Question about Toshiba 52HM95 52" HDTV Projection Television
Green light flashes 3 times, tv won't come on
When you plug the DLP TV up, the green led flashes 3 times, pauses, repeats the cycle continuously. The fan is on, Will not turn off or on completely. Checked and reseated the bulb which was replaced 6 months ago. Does not appear shattered. What is wrong with the TV? Is the ballast bad? Is there something I can do to fix this? All I get is a black screen, green flashing led, and a fan running in the background.
    Problem Solver:
Re: green light flashes 3 times, tv won't come on
I have same thing going on. third bulb in 2 years. just replacedthe bulb again a few weeks ago, the tv worked fine, then one morning it would not do anything.. green light flashes 3 times and thats it.. the set does not make any noises or anything... junk.
Posted on Jun 09, 2009
Re: green light flashes 3 times, tv won't come on - Toshiba 52HM95 52" HDTV Projection Television Projection Televisions
If its not the bulb, I have the same problem
Posted on Nov 22, 2007
0 characters
3 Points
All I get is a blue welcome screen on my Mitsu WD-65C9 DLP TV. After several seconds of blue screen, it always just shuts down. I downloaded the Mitsubishi software upgrade, but it did NOT solve...
Hi Mike,
May I know if the LED light at the front panel has a pattern of flashes or flashing continuously in green color.
Please check if you can access the "Self diagnostic screen" by following the steps below.
- To activate, press the front panel "Activity" and "Channel down" buttons at the same time and hold for 5 secs. The Status led will then flash a two digit code. Example, if the error code is "23" the led light flashes 2 times(blink, blink) pause and then flash 3 times(blink, blink, blink). Let me know the error code, it will help to diagnose where the fault came from.
Note : the TV must be in shutdown not switched off, or AC power cord is removed because the code will reset to "12" means no error. Use the front panel buttons not on the remote control. If you can't access the self diagnostic, press and hold the "Activity" button on the front panel for 5 secs before entering the "self diagnostic" code.
Kind Regards,
Nov 25, 2011 | Mitsubishi WD-65C9 65" DLP HDTV
MOST LIKELY problem is the convergence amps but.....
It might be your vertical or horizontal circuit...those initiate a 3 blink failure code too....
Dec 01, 2007 | Panasonic PT-50DL54 50" Rear Projection...
I hav a mit 65 in tv model number wd 60737 it comes on with the words welcome mit and green light blinks and then shuts off.
Does the led light flashes green continually?
Check if you can access the operational error code. The TV must be in shutdown and then press the front panel "activity" and "channel down" at the same time and hold them for 5 secs.
Led light will flash 2 digit code separated by a pause.
23 - 2 blinks pause 3 blinks
Let me know the result...
Nov 16, 2011 | Mitsubishi Projection Televisions
Have a toshiba theatrewide hd dlp. Replaced the lamp because the led indicators suggested to replace. Now the same thing occurs. TV trys to start up. the green light flashes repeatedly while the tv...
Most likely a defective digital module which is part of the light engine and cannot be bought separately. The average cost to replace the light engine assembly is around $800.00.
Apr 26, 2011 | Toshiba TheaterWide 52HM84 52" Rear...
I have a SONY KF-WE50 rear projection tv, a few weeks ago it started to turn the pic and sound off while the green light was flashing around 30 times. After the light finished flashing both the picture and...
the green is the reboot process and is normal.
the red light is an error code indicator.
count the blinks of the red cant be 30 times (I think)
it will blink a sequence, pause, then do it again for a total of three times.
count carefully, it gives you three chances to catch the number it is blinking.
Apr 13, 2011 | Sony Projection Televisions
Problem with mitsubishi wd65737. thought the bulb was bad, bought a new bulb replaced it and now the screen doesnt want to come on. light on the front of the tv turns green, you have sound but no picture...
Lets try an error code operational checl. Unplug the tv and plug it back in. With the standby LED on press and hold the MENU and DEVICE/INPUT buttons for 5 seconds. The LED will flash a certain number of times pause for a while and blink again. Count the blinks before and after the pass, then post it here so that I can tell you what the problem is
Mar 27, 2011 | Mitsubishi WD-73827 73" HDTV DLP TV
Blinking green light and clicking noise AFTER bulb replacement
do this. press and hold device and menu button on set for 5 seconds. this will retrieve a 2 digit error code .. the led will flash the first digit and pause the flash second digit. This unit is known to have capacitor problems on the power board. getting to these capacitors involves taking alot apart. let me know error codes and we can continue troubleshooting
Jan 15, 2009 | Mitsubishi WD-52525 52" Rear Projection...
The standby light should be flashing in a repeated count with a short pause between the counts. If you could post that count here, it will give us an indication of the circuit in which a problem was found and allow us to provide solutions.
Oct 10, 2008 | Projection Televisions
KDS-R60XBR1 Sony Projection SXRD Power Issue?
how many times does it blink pause then blink again?
Dec 01, 2007 | Sony KP-41T65 41" Rear Projection...
Television won't turn on
If its a DLP tv chances are the bulb went out, double check with the manufacturer before getting as they are not cheap, around the $250 range.
Oct 26, 2007 | Sony Grand WEGA KDF-60WF655 60" Rear...
Toshiba 52HM95 52" HDTV Projection Television Logo
668 people viewed this question
Top Toshiba Projection Televisions Experts
Jaime Hernandez
Dave Naylor
Dave Naylor
Are you a Toshiba Projection Television Expert? Answer questions, earn points and help others
