Question about Flip Video Flip UltraHD 8GB High Definition Camcorder
Won't hold battery charge or work with batteries
Battery won t hold charge
If your battery does not hold charge, and you don't want to buy a replacement, then there is not much can do other than to keep using your laptop with the charger. All batteries have a time life span.
Jun 19, 2013 | Acer Computers & Internet
Nwz-w262 battery will not hold charge
If the rechargeable battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Nov 14, 2012 | Audio Players & Recorders
Will not hold charge
Nov 02, 2012 | Kodak EasyShare DX6440 Digital Camera
My daughter 2004 Kia won't hold a battery charge.
voltage regulator. it may be in the alternator, or remote mounted. ((the alternator can be charging, but if voltage regulator is'nt working then it won't allow voltage to get back to the battery to keep it charged
Sep 07, 2012 | Cars & Trucks
My aspire 5100 wont hold charge without charger
If thelaptop battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Aug 05, 2012 | Acer Aspire 5100 Notebook
Sandisk mp3 not resonding or holding charge
If the recharageable battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to an unacceptablecharge level then the battery needs to be replaced.
Jun 27, 2012 | Audio Players & Recorders
Laptop Battery Won T Charge on a laptop dell inspiron 1525
Battery could be dead and won't hold another charge. Batteries only last for so long until you have to replace them. If you laptop is ok with the AC Adapter & Power Cord meaning it boots and allows you to work in windows, then the battery is definitely dead.
Mar 19, 2012 | Dell Computers & Internet
Htc evo 4g shift won't charge or turn on and I
Have you attempted taking the battery out and while the battery is out holding down the power button for a few seconds? If this doesn't work,
First test your charger to ensure proper charging. Clean charging ports. Remove battery and clean brass contacts with alcohol and q-tip
Jan 12, 2012 | Lands Phones
Sony vaio vgn-nr285E battery won't hold a charge
Dec 03, 2011 | Sony VAIO VGN-NR285E/T Laptop
It worked for a while and I was able to recharge it, but now it won't hold a charge.
If the cell phone battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Sep 01, 2011 | Cell Phones
Flip Video Flip UltraHD 8GB   High Definition Camcorder Logo
24 people viewed this question
Top Flip Video Video Cameras Experts
Tom Chichester
ray gallant
Are you a Flip Video Video Camera Expert? Answer questions, earn points and help others
