Question about KitchenAid Kitchen Aid KERS206X Electric Ranges
Thermal fuse for kitchen aid model kers206x - KitchenAid Kitchen Aid KERS206X Electric Ranges
2 Suggested Answers
dmftrucker
  • 1922 Answers
SOURCE: blown fuse inmy kitchen aid range
if you havnt lost your main input 120/240 voltage then check around the control panel,you'll probably find a special control fuse in this area
Posted on Jul 28, 2009
I used my self cleaning feature the oven has cooled down and unlocked itself now my stovetop will not-heat up?
Kitchen aid range? Might have a thermal fuse that resets or may need to be replaced typical thermal Bo metal fus3 ( non reset able) can be reset by hitting it hard again a counter top.
Apr 30, 2016 | Bosch Kitchen Ranges
Where is the thermal fuse on my kitchen aid model kesc308lsso electric oven
Hello Billy;
My name is Peter. I am a retired field service appliance technician.
You do not have a thermal fuse on your unit.
Tell me what is going on.
May 15, 2015 | Kitchen Ranges
Free fuse box diagrams
Parts #: W10317343
Substitution: WPW10317343 $145.98 at sears
Parts #: W10354052
Substitution: WPW10354052 $125.92 at sears
Part #: W10317347 front LED board $230 at sears
Many ovens have a bi-metal thermal fuse-also called a thermal limit switch-that protects the oven from overheating. The oven thermal fuse trips when the temperature in the oven gets too hot. After the thermal fuse trips, the oven won't heat. If the thermal fuse trips after the self-cleaning cycle, try resetting the fuse by turning off electricity to the oven, removing the exterior back panel, and pushing the reset button. If the fuse tripped during normal operation, replace it. If the problem persists, the electronic oven control board might require replacement. Reset the thermal fuse after replacing the control board.
Jul 15, 2014 | KitchenAid Ovens
My kitchenaide oven kers206x won't work. lights comes on
I do not know your unit but it sounds like one of the fuses has failed if you have them. If burners work then probably the thermostat. This is just a guess.
Apr 16, 2014 | KitchenAid KESC307 Electric Kitchen Range
Kitchen aid gas range model kgsa906pss. After using self clean oven door is locked and control panel is out. There is power through the thermal fuse. What else should I check?
Try unplugging the unit for about 10 minutes and then plugging it back in. If the problem persists call for service especially if under warranty.
Apr 11, 2014 | KitchenAid KGSA906PSS Gas Kitchen Range
Kitchen aid oven
http://appliantology.org/
Jan 21, 2014 | managemylife.com
My kitchen aid gas dryer is not heating up.
If it is tumbling. This troubleshooting video will help. Could be the thermal fuse,ignitor,or gas coils. The free video will walk you thru testing.
www.appliancehelponline.com/servicemanual.html
Feb 26, 2010 | KitchenAid Dryers
Kitchen Aid Electric Dryer Model # KEYE678BALO, won't start.
This is most often caused by a bad thermal fuse or thermostat high limit cutout. Check them for continuity (with the machine unplugged, of course) They should have continuity -- replace them if open. They should be available at www.appliancepartspros.com Also, if one or both are bad, check the dryer vent as they often are damaged by high heat due to a restricted vent pipe. The website above also has diagrams to help find the parts on the machine.
Dec 30, 2009 | Washing Machines
Kitchen aid oven blackout after using self clean. Waiting for repair. $100.00 service call. $ 70 part fee. From what I read on the internet this will just happen again. Anyone know of a way to solve this...
this is probably the thermal fuse replacement fix (see my other posts for easy replacement directions)..
i'm sure kitchen aid wont recommend this but if you slip a thin piece of cardboard or non combustable insulation material between your replacement thermal fuse and the oven wall, you may not have the problem again..
good luck
tpug
p.s. i'm trying to source an auto-resetting thermal fuse for this application... if i find one, i'll post knowledge for everyone..
Jul 15, 2009 | KitchenAid KGSA906PSS Gas Kitchen Range
After self cleaning cycle on my Kitchen Aid kgsa 906, was finished the door opened, but the next morning the door wouldn't open and the control panel was blank
You may be experiencing the dreaded Thermal Fuse overload problem.. search the other posts, i've included easy steps to replacing it..
(you may want to check yours for continuity with a radio shack tester before you buy a new one)..
good luck
tpug
May 09, 2009 | KitchenAid KGSA906PSS Gas Kitchen Range
Open Questions:
KitchenAid Kitchen Aid KERS206X Electric Ranges Logo
22 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
