Question about Panasonic Viera TH-50PX80U Plasma TV
Red power light flashes and tv won't start
Tv worked fine last nite but today it won't start and the red power light just flashes
SOURCE: tv won't work
try new inverter panel
Posted on Apr 24, 2008
djchillsnyc
  • 151 Answers
SOURCE: The tv wont turn on
hello 2 blinks on this tv means you have this issue below
PT-44LCX65
2 blinks 5 secs you have your lamp cover open
check for this
hope this helps
Posted on Dec 14, 2008
ginko
  • 19396 Answers
SOURCE: Panasonic TH-42PD25 power problem
If the TV goes in standby, then it is in protection mode.
Ensure also that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem on DVD with no receiver box
connected.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the TV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
On LCD Pay particular attention at inverter and power board, power board can be inspected looking for bulged or leaking capacitors, then tested with a multimeter. The inverter is more difficult to test , there is need to read voltages, should be done by a tech. Also the LCD controller board can cause same problem
On Plasma, test Sustain (Ysus/Zsus) / Buffer boards , cables to plasma, digital board and power board.
On Rear Projection : check lamp, lamp ballast, power board, and convergence.
On CRT TVs, check ballast , flyback transformer, CRT, Tuner, Convergence.
Posted on May 05, 2009
Karthik316
  • 187 Answers
SOURCE: flashing red light
When the power light blinks the set's protection circuits are causing the unit to shut off and blink. The series of blinks is an SOS signal that a servicer can decode to help diagnose the problem.
For those in areas other than in the US, I can't really say what the issue might be as the SOS patterns may be different for different countries. But, if you can find a service manual for your area you should be able to at least get an idea of what might have happened to it. There's no guarantee that what you read is the actual problem without further testing, however a solution which may work is press & hold the power switch on the TV -- that resets the switch..
psl rate my suggestion.
Posted on Jul 24, 2009
  • 5 Answers
SOURCE: Power to TV, cant power on, red light flashing
The repetitive blinking light is a trouble code which is used to determine which series of boards may need to be replaced. How many times does the red light blink?
Posted on Aug 30, 2009
Black screen
It is likely that you now have power supply trouble.
May 26, 2013 | Philips Televison & Video
TV won't turn on power light flashes 10 times
Switch off the TV from remote, then switch off the on/off button on the TV, remove the plug pin from the power outlet. Cool off for 48 hours and then retry. If nothing works, better refer it to a qualified service technician.
Jul 18, 2012 | Panasonic Televison & Video
TV won't turn on
It sounds that, the memory IC to your TV has damaged. This IC can be located very near to main system control IC. A very small one, with 8 solder terminals. Even though it is very small, function of it while the TV works is great. The work is a semi-skilled one, and you must have some knowledge in electronics to proceed.
Jul 09, 2012 | Akai Televison & Video
RCA LCD TV red light flasiing tv won't come on
Bad main logic board. Probably won't be able to find it. You can try Encompas Parts. Good Luck to you.
Nov 20, 2011 | RCA L32WD22 32 in. LCD HDTV
JVC TV has flashing red light in front. TV won't turn on when red light starts flashing. After unplugging tv for a while, TV sometimes turns on but screen is shaking violently. Any flashing lights...
sometimes a leaky filter capacitor in the power supply primary section could caused this problem,or a loose solder connection in the power supply section
Jul 18, 2011 | JVC AV-32230 32" TV
My flatscreen emerson tv will not turn back on.
I found a way around this problem. When this happens, don't use the remote.
Walk up to the TV, then HOLD DOWN the power button and while the lights are flashing, start pushing the menu button on the TV at the SAME TIME.
Then your screen will turn on. No idea why this works. Just stumbled on it while getting ********** that this TV, I had less than a month, suddely would not come on anymore. I was about to unplug the whole thing to take back to WalMart and just started pushing button combinations and found this worked.
Mar 30, 2009 | Emerson LC320EM8 32 in. LCD TV
Red Blinking Light/No Picture
7 blinks? Many have replaced caps on the SMPS board, with success: 2662 is a 1000μF 25v 85°C with 2663 and 2664 both 25v 1 00μF 25v. Another model: http://www.hotelkaveka.com/9944CU.jpg
Some other pics of different caps: http://i121.photobucket.com/albums/o229/garafrax/TV%20Repair/HPIM1458.jpg
Jul 08, 2008 | Philips 42PF9630A 42 in. Plasma Television
SAMAUNG MODEL LN37A550
For the User Manual go to;
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
You will need to create an account - it free.
Jun 04, 2008 | Televison & Video
Power indicator is flashing
Possible error on JB board - diodes D5701, D5703, D9616. Replacing them should be sufficient. Anyway, you should contact the nearest Sony Service. Regards, Arpi
Mar 16, 2007 | Sony KDF-E50A10 50 in. LCD HDTV
Panasonic Viera TH-50PX80U Plasma TV Logo
20 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
