Question about Moen Home
Moen float valve adjustment - Moen Home
Moen Universal Fill Valve Model M5350 problems
Some kind of crud may have goten into the fill line during installation and is blocking shutoff. The new fill valve could be defective. Something may be preventing the float from stopping the flow. The flapper may be allowing slight leakage, preventing the fill valve from shutting off and staying off. The "overflow tube" actually is the fill tube; the tank fills from the bottom up.
Feb 01, 2014 | Home
The water continues to fill the toilet tank even with the float at the very top
Sooner or later, that defective fill valve will have to be replaced.
May 05, 2017 | Moen Home
My classmate
Moen Monticello 4-inch centerset bath faucets can be repair easily with only a screwdriver and adjustable wrench. Turn the water off to the both sides of the faucets under the sink. Open both the hot and cold-water valves to alleviate any remaining pressure. Remove the handles by grasping the base of the handle and turning it counterclockwise.( This works for both lever and cross handles). Loosen the Moen faucet cartridge bonnet nut with an adjustable wrench by turning it counterclockwise to the left. Pull the stem from the faucet by hand and replace. Reinstall the bonnet nuts and handles. Turn the water back on and test the faucet for leaks. The Moen Monticello faucet comes with a limited lifetime warranty. Try calling Moen to get your replacement parts free.
Dec 09, 2010 | Moen Bathroom Sink Faucet - 4-inch...
Sensitive Temp adjustment through shower.
Pull the trim off of the valve and you will see a 1 inch diameter flat screw, unscrew that and clean it out and try it again. If rinsing it doesn't work you may need to replace it. It is called a balancing caulk.
Apr 24, 2010 | Moen 3175 Legend One Handle Shower Faucet...
Need to replace a moen tub-shower valve without tearing down a wall. Can you help? Where can I get the valve?
If you remove the handle and the fasia plate you'll see the valve in the center (make sure to turn off the supply valves first. These are located at 3:00 and 9:00 beside the valve. Then the whole assembly unscrews from the center with a large adjustable wrench or a pair of channelock pliers.
Feb 20, 2010 | Moen 3175 Legend One Handle Shower Faucet...
My(installed today) moen single handle shower valve (82910CBN) is only producing cold OR hot water. It is not mixing. What should I do to fix this?
if u still have instructions it will explain how to adjust the water -in the handle are a red and blue plastic tabs that are adjustable pull back and turn to adjust --this is the anti-scold--till u are satisfied
Nov 03, 2009 | Moen 3175 Legend One Handle Shower Faucet...
Not enough water in the toilet bowl
Adjust the floating stopper in the tank to allow more water to fill the tank
Oct 29, 2008 | American Standard Flowise 2480.216.020...
Home Logo
50 people viewed this question
Top Moen Home Experts
Mike
john h
Andrew Bugbee
Are you a Moen Home Expert? Answer questions, earn points and help others
