Question about Minn Kota Maxxum 70 Freshwater Bow Mount Trolling Motor
Trolling motor runsor awhile then stops just clicks when i hit the foot pedal couple minutes later it works agai
5 Suggested Answers
  • 10 Answers
SOURCE: somethings come loose in the head of the trolling
http://www.northlandmarine.com/MinnKotaQuickRef.htm
Posted on May 02, 2009
  • 3 Answers
SOURCE: Minn Kota power drive trolling motor will not
There is a good chance that he control board is bad. This is a common problem with these units. I have replaced my control board twice.. When the control board goes out, the some function of the unit will not work correctly while other functions work fine. The first time mine went out, the prop motor would not work. The last time the board went out, the unit would only steer right.
Posted on Jun 04, 2009
SOURCE: Trolling motor doens't work
I have a trolling motor and can't seem to get it to come on. I seen it work when I got the boat. But now it won't come on.
Posted on Aug 09, 2009
  • 8 Answers
SOURCE: On a Minn Kota All Terrain trolling motor, what
You should only use the MOM (or momentary) setting when using the push button the foot pedal. Con will just keep the motor running and your foot control will only allow for direction and speed!
Posted on Sep 07, 2009
My trolling motor stopped working suddenly. It is a 96 motorguide 56. It is completely charged. What else do I check. I check 5 fuses by the battery as well.
First you need to check to see if power is getting to the motor. If power is not getting to the motor, then check the battery. If you are getting power to the motor, then troubleshoot starting with checking to see if power is getting to the foot pedal. From there check the switches, and make sure they all have power. If they do, then most likely it is the brushes which could be worn on the powerhead itself.
Jun 02, 2011 | MotorGuide FW40 FB 42" 12V FLXMT Trolling...
How do you reset remote for w75 wireless trolling motor
Its very easy:
Reprogramming the Wireless Foot Pedal or RemoteNOTE: This activation procedure applies to the foot pedal and remote.
IMPORTANT: To activate multiple foot pedals or remotes, the motor must be unplugged from the power source and then plugged
back into the power source between activating each control device.
1. Unplug the battery cables from the power source. Wait 30 seconds and then plug the motor into the power source.
2. In less than ten seconds, press and hold the "+" and "-" buttons on either the handheld remote or the foot pedal controller
simultaneously.
May 07, 2011 | MotorGuide STANDARD MOTOR REPLACEMENT...
On a Minn Kota All Terrain trolling motor, what should the MOM/OFF/CON switch be set to when using the foot pedal manually?
Jul 06, 2009 | Minn Kota Maxxum 70 Freshwater Bow Mount...
Foot pedal on Motorguide is out of time with steering...
There should be a couple of allen screws on the shaft that you can loosen, which should allow you to swing the motor head in the direction you want it to be pointing for the desired pedal position. Tighten and carry on.
Jun 01, 2009 | MotorGuide STANDARD MOTOR REPLACEMENT...
Trolling motor doesnt work?
Most trolling motors have in-line breakers, I would start there & see if one went bad, then check the wiring under the foot pedal for broken or corroded contacts, then you will have to trace wires & make sure everything is in order starting at the trolling motor plug.
May 24, 2009 | Boating
Minn Kota power drive trolling motor will not steer to the right **** huard
It is the circuit board in the foot pedal. You will have to replace the whole foot pedal. This is a very poor design. The thin plastic which protects the contacts gets a little hole which allows water to enter and consequently the contacts corrode. Has happened to me two times in past four years. It might be OK for operation in a dirt-free water-free environment; but not under actual fishing conditions.
Apr 29, 2009 | Minn Kota Maxxum 55 Freshwater Bow Mount...
Motor won't run
Look at the red indicator arrow when you hit the foot pedal. If it lights up, the motor should run. If not, inspect the splices under the top cover on the shaft. They will stop the motor if corroded or burnt.
Sep 02, 2008 | Boating
Minn Kota Maxxum 70 Freshwater Bow Mount Trolling Motor Logo
44 people viewed this question
Top Minn Kota Boating Experts
Mike Marcotte
Mike Marcotte
Andrew Taylor
Andrew Taylor
Colin Stickland
Colin Stickland
Are you a Minn Kota Boating Expert? Answer questions, earn points and help others
