Rdr hx780 My Sony HX780 will not respond to the command on the remote There is a number 1 on the front panel near the clock.I am sure this is stopping a number of commands including system menu,syncro rec and a number of other functions can you help Ian
  • 79 Answers
SOURCE: Sony Video Cassette Recorder/DVD Recorder
Hold the "Enter" button and press number 1 on the keypad simultaneously for more than 5 seconds. This takes you back to the "Settings" screen with the "Settings" button, change the control back to DVD 3, and reverse the setting in the remote by pressing "Enter" and the number 3 this time. Remember to hold them down for more than 5 seconds.
Hope this helps
Thanks for reading!
Posted on May 02, 2008
SOURCE: connecting and recording sony hdtv, rdr-hx780 recorder,sony dream system
I have the same system, except for the TV, I have a project (that part doesn't matter).
From your Sat. go straight to your AV receiver
Again from you Sat. (all of the AV outputs are all live), go out from either 1 or 2 and go to your recorder Line 1 in.
From you AV receiver go to your TV.
All you have to do is hit record and you will record whichever channel you are on. I am having difficulty getting it set up as a PVR, but will figure it out sooner or later.
Hope this helped.
Posted on Feb 24, 2009
SOURCE: Not responding to any input commands.
Don't worry. I unplugged it and left it for a number of minutes and then tried it again. It now works fine.
Posted on Mar 24, 2009
SOURCE: Command mode change disabled remote
According to Sony, if you turn the power on and hold the Enter key and the #1 key down together for at least 3 seconds, everything will default back to factory settings.
Mike
Posted on Apr 03, 2009
SOURCE: Connecting my laptop to DVD recorder and recording onto the recor
You FIRST need a way to get the Signal, INTO the laptop, you need to get a USB to TV/Video Dongle, Now using this and the software that came with it, as well as other software, You Hook up the OUTPUT from the DVD Player, to the Video Input on the USB Dongle, Either, Component (Best) or Composite, (OK) Video, and AV Audio, and set to "Record" on the PC, and "Play" the DVD and then the PC will "Record" the incoming signal from, the DVD player, to the HDD in the PC. Once digitised, and saved it can be manipulated, any way you want.
Now if you want to do the REVERSE IE: Take a signal FROM the PC, to the DVD, then you simply setup the DVD as a Second monitor, use a TV to set it all up, once it is all working on the Laptop and TV, simply swing the Output, away from the TV's Input, to the DVD's Input,and select record, the PC, will then output whatever, to the screen, and whatever is displayed on-screen, will be recorded by the DVD's hard drive.
You First though must setup the PC to have multiple monitors, it is best to get the most up to date drivers and install them in the PC. FIRST. Go to this MS link below it shows you how to set u,setup as CLONE mode, I think will be best, also don't set initial resolution too high to start, set it to say 800x600 32 bit, to start, and work up, until your TV complains and stop. As related once setup, swing the PC's output to the DVD, and record.
http://support.microsoft.com/kb/307873
Posted on May 08, 2010
Hi I have a sony dvd recorder gx360 that will not work with my remote. When try, it displays dvd 2 on front of the panel. I think its locked, how do I unlock it?
You have got the wrong remote code!
I have copied this from the manual....
Set the command mode for the remote so it matches the command mode for the recorder you set above. Follow the steps below to set the command mode on the remote. A Hold down ENTER. B While holding down ENTER, enter the command mode code number using the number buttons. Command Mode DVD1 - number button 1 DVD2 - number button 2 DVD3 - number button 3 C Hold down both the number buttons and ENTER at the same time for more than three seconds.
The correct "default" for the remote is DVD3!
The full manual is available free on this website:
http://www.manualslib.com/manual/228795/Sony-Rdr-Gx360.html?page=23#manual
Mar 08, 2016 | Sony Televison & Video
Request instrtuctions for setting Sony RDRVX560 clock
Do you mean the RDR-VX560 DVD recorder/VCR combo? With the original remote for the recorder, you need to press System Menu (which is the left button on the row of large buttons above the arrow key circle). Then use the arrow keys to select Setup, press Enter and then select Clock Set. (Press Stop before attempting to access the System Menu. Then make sure that the remote is in the same mode as the recorder. The Command Mode for the recorder is set from the system menu as well. The remote can be reset by pressing and holding Enter, then press and hold 1, 2, or 3. Hold both the enter and the digit listed for 3+ seconds.)
To provide more help, I need more information about your Digital Stream remote. I'm not sure if there is a button that will match the System Menu and the Command Mode on your remote.
Remotes.com has a replacement original remote: http://www.remotes.com/store/sony/rdrvx560.html . Other sites may also have the remote for sale.
The documentation for the unit is available from Sony support: http://esupport.sony.com/US/perl/model-home.pl?mdl=RDRVX560&template_id=1&region_id=1&tab=manuals#/manualsTab . The direct link to the manual is http://www.docs.sony.com/release/RDRVX560_EN_ES.pdf .
I hope this helps.
Dec 05, 2011 | Audio Players & Recorders
Need 3 digit code for controlling sony rdr-gx7 dvd recorder with my time warner cable remote.
This is a common problem for the Sony RDR-GX7 dvd recorder.
It seems to occur with various remotes (DirectTV, Bell ExpressVu or in your case, the time warner cable remote).
In most cases, the problem can be solved by using a different remote frequency from the system menu as follows:
Insert a dvd and make sure it is not playing (stopped).
Enter the System Menu then / Setup / Options / Command Mode (this can be done from the access panel on the front of the unit). There are 3 possible values, (DVD1, 2 or 3), try changing it.
Then enter one of the suggested codes for your Warner remote (in my case, for Bell ExpressVu I selected the DVD1 command mode
and I used 883 as the 3-digit code. The up and down arrows are not functional with this code but I bypass this problem by entering the menu item number. Good luck!
Feb 14, 2010 | Sony RDR-GX7 DVD Recorder
I have a Sony DCD Recorder (RDR-HX780) and Sony 40" 1080P LCD TV (KDL40S510) "tripple checked lines and HD cable connection." Problem (which occurs randomly and is anoying): When switching to DVR or...
Try this: got to www.sony.com mouse over "support" then click on "drivers/software" enter your model #(s) and then you can check for firmware updates, the symptoms that you list, unfortunently are somewhat common when connected via HDMI cables.
Check for updates on both product that you list.
Good luck !
Jan 31, 2010 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Can't watch show while recording
It doesn't do. No can do.Whatever channel you SWITCH ON TO AFTER you started recording be it timer or manual GETS recorded. Whether you switch onto inputs on your TV remote or cable remote IS the one getting recorded.
Jun 15, 2017 | Sony Televison & Video
Recording from TV issues: Channel selection...Line 1, 2 or 3???
get it fixed in a shop.
when things break do that.
this dc4000 is an old device.
get the service manual on it ? yet?
or why not upgrade ,
what way to you watch TV, (sources)
antenna
Cable
SAT
what?
Nov 06, 2017 | HP dc4000
Connecting and recording sony hdtv, rdr-hx780 recorder,sony dream system
Hope this helped.
Oct 20, 2008 | Sony RDR-GX300 DVD Recorder
CANT FIGURE OUT HOW TO RECORD OFF AN 'AV' SETTING
The method is the same as for TV channels; select the input (i.e. view the desired channel), then press the record button. AV1 and AV2 usually are at the end of the channel list, and can be found by pressing the channel UP or DOWN buttons.
Aug 13, 2008 | Sony RDR-GX300 DVD Recorder
Dvd recorder rdr-hxd860
press stop button then the power button together the player will go off. put it on again the remote should work.
Mar 15, 2008 | Sony RDR-HXD860 DVD Recorder/HDD Recorder
Televison & Video Logo
21 people viewed this question
Top Televison & Video Experts
