How to reset your tv to factory default - Televison & Video
How do u get parental passcode
Try a reset
To restore the TV to its factory default settings:
1. Press the MENU button on the remote. The on-screen menu is
displayed.
2. Use the Arrow buttons on the remote to highlight System
and press OK. The SYSTEM menu is displayed.
3. Highlight Reset & Admin and press OK. The RESET & ADMIN
menu is displayed.
4. Highlight Reset TV to Factory Defaults and press OK.
5. If you have changed the default parental control PIN, enter it
now.
The TV displays, "Select Reset to restore all TV settings to
factory defaults."
6. Highlight Reset and press OK.
7. Wait for the TV to turn off. The TV will turn back on shortly.
If you have not set a PIN, enter the
default, 0000
Feb 14, 2016 | Vizio E-Series E470I-A0 47" LED TV...
How to reset samsung led tv to factory settings?
Step 1 Press the "Menu" button on the Samsung LED TV or the remote control. Step 2
Press the up or down arrow buttons and highlight "Support." Press the "Enter" button to open the Support Menu.
Related Reading: How to Reset a Samsung DVD Recorder Step 3
Select "Self Diagnosis" and press the "Enter" button. Select the "Reset" option and press "Enter." Step 4
Enter your TV's security PIN. The default PIN is 0000; however, if you had previously changed it, enter the new PIN. Step 5
Select "Yes" to confirm your selection when the "All settings will return to factory defaults except network settings" dialog message appears on the screen. The TV powers off automatically and restores the default factory settings.
How to Reset Samsung LED TV to Factory Defaults
Nov 29, 2015 | Samsung Televison & Video
Vizio tv problems
Have you checked the TV without other devices connected to the TV.
Eg. disconnect any home theatre or speakers from the TV.
Verify with audio menu if the settngs of TV speakers is on or off ?
To adjust the audio settings:
1. Press the menu button on the remote. The on-screen menu
is displayed.
2. Use the arrow buttons on the remote to highlight audio and press ok. The AUDIO menu is displayed.
3. Use the arrow buttons to highlight the setting you wish to adjust, then press left/right arrow buttons to change the setting:
• TV speakers - Turns the built-in speakers on or off.
Lastly have you tried restoring the TV to factory default settings.
1. Press the menu button on the remote. The on-screen menu is
displayed.
2. Use the arrow buttons on the remote to highlight system
and press ok. The SYSTEM menu is displayed.
3. Highlight reset & admin and press ok. The RESET & ADMIN
menu is displayed.
4. Highlight reset TV to factory defaults and press ok.
5. If you have changed the default parental control passcode,
enter it now.
factory defaults and clear all account information."
6. Highlight reset and press ok.
afterward and the Setup App will begin
Apr 29, 2014 | Televison & Video
Cannot get AV Mode
There is a TV/VIDEO button on frond panel of the tv. When you press each time this button then you will able to access different video inputs. if the button is inactive the probably the micro switch for TV/VIDEO button may be faulty. also check the same with the remote. If its doesn't help then try to reset the tv to factory default setting. For that you need the remote. Keep in mind that when you reset the tv to factory default setting all the memorized parameters will erased(like channel memory, personal preference setting etc ). For reseting the tv to factory default do the following
1.Turn on the TV.
2.While holding down the RESET button on the
remote control, press the POWER button on the TV front panel.
The TV will turn itself off, then back on again. Release the
RESET button
Ajin
Jan 23, 2013 | Sony FD Trinitron WEGA KV-36FS120 36" TV
How do i reset a sony wega kdf55wf655 tv?
Hello
To reset this set to its factory settings:
Press when in a Menu, to reset the settings to the factory defaults. Also user to clear Labels, Channels or Favourite Channels.
To reset the TV fully to its Factory Defaults:
Turn ON the TV while Holding Down the "RESET" button on the remote control, Press the POWER button on the TV. The TV will turn itself OFF, then back ON again. Release the RESET button. OK.
Oct 08, 2011 | Televison & Video
553SV Vizio TVand forgot the passcode. Anyway to retrieve it ? Or reset to factory settings
System Info
Display the technical information including model name, version and
revision of firmware, source type, and resolution.
Reset TV Settings
Return all Picture and Audio settings to factory default. A screen will come
up to confirm your selection or to cancel it. Press Left or Right Navigation
buttons to make the selection, and then press OK to accept it.
Note: This does NOT reset the Parental Control Password.
Clear Memory (Factory Default)
Use this function to reset the TV to the default factory settings. The screen
will display a message to confirm that you want to reset the values to
factory settings. Press ? or ? to make the selection, and then press OK to
accept it.
Guided Setup
Use this function to return to the Initial Setup menu. Use this function if you
want to have a guided setup when you move your TV. Refer to Chapter 3 for more information.
Note: Previously scanned channels will be removed.
Aug 16, 2011 | Vizio P2 42 in. HD-Ready Plasma Television
Toshiba regza 37" reset defaults
Unplug the TV for some time (usually 1hr is plenty) and it should reset to factory settings.
Mar 14, 2011 | Toshiba Regza 37HL17 37 in. LCD TV
Access code to reset factory default settings
Hello:
To reset your Dell W4200 to the factory default settings, follow these steps:
  1. Press "MENU" on your remote
  2. Select "Setup" on the screen using your remote
  3. Select "Factory Reset"
If your TV is locked, you can use the default code of 3355 to unlock it.
Manual for W4200: http://support.dell.com/support/edocs/systems/W4200/
Mar 06, 2011 | Dell W4200 42 in. HD-Ready Plasma...
Tv turns on but no picutre, no menu... and then tv proceeds to turn it's self on and off, on for 10-15 seconds and then off for 2-4 seconds and then back on.... Is there some type of manual reset button on...
Hello
Just set it to factory defaults first. Setting it to cactory defaults, will reset all the items except picture settigns. Parential password will also be get resetted. You have to set it later. To reset the TV to factory defaults, do the following.
[1] Push Menu button and select Setup.
[[2] Select Reset To Defaults from the drop down window.
[3] Push OK button.
The TV will reset to factory defaults and will display it. After that it will switch ON again. Ok
Jan 29, 2011 | Panasonic TC-P50X1 50 in. Plasma HDTV
Trying to reset the settings for my toshiba model27a45
Hello
It is easy to reset your Toshiba set to factory defaults. Enter each options, ie, picutre, sound etc, and press "Reset" button on your remote control to reset each options to factory settings. The default factory settings for Video is DVD. Ok.
Jan 07, 2011 | Toshiba 27A45 27" TV
Televison & Video Logo
10 people viewed this question
Top Televison & Video Experts
Electro Med Services...
