Question about Electrolux ICON Designer E30SO75ESS Oven
I have checked my oven temperature with a separate oven thermometer, and my oven is 25 degrees hotter than the setting. Even when I adjust for this, I still have cakes that don't rise enough or soggy crusts. I bought fresh flour and followed all procedures per the recipe. What is wrong? How do I calibrate my oven?
4 Suggested Answers
SOURCE: Oven not working
i have a electrolux top oven is ok bottom ove and timer are not working modle is  edomss
Posted on Jan 14, 2009
  • 189 Answers
SOURCE: oven tempeture lower than setting by 100 degrees
Hey-  Let's fix this thing.  Several things can affect indicated/actual temperature.  The temp probe should test ok across it's lead wires at around 1100ohms. The computer usually shows a fault if the circuit is open, but won't show a code if it hasn't failed completely.  The next suspect is the igniter for the oven burner.  These can become weak with age, affecting gas flow to burner. Testing igniter is not really possible when it comes on and the part is usually replaced.  The regulator is next in line, occasionally causing variable flow to burner.  As you can see, quite a bit to consider.  On site diagnostics is usually required, but this gives you a start.  Installation instructions are available for all parts.     Please acknowledge this post if my info and time spent helps you.  Have more info if needed.  Thanks- Ed
Posted on Mar 26, 2010
barkencoa
  • 3463 Answers
SOURCE: My oven does not heat to the correct temperature.
The thermostat is the cause of the problem, normally the the only cure is to replace the oven thermostat,completely, or alternatively, compensate by setting a lower temperature when cooking.
this will work o/k if it is always the same variation in temperature across the range .
Posted on Dec 25, 2010
Can't adjust oven thermostat
Has this just happened or have you suddenly just tested the oven temperature with a RELIABLE thermometer? Some cheaper thermometers can give a false reading. Check with a accurate thermometer first and place it at intervals in different parts of the oven ( it does vary) and take the average
Jan 17, 2014 | GE Profile JK915 Electric Single Oven
Hotpoint ew81n cooker. Non working oven thermostat has been replaced. The cooker temperature is hotter than the dial reading. What can I adjust to make them the same?
Hi.
Unfortunately, the oven thermostat is non adjustable.
However, it is normal for oven temperatures to vary by + or - 10% of the setting.
This is acceptable, so to compensate, set the temp 10% less of the required temp setting.
Make sure you have the sensor fitted correctly inside the oven compartment
Make sure that the thermometer is accurate if you are checking the temperature with one.
Feb 23, 2011 | Hotpoint Ovens
Oven runs much hotter than set temperature. Usually 50 degrees hotter than what it is set at, but can go over 100 degrees higher.
Sounds like you need a new oven thermostat or get an oven thermometer and by experimentation draw up a new heating range for the oven dial.
Feb 11, 2011 | Frigidaire Ovens
When set to bake eg: 350 degrees the audio alarm will indicate it's reached temp but the oven is 50- 75 degrees lower. Must wait another 15 min for it to reach the proper temp. Have tried to adjust the off...
If you are monitoring the oven temperature with an analog style thermometer you may actually be ok, but seeing the thermometers slow reaction time.
Some newer ovens actually do pre-heat beep prior to reaching temp in an effort to conserve eelectricity.
A good home test is to try your oven at several different temps to see if there is any variation in internal temperature. Try it one day on 300, the next at 375 and another day at 450. Give your analog style thermometer time to catch up (usually just about 15 min) and leave it on for a half an hour to see if the temp maintains.
Also Beware of aluminum foil AND THE NEW OVEN LINER MATS as they can alter oven performance bay absorbing and blocking the ovens natural heat radiation and convection air flow currents that happen in all ovens, not just convection models.
Another interesting fact is that older ovens used a thermostat in them that operated much like your thermometer and was very slow to react making the oven typically about 100 degrees hotter than where the customer set it. This was just a fact of life before the advent of electronic temperature management and became noticeable when people began trying to bake older "hand me down" recipes in the newer ovens with less than stellar results.
You can mimic the older oven performance by preheating the oven about a hundred degrees higher than called for and after it reaches temp, re-set it to the correct temperature and put the items in right away.
If you find your temperatures fluctuating ask your servicer to replace first the temp sensor and as a last resort the control board as this part is usually pretty expensive.
Good Luck with this!
Jun 14, 2010 | Ovens
I bought an oven thermometer and it indicates that the oven temperature is approximately 100 degrees lower than the temperature set on the oven. Is there an adjustment to make so the set temperature is...
It sounds as if an element in the oven is not working do check again that the oven thermometer is on same scale as the oven settings farenheit or centigrade.Most likely it is an element fault.
Hope I helped.
May 07, 2010 | GE Profile JT915 Electric Single Oven
I have a frigidaire stove that heats to 50 degrees hotter than the know setting. Can it be adjusted to read correctly?
There is a calibration method to adjust the oven thermostat plus/minus 35 degrees if it is a digital display. The method varies depending on the model range. This calibration method is used to adjust the thermostat if it is not keeping proper tempature. For example if you are setting the oven to 350 and the actual temp it is keeping is 325 then you could use the calibration method to adjust it plus 25 degrees to correct the temp. Just so you know electric ovens will keep a pretty even temp but gas ovens will vary by 40 or more degrees to keep an "average" temp. For example the burner will come on when the oven is 330 degrees and turn off at 370. 330+370 then divide by 2=350. So a oven thermometer may not show you the temp you set it at in a gas oven but does not mean the oven temp is off.
Jan 14, 2010 | Ovens
My oven burns everything.
Use a 'oven thermometer' in the oven and determine the 'actual temperature' in the oven. Your knob setting is off (not calibrated) and the oven is hotter than the control knob setting.
Sep 16, 2009 | Ovens
Incorrect temperature
under the oven knob is the screw that adjusts the temp. remove the knob and with a small blade screwdriver adjust the temp according to your wife's oven thermometer CW+hotter CCW=cooler
then on the back of the knob is a screw to adjust the position of the knob with respect to the marker
Apr 20, 2009 | Viking 30" Professional Select Built-in...
My Whirlpool oven no longer heats to the set temperature.
Temp probe/thermometer inside oven dirty, or off attachment, or defective. On some models, a small screw head adjustment is provided to calibrate thermometer under dial knob. Else, I would just set dial 50 degrees higher rather than expense of new thermometer or dial.
Mar 02, 2009 | Ovens
Oven temperature only gets to within 20-25 degrees of temp. set
next to last page in your manual
Adjusting Oven Temperature
Oven temperature has been factory calibrated and tested. If
oven consistently over or under cooks food, adjust thermostat.
Oven temperature can be increased or decreased 35°F. To
avoid over adjusting oven, move temperature 5°F each time.
1. Push BAKE pad.
2. Press + pad until an oven temperature greater than 500°F
shows in display.
3. Immediately push and hold, approximately 5 seconds,
BAKE button until “00” appears.
4. Press + or - arrow pad to adjust oven temperature.
• To increase oven temperature (for a hotter oven), Press
pad until a positive number appears in display.
• To decrease oven temperature (for a cooler oven),
Press pad until a negative number appears in display.
5. Press OVEN CANCEL pad to save adjustment.
• Setting is saved if power fails or is disconnected.
heres a link to the entire manual if needed
http://shop.amana.com/assets/pdfs/literature/32103601.PDF
Nov 27, 2008 | Amana AOCS3040SS Electric Single Oven
Electrolux ICON  Designer E30SO75ESS Oven Logo
29 people viewed this question
Top Electrolux Ovens Experts
ashburton
Mack Baxter
Are you an Electrolux Oven Expert? Answer questions, earn points and help others
