Question about PetGuys Van Ness Pureness Cat Pan Liners Large 12ct L2
How to install these cat pan liners
Can't figure out how these liners open
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 39 Answers
I hate those liners, the cat usually moves them around or scratches holes in them. I use World Best Cat litter and never have to throw out the litter. It clumps well and never drops to the bottom like a lot of other litter.
Posted on Apr 26, 2016
Where is the fuel filter located on a 2007 6.7L dodge ram 3500 diesel pickup truck
Removal and Installation of the Cummins 6.7L Fuel Filter/Water Separator Mopar P/N 0518341AA
Job Time: 15 minutes
Tools needed:
5/16 Nut driver or Ratchet and socket
1/2" Drive Ratchet with extension for filter removal
or
Strap wrench
pan or jar for Fuel Drain
Motor oil
Got out there today and changed the Fuel filter and here's how I did it.
From the drivers side of the truck remove the (8) 5/16" screws from the fender liner and there's also a clamp attached to the fender liner by the brake fittings that needs to be pushed out and then remove the liner exposing the filter.
Wipe off all the dirt and junk from the filter, disconnect the Water In Fuel
(WIF) connector from the bottom of the filter and then place a drain pan below the drain valve and then open the drain valve two revolutions to drain the fuel from the filter. ( I used a mason jar stolen from the Queen so I could look at the drained fuel)
Now you have two ways of removing the Fuel Filter. You can either use a 1/2" drive ratchet inserted in the the bottom of the filter (You can't turn the filter the wrong way because the opening for the ratchet will only allow you to remove the filter this way.) or you can use an oil filter or strap wrench as I did.
Make sure when you remove the old filter to remove the drain hose to use on the new filter and you'll also have to reach up into the fuel filterhead/Housing assembly and remove the old end seal but it can be thrown away.
Installation
Install the yellow o ring that comes with the Filter and make sure the above end seal is installed.
Lubricate the O-Ring with clean engine oil. (Do not pre fill the filter with fuel or you'll toast your fuel pump.)
Install the filter until you feel it contact the head and then turn 1/2 rotation more.
Install the WIF connector and drain hose.
Prime the engine.
1. Turn the key to the RUN position but don't try to start the engine for 20 seconds.
2. Crank the engine for 1 to 2 seconds. If the engine does
not start, then release the key or starter button back to the
RUN position (do not turn the key back to the OFF
position). The electric fuel transfer pump will continue to
run and purge air from the system for about 20 seconds.
After 20 seconds, attempt to start the engine again.
3. Repeat the procedure if the engine does not start.
4. Start the engine using the Normal Starting Procedure and check for leaks.
Reinsert the wire clamp into the fender liner and install the fender liner with the (8) 5/16 bolts removed earlier and Congrats you're done.
I took the filter apart and here's what my filter looked like after only 8800 miles. So when the Master Tech I bought lunch for so I could pick his brain told me that the best advice he could give any Cummins owner is to change the fuel filter at least every 10,000 miles he wasn't just blowing smoke and that was the best $10.00 I've spent in a long time.
Jul 27, 2017 | Dodge Cars & Trucks
Stila Limited Edition La Quill Precision Eye Liner Brush price in india ?
Bold eye liner looks, from tight lines to cat eyes, have never been so easy to achieve. This eyeliner brush is designed to dispense liquid eye liner evenly and precisely in a thin or bold line. Just dip it into the unique, cushion sponge soaked in color (sold separately), and draw across the lid smoothly. The brush acts like a calligraphy pen, depositing the formula effortlessly for chic precise lines.
STILA COSMETICS INDIA
Jul 14, 2016 | Stila Health & Beauty
When rake cleans makes loud noise
Open the left side of the box and you'll see a white plastic part covering the hole. Get scissors and cut it out. The metal piece moving the rake was dragging on the plastic and so I cut it out of mine and now it's back to normal !
Jan 02, 2016 | LitterMaid Mega Self-Clean Cat Litter Pan
I live in Republic of Ireland and require a replacement liner for a 0.5l flask. Where can I find this. Are liners still available or only new vacuum flasks
Vacuum flask liners have faded from the general scene
However if you try the specialist cooking tensile shops ( shops that handle pots, pans knives and all lines for the kitchen) you may get a shop that can still source the liner for you
Aug 29, 2015 | Cars & Trucks
863 bobcat getting oil in fuel
Internal leak in lift pump. Leaks fuel into cam to oil pan.
Jun 21, 2012 | Bruder Cat Skid Steer Loader
When slow roasting, do I need to keep the liner pan in or can I just roast with the base roaster? 16q roaster
Hi chef wendy...
Leave the liner pan in it will help crisp/brown your meats ...it will also aid in clean up later...
Please take time to rate me
Sep 23, 2011 | Rival 18 Qt Roaster Oven with Buffet...
Do you add water to the bottom pan before you state cooking with it?
Yes, you need to add a couple of cups of water first... more depending on what you are cooking...if the meat you are cooking will make its own juice then you need not add any more...also if you are cooking at a higher temp then like 350 then you may need more water as it will boil off...
heatman101
Apr 23, 2011 | Rival 18 Qt Roaster Oven with Buffet...
96 chevy tahoe, passenger side and rear cargo carpet is wet
sounds like the air conditioning drain for condensation is plugged
Apr 24, 2009 | 1996 Chevrolet Tahoe
I have a whirlpool side by side refrigerator that is leaking and we can not figure out where the leak is. the pan is full of water.
empty out the freezer and remove the back liner of the freezer compartment usually phillips screws. In the back you will see the freezer coils along with a defrost element. Below these two items u will see a drip tray that collects water from the coils on defrost cycle, in the center of the pan will be a drain hole that connects to a hose that leads to a pan under the refrigerator.Normally the water is collected there and evaporated. The hole in the tray in the freezer is clogged. Thaw it and clean it until you can pour water in it and it goes to the pan down below. please rate me
Jan 08, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
BAD INSTALLATION ON LG 4.00 WM2496H*M TROMM WASHER.!!!!!!!!!!!
The storage bottoms are ok in quality, and do give you more space. They are built for just the use of the washer/dryer they are made for, so they will hold up. Best idea, is when you get your base units, tell the store you want a new pan liner installed as well. You may also want to tell the store that the installation personel who set up your new machine broke the last one and you want some sort of credit, free delivery, new pan liner, discount, etc. All stores (Home Depot, Lowes, Sears, Ace) that carry plumbing products, appliances, etc, will carry a heavy duty floor pan for your unit. Good luck and let me know if you need further information. Jim
Nov 04, 2007 | LG WM-2277HW Front Load Washer
PetGuys Van Ness Pureness Cat Pan Liners Large 12ct L2 Logo
360 people viewed this question
Top PetGuys Cats Experts
Tom Chichester
Ruth summersides
RANDY POWERS
Level 1 Expert
Are you a PetGuys Cat Expert? Answer questions, earn points and help others
