c3r126a compressor. I believe it uses a 30 mfd capacitor.
Jun 10, 2011 | Heating & Cooling
I'd lke know, the HP of this compressor MATSUSHITA DB91C14RAW5 thanx
According to the information you have given it is a one quarter horsepower compressor
designed for R134 refrigerant. It runs on 115 volts.
Apr 03, 2011 | Matsushita DD73C14GAU6 1/4 HP R134...
Cannot find supplier for special matsushita relay
Go to loadparts.com and search with the part number.
Mar 25, 2010 | Computers & Internet
Frigidaire r134a compressor.how can i know the horse power
It depends the model number, 452 BTU are 1/6 HP, R134a 776 BTU are 1/5 HP.
Dec 20, 2009 | Matsushita DD73C14GAU6 1/4 HP R134...
HP OF R134-ADMIRAL REF
it will be located on the compressor plate of the rateing of hourse power and amperage with the amount of freon needed to fill it.
Jun 25, 2009 | Matsushita DD73C14GAU6 1/4 HP R134...
Freezer just stopped won't even turn on
Hi with those temperatures It wont come on Its too cold. It will work ok
Dec 22, 2008 | Haier 5 cu. ft. / 142 liter Chest Freezer...
Matsushita DD73C14GAU6 1/4 HP R134 Compressor 115V/6Compressor Logo
256 people viewed this question
Top Matsushita Heating & Cooling Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Marat Brikov
Are you a Matsushita Heating and Cooling Expert? Answer questions, earn points and help others
