Question about Acer Altos G540 Server (G540-50039)
When switching on continuos sound - Acer Altos G540 Server (G540-50039)
    Master:
  • 680 Answers
Stop switching on continuous sound.
Terry
Posted on Jun 21, 2015
The subwoofer das not work the wireless
I presume you have plugged in the to the power outlet and then paired it to the sound bar? If so, then this could be range or interference that's the problem.
Try the sub closer and see if it connects. If not, take it back as faulty.
Aug 17, 2014 | Audio Players & Recorders
Sound behind glove box
You migt have lose some out of your glove box and it has went be hide it
Jan 06, 2012 | 2003 Audi A4
Air conditoner dood in 1998 lincoln makes continuos clicking noise
one of the servo motors that control blend doors has stripped gears and will need to be replaced. easy to find because of the clicking noise .. if it's clicking under the hood could be low freon or a bad cycle switch
Dec 30, 2011 | 2002 Lincoln LS
HOW TO SWITCH ON THE PHONE
Hold down power button until phone turns on. It will be easier to supply advice if make/model or more information is given
Mar 03, 2011 | Cell Phones
Start up Beep Beeps ton wy is that? whenn i start
if it is a continuos repeated beep beep sound your hdd cable is loose and if it comes at boot time only it is the sound for ram testing which says ram isok
if a continuos long sound comes and pc doesnot start it is the case of ram fault try cleaning contacts of ram and ram slot with alcohol methyl or spirit or Absolute vodka works best.
Dec 25, 2010 | Intel ASUS P4BGL-VM 845GL Chipset Ultra...
I spilled water on my gas stove.. out of 5 , 3 burners are working but there is a continuos clicking of the sparky thngs attached to each burner....
Sounds like water got into one of the burner switches. It may dry out and stop or you are going to have to replace the switch. If taking apart to replace I would replace all the ones that got wet when the water spilled.
Eric
Aug 21, 2010 | Amana RanARG7302 Gas Kitchen Range
Continuos pumping
Continuos pumping is associated with waterlogged
pressurized system. To correct it, do this steps.
1. Put the power line off.
2. Drain all the water inside the pressure tank by
taking off the plug at the bottom. Then replace and
close the drain plug.
3. Open the priming port plug and fill it full with water.
Replace the priming port plug.
4. Close the flow control valve to regulate water output
5. Put the power back on, and start the pump.
6, Slowly open the flow control valve until the water
stabilizes at 20 or 30 psi at the pressure gage..
7. Set the pressure switch to stop at 40 psi and
start at 20 or 30 psi.
This will solve your problem.
Oct 15, 2009 | Plumbing
Acer Altos G540 Server (G540-50039) Logo
228 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
