Question about Kenmore Progressive Bagless Upright with Inteli-Clean SystemVacuum
Kenmore vac hub - Kenmore Progressive Bagless Upright with Inteli-Clean SystemVacuum
How do I change the belt on Kenmore vac model # 116 32213200?
Your model has two levers on top of the nozzle housing that you slide to allow you to remove the cover to gain access to the belt and brush roll.
Dec 21, 2014 | Kenmore Vacuums
We just moved in - the house is about 9 years old. I have a Eureka Mega Boss central vac - looks like model # is CV20220. 12.4 amps, 120 volts. Can't figure out what type of bags I need. Can you...
Well, for this unit you will need any of the following bags,
Eureka genuine Part# 90610
Eureka replacement (Central vac bag)
another genuine bag style called CV-1, and/or CV-2
Kenmore Central vac bags
Most of the bags there are available at your local vacuum shop, and sometimes even Sears. The Kenmore central vac bag is, can and will fit your Eureka Mega Boss. Prices range on these bags anywhere from $12-$20 for packages of 3. Generally you will replace a bag once every 3-4 months.
Good luck,
Mark
Nov 10, 2010 | Vacuums
Which new model replaces this model #11622612200
Ron, Kenmore assigns model numbers pretty much sequentially as they receive new inventory. There is no cross reference anywhere in the industry for their product except in their catalog. If you want to compare features you must do it that way to find a similar vac. If you are very luck you may find an experience Sales rep at Sears.
If this is a Kenmore canister , as they age the hose and wheels and wand connections break down. For a better designed or improved vac, look at a professional vac shop and look at all the spots which broke down on your old one. If there are feateures you like make note of them too and you should find similar features on a pro brand or at Sears.
One more thing, don't buy a new vac based on amperage. Amperage is consumption of power NOT output but its a big deal to advertise that way. it's only a numbers game. A 12 AMP vac motor with its suction fans removed is still a 12 amp motor, it just has no suction. Anyone who tries to sell you a vac based on amperage does not know there business. Best of luck. For a lighter easier running vac,better design look at Sebo , Miele, etc, as well. The Europeans are far ahead in design and filtration and durability
Oct 27, 2009 | Kenmore Vacuums
I have a Kenmore Canister Vac. I need to replace
Try forcing a flathead screwdriver between the flange (tab) on the hose collar and the tab on the swivel assembly itself, taking care not to gouge the wires. Saw one solution where they used 2 screwdrivers simultaneously; couldn't do that, but did loosen one side at a time.
Sep 24, 2009 | Kenmore Vacuums
The beater of my kenmore vacuum won't turn on - the primary light goes on but none of the sensor lights go on.
Kenmore vacs generally have three male contacts at the machine end.Internally when the hoses swivels these contacts run on three brass rings which can also get dirty due to proximity to dirt. They can get dirty or dirt can fall into the corresponding female socket where the hose meets the vac. If you have just changed the bag inspect these connections near the intake port on the vac.
The working LED means you have a partial connection. Also try wiggling and twisting gently at the handle of the hose and where the wand connects to the hose and the power head elbow... you have 4 connections between vac and head
Sep 06, 2009 | Kenmore 22812 Bagged Canister Vacuum
How do you take the canopy cover off of a kenmore cannister vac?
Flip the vac upside down and look for two screws from the underside near the wheels. If they are not visible you will need to remove hidden screws from above by prying gently at the back of the vac where the body panels meet at the bumper. Also look for two vertical screws in the bag area.
Sep 02, 2009 | Kenmore Vacuums
Kenmore vac has no suction in hose or base
Find a Shop that sells these & get them to show you.how it works.
Apr 08, 2009 | Kenmore 31912 Progressive Direct Drive...
Open power cord housing on kenmore 116 vac
You can go to the Sears Parts Direct website and type in your Model number. It will return both an exploded view and parts list, with pricing for replacement parts. You can also order from them, and they can tell you stock status as well.
Jan 15, 2009 | Kenmore 25512/ 25513 Progressive Canister...
Druabrand canister vac
I was looking for a Hose for the vac, and found one at good will store that will work. Others wanted more for the hose than the vac was worth.
Nov 05, 2008 | Kenmore 22612 Bagged Canister Vacuum
Kenmore central Vac - where to connect low voltage wires?
Mosy central vacs have 2 spades close together that stick out on the side, usually where the circuit breaker and auto/manual switch is. This is where you plug the low voltage wires into.
May 13, 2008 | Vacuums
Kenmore Progressive Bagless Upright with Inteli-Clean SystemVacuum Logo
15 people viewed this question
Top Kenmore Vacuums Experts
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
