Question about Vivitek Office Equipment & Supplies
Vivitek projector not working - Vivitek Office Equipment & Supplies
Change module on Vivitek projector
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Apr 05, 2016 | Vivitek Lamp for H5085 Projector
Where can I get a replacement dmd chip for my vivitek d837? i can't find a product number or anything!
Our company supply the DMD chip
the unit price is USD200 (not including the freight cost)
the freight cost is USD25--USD30
any questions, feel free to contact me
have a nice day!
Jerry,Lampdeng Limited
Mar 10, 2014 | Vivitek Corporation Vivitek D837 DLP...
Circuit manual of power supply of vivitek d832mx
These are not available except for payment but you can get technical help for your fault from the link below; http://www.vivitek.in/For fault on SMPS get some tips from the link below:
http://www.fixya.com/support/r5826301-working_switch_mode_power_supplies
Nov 30, 2011 | Vivitek D832MX Projector
Hi--my new Vivitek D5 projector is not connecting to my Macbook. I have a mini DVI converter attached to a vga to DVI video adapter, but the projector can't "find" the source.
Please check your port with another source to confirm the working of the PC. Now also try to see if the projector connects with another PC. This will confirm the culprit as it is possible that there is a signal mismatch to the source input and hence not detected.
Oct 14, 2011 | Vivitek D511 3D Projector
How do we connect the projector to the pc?
Hook up using the S-Video port, the VGA port, RCA port, or the RS-232 port. The USB port is not used for input on at least some of the Viviteks as per Vivitek Service"The USB port is not in input port. This is used for service only. Please use another input port such as RGB input. Regards, Vivitek Customer Service"
Hope this helps.
Aug 06, 2011 | Vivitek D825MS Projector
Source not found I am using an Acer Aspire One
Make sure you are using ports other than the USB port. Vivitek Service indicates that at least some of their projectors do not use the USB port for input. "The USB port is not in input port. This is used for service only. Please use another input port such as RGB input. Regards, Vivitek Customer Service
Hope this helps.
May 16, 2011 | Vivitek D825MS Projector
We are a conference facility with a large projection screen we have recently bought a Vivitek projector and we are having problems making the picture small enouhg to fit on our Theatre screen the further...
You can go to the Vivitek website and they have a handy distance calculator to help you know the correct distance to place your projector from the screen to achieve an appropriate size.
http://www.vivitekusa.com/calculator/calculator.html
Mar 07, 2011 | Vivitek D945VX Projector
I am needing to verify if this projector allows for a widescreen image and what type of bulb does it use?
hi,
vivitek D510 supports 16:9 ( wide screen) format also. it uses 180w projector lamp.
ok
Dec 27, 2010 | Vivitek D510 Projector
37 people viewed this question
Top Vivitek Office Equipment & Supplies Experts
Miguel Luiz Martins
Are you a Vivitek Office Equipment and Supply Expert? Answer questions, earn points and help others
