Question about Nordic Track NordicTrack A2350 Pro Treadmill
Incline stuck on 10
Since folding the treadmill incline will not adjust
  • 3 Answers
SOURCE: Buttons Froze during workout, now none of them work
It sounds like you just need some calibration. To calibrate incline, turn power on press press any incline buttons, as the incline try to change unplug the key. Now re-nsert key and incline will self calibrate,
Posted on Sep 02, 2009
  • 218 Answers
SOURCE: my treadmill is stuck on
incline motor is bad or needs calibrated, try this
1. remove safety key
2. press and hold the speed+ and stop keys at the same time
3. Put the safety key in/on and release the keys
4. press stop once
5. hit the incline + arrow and let the incline go the whole way up and down
6. remove safety key and try
Posted on Aug 13, 2010
SOURCE: incline goes up and down
I had the SAME problem, several time, with my NordicTrack A2250 Treadmill.
Allow it to go fully up and then fully down several times, without turning it off. IT seems to "cycle" that way 3 times and then "reboots" itself and starts working normally, again.
I had to figure this out myself... none of the suggestions I read worked.
Posted on Mar 07, 2011
SOURCE: incline stuck- keep going up and dopwn. Treadmill
I had the SAME problem, several times, with my NordicTrack A2250 Treadmill.
SOURCE: The treadmill is stuck on
I can't solve this, but my Nordic Track T5 zi occasionally does the same thing. The previous two times, I waited until the unit "bottomed out", and then pulled the mag switch (key) off. I unplugged the unit, then plugged it back in, attached the key, and all was well. This worked twice before, but today (3/8/2011)the unit's incline is cycling again, and the old fix isn't working. Maybe it will need to go back to Sears! Unit was purchased in October of 2010. Frustrating.
Posted on Mar 08, 2011
Adjust incline on weslo cadence g 5.9 bought it used no manual
On the rear of walking deck you have the left and right feet. Down the deck is at 0 degree incline, fold them up and you have a 3 degree incline.. You have no incline motor on this model.
Mar 02, 2015 | Cadence Weslo 825 Treadmill Walking Belt
Treadmill deck will not fold in the storage position
HOW TO FOLD THE TREADMILL FOR STORAGEBefore folding the treadmill, adjust the incline to the lowest position. If this is not done, the treadmill may become permanently damaged. Remove the key and unplugthe power cord. CAUTION: You must be able to safely lift45 pounds (20 kg) to raise, lower, or move the treadmill. 1. Hold the metal frame firmly in the location shown bythe arrow at the right. CAUTION: To decrease the possibility of injury, do not lift the frame by the plastic footrails. To raise the frame, bend your legs, keep yourback straight, and lift with your legs. Raise the frameabout halfway to the vertical position. 2. Raise the frame until the latch knob locks into the storageposition. Make sure that the latch knob is locked in thestorage position.To protect the floor or carpet from damage, place amat under the treadmill. Keep the treadmill out of direct sunlight. Do not leave the treadmill in the storage
position in temperatures above 85 Fahrenheit.
http://www.treadmilldoctor.com/?utm_source=fixya&utm_medium=CPC&utm_campaign=Mendi
Jul 15, 2012 | Epic View 550 Treadmill
The treadmill hums when I turn on and error7 appears and will not incline
Dear Sir:
This error has 2 options:
1) Alternative is the elevation motor: a) motor need maintenance b) lube the gear and shaft c) adjust the potentiometer. d) motor faulty.
2) Display board need adjustment Reed switch, see the diagram attached, clean, and tight the connector very well.
sincerely. God bless you
May 02, 2012 | Endurance TF3i Folding Treadmill
How to make the base lock in place.
Before folding the treadmill, adjust the incline to the lowest position. If you do not do this, you may damage the treadmill when you fold it. Remove the key and unplug the power cord. CAUTION: You must be able to safely lift 45lbs. (20 kg) to raise, lower, or move the treadmill.Raise the frame until the latch knob locks into the storage
position. Make sure that the latch knob is locked in the storage position.
May 15, 2010 | Reebok T 1280 Treadmill
ERROR 7
Sounds like a incline problem , could be that the incline motor is stuck or the fuse may have blown on lower electronics.Call or E Mail:
Technical Support & Spare Parts OrderingCall: 01327 701824
Email: helpdesk@yorkfitness.co.uk
Opening Times: 9am-4pm Monday-Friday
Apr 25, 2010 | York Barbell Home Use Fold-Up Treadmill
Aug 23, 2009 | Nordic Track NordicTrack Treadmill, A2550
My Proform treadmill will not incline. It is stuck at about mid incline. When I turn on the treadmill, it raises and lowers back to mid incline right away. Despite pressing incline buttons, there is no...
Under the hood there should be a tech sheet with calibration instructions. I have not worked on these for several years or I would rattle off the procedure. If the sheet is still there make sure you put it back in the plastic sleeve for next time..... Eric
Jun 17, 2009 | Proform Sport 1000 Folding Treadmill...
Manual Treadmills vs. Motorized Treadmills
Treadmills come in two basic varieties, just like lawnmowers: manual and motorized. But, unlike a lawnmower, you will generally get a better workout from a motorized treadmill. Manual Treadmills - Getting Going On a manual treadmill, the action of your feet against the deck moves the belt. Pros * You provide all of the motive power and exercise your lower body. Cons * It can be difficult to get the belt moving intially. That straining against the belt can stress your joints. * You may have to raise the incline of the treadmill significantly to make it easy enough to get the belt moving. * Once the belt is moving, however, you would have to stop and get off to change the incline, so you are stuck with one incline level during each workout. Motorized Treadmill Advantages * The belt is moved by the motor, you don't have to strain to start it. * On many treadmills, you can adjust the speed and incline while you are still walking or running. On others, you may have to get off and adjust the incline manually, but you just have to turn on the treadmill to start the belt again. Manual Treadmills - Speed With a manual treadmill, you go only as fast as you push yourself. If you slow, it slows. If you stop, it stops. Motorized Treadmill Speed and Workouts The speed is adjustable and many motorized treadmills have workout programs that adjust the speed to give you a varied workout. This pushes you to go faster. The constantly moving belt of a motorized treadmill motivates you to keep up. Costs Manual treadmills are relatively inexpensive, in the $100-200 US range. Motorized treadmills for home use cost from $750-$5000, and generally the more you pay, the better you get. Most motorized treadmills under $1000 have underpowered motors and are less sturdy and have fewer options for adjusting the incline, programmed workouts, etc.
Dec 01, 2008 | Endurance TF3i Folding Treadmill
Nordic Track NordicTrack A2350 Pro Treadmill Logo
Top Nordic Track Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
