Question about Samsung C3050 Cell Phone
How to change upper case
Which key changes case
How do i do upper and lower numbers on my computer ,i am a learner
Upper and lower numbers, or letters? I don't know anything about lower numbers. But you press the shift key or take off the caps lock to change from upper to lower case and vice-versa.
Feb 27, 2015 | Toys
Change from lower case upper case
Have you tried re-installing your input device drivers such as your keyboard? Are you using PS2 keyboard ? if yes then please try to check the pins on each pair
Jul 10, 2013 | Computers & Internet
HOW DO I CHANGE FROM UPPER CASE TO LOWER CASE
Press the "CAPS LOCK" key on your keyboard.
Oct 08, 2010 | Computers & Internet
Hello, When typing on my Mo Droid if I want my caps to stay on how do I get that to work.....I tried holding it down but maybe I am not doing it properly?
If you are typing using the touchscreen, the upper-case arrow, touched once, will upper-case the next letter you type and then back to lower case. It you touch the upper-case arrow twice in a row, you should see a green light come on directly over it. That keeps the caps lock on.
If you are using the slide-out keyboard, touch the upper case key once and you should see a triangle underneath the cursor on the screen. That will upper case the next letter you type. To get it to stay in upper case, hit the upper case button again and the triangle should change to a > symbol, point up, underneath the cursor. That should keep it in upper case mode. Don't hold the upper case button down, as that won't do anything. A third press returns it to normal (lower case).
Jun 14, 2010 | Motorola Mobility Droid (2 GB) Cell Phone
I cannot figure out how to get my phone off all caps for texting
While on the message editor, press 0 to switch from lower to upper case and vice versa.
Oct 09, 2009 | Motorola Mobility TracFone C139-4 Cellular...
I have a motorola tracfone w175g and wondering how to capitalize letters? do you have a detailed manual on the buttons?
Press "0" key.
A plus or minus sign will display in the text space.
The (upper case) "AB" or (lower case) "ab" on the top left-hand side of display will change to case you are seeking.
May 02, 2009 | Motorola Cell Phones
Name change of phone
The default DB password is ######## (pound sign eight times). Then press the SHOW softkey, then enter 04-05-(ext. number). Then press the CHG softkey to change the name. Remeber that you have to use the # key to advance the curser after each letter, and the star key toggles upper/lower case.
Mar 07, 2009 | Comdial 8324S-PT Corded Phone
Changing text message entry text from upper case to lower case
to change from upper case to lower case.press and hold down the number sign button,and the different case would show up on the top of your text message.
Aug 04, 2008 | Motorola Mobility MOTOKRZR K1 Cellular...
Hello
copy all text past in to microsoft word. select all text press function key F3 this wil change case upper and lower and tile case. u can switch which type u want
Mar 01, 2008 | Computers & Internet
Samsung C3050 Cell Phone Logo
14 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
