Question about Jabra Radio Communications
CANNOT CHARGE JABRA BLUETOOTH HEADSET
THERE IS A BLINKING OF RED LIGHT BUT CANT CHARGE
SOURCE: Not sure if Jabra bluetooth headset or charger that not working
I had the same problem, called support, they told me battery is defective or too old and doesn't accept the charge. Battery in a headset is hardwired and can't be replaced, so the whole thing is trash :(
Posted on Jul 10, 2007
SOURCE: Jabra BT350 Bluetooth Headset
This is what I did:
1. open the headset by following these steps:
http://www.instructables.com/id/Jabra-BT-350-Disassembly-and-Repair/
2. measure the voltage of the battery. If it is too low, the internal charger circuit may not like it. Mine was 2.6v.
3. Charge the battery "manually" by connecting to 3 serially connected rechargeable batteries (final voltage should be around 3.7v). Three NiMH AA batteries are fine.
4. Reassemble and hope your headset is back to business.
Posted on May 19, 2008
  • 3 Answers
SOURCE: Jabra BT2010 Bluetooth Headset help
Hey guys, hold the button pressed for 6 sec. until led is solid. then search bluetooth devices on phone click on Bluetooth headset insert '0000' press OK now it should work, or check http://jabra.com for compatibility. Best wishes, htmlfreak.
Posted on Nov 14, 2008
jmgldsmth
  • 1889 Answers
SOURCE: The Motorola H800 bluetooth headset doesn't charge or turn on. While charging it just displays blinking green light
open and, replace the rechargeable batteries
Posted on May 29, 2009
SOURCE: Jabra JX10 Bluetooth doesn't/won't charge
Not sure if this is a solution or if it occurred by chance. Like many on here, I put my Jabra JX10 away for a few months while not using it. The time come for me to need it once again and found that it was dead. Made an attempt to charge the unit with negative results. The unit would only show a green "charged" LED indicator as if the unit was fully charged. I tried plugging the unit into the charger multiple times, and took the cradle out of the loop and just used the AC cord alone. Still with the same results. I pulled the outside cover off (slowly), to be sure not to break the small fragile tabs that hold it in place. The battery takes up majority of the space. Removed the battery but DID NOT disconnect from unit. Plugged the charge cord into the unit and immediately got a red LED charging indicator. While charging, placed the battery back inside and put the outside cover back on. The unit continued to charge for a little over an hour before the green LED "charged" indicator came on. I used the unit throughout the day to test it with no problems. Not sure what removing the battery from unit did, especially when it was not disconnected, but it worked. I hope to see similar results.
Posted on Jun 09, 2009
Jabra wave battery suddenly won't charge
The battery may be shot and incapable of charging. The red light could be merely indicating that the charger is working.
Jan 13, 2014 | Jabra Wave Bluetooth Headset
Hello my jabra wont light up when it is fullcharge? can you help me?
The headset light turns off when it is at full charge. If it is not charged yet it will be illuminated red.
Found this in the online manual:
http://img5.jabra.com/sites/Jabra/GNimages/Products/Stone_Manual_EN_NA_8404.pdf
Feb 28, 2011 | Jabra Stone Bluetooth Headset
I have 2630 nokia phone i use my jabra bt 2070 for this one and then i bought a new phone 6120 nokia but i cant use the headset on it every time i search for jabra device my phone cant find it
First turn ON your bluetooth on phone, then hold on/off button to turn ON Jabra headset for 5 SECONDS, then vill light hold ON (NO BLINKING) and then find it on your mobile phone....
Hi from Serbia ;)
Nov 23, 2010 | Jabra BT125 Headset
How do I put Jabra BT 135 in Discovery mode?
Turn the device on and continue holding the power on button until the light stays solid. That puts it in discovery mode.
Pair it with your device.
It will probably also ask you for the password to the bluetooth headset (mine did). The default is 0000.
Jun 30, 2009 | Jabra Bluetooth Headset with Adjustable...
Making jabra bluetooth headset work with motorola v9 phone
have you made the headset viewable by while its off holding down the power button untill a constant red light comes on. then searching for the headset
Mar 21, 2009 | Jabra BT150 Wireless Headset
Jabra bt2020 will not charge/function
I don't know how long you have had the headset but it sounds like it isn't holding a charge.  Contact Jabra to find out what the warranty is on the headset.
Nov 12, 2008 | Jabra BT2020 Bluetooth Headset
Steady Red Light
From the sounds of this.. It's all due to bad keying of the polarized charging plug. The solid red light PROBABLY means you're battery is pretty darn dead. It'll need a new battery(not worth the cost imho. get a new jabra, and be happy once again) At a certain low voltage, the red light starts blinking. when it drops below the preset threshold, it will shut off completely. If it sits too long at this discharged rate, the battry WILL self-terminate. If the voltage drops below a certain level, it's ruined. Also note, most Li-ion cells will only last a few years. 2-3 years of "full power" is usual. Mine's 2 years old(steady usage), and showing signs of it's age.
"My red light won't go off even though I charged it all night.
Also, a small piece of plastic came off the charge opening. I don't know if this is will pose a problem to the use of the Jabra BT150."
This is probably the most telling bit of information. It means you DID plug the charger in upside down. It will NEVER charge in that configuration, as it is supplying power to the completely wrong pins. If the battery was good to start with, it shouldn't hurt the headset, but never know. I have accidentily plugged it in backwards for a couple min before noticing, with no ill efect, but YMMV.
"Doesn't anyone from the Jabra manufacturer check this site?"
NO (especially not for discontinued products)
Oct 05, 2007 | Jabra BT150 Wireless Headset
May 26, 2007 | Jabra BT250 Consumer Headset
Radio Communications Logo
15 people viewed this question
Top Jabra Radio Communications Experts
TO Lady
Greg Cann
Greg Cann
Michael Vincent Cruz
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
