Question about Harley Davidson Lamp Heritage Sound N Light Effects
No sound Won't make sound
My powermore engine won" turnover. Starter sounds scratchy
First make sure you battery is up to full charge then you may have to pull the starter and take it to a repair shop and get it checked out. Sounds like you need a replacement. Also check battery cable both end and make sure they are clean and tight before doing anything.
Apr 25, 2016 | Garden
Stove burners won't light
sounds like the igniter is faulty try a local h/ware or plumbing shop for a new piezo ignition
Feb 02, 2013 | Hotpoint RGA524 Gas Kitchen Range
Won't drain and won't spin ,makes a clicking sound
sound as though the drain pump has something hitting the impeller making the clicking noise,and the filter basket next to the pump is blocked by debris and not letting it drain
Sep 01, 2012 | Maytag MAH6700AWW Neptune Front-Load...
Perego Choo Choo will make noise, but won't move
the sounds are run off of a different battery source, check the battery under the seat and make sure that its connected
Apr 06, 2012 | Peg Perego Choo Choo Express Train Set
95 jeep wrangler 4.0,won,t start,dash lites won,t go on.replaced starter relay.still won,t turn over.
Try checking the battery and battery leads. Sounds as though you have a bad battery. Also check your fuses under the hood and dash.
Jun 03, 2011 | 1995 Jeep Wrangler
Car won.t start makes a clicking sound
this is always the starter solenoid that does this, replace the starter solenoid.
Apr 12, 2009 | 1997 Saab 900
Automatic won`t change above second gear
sounds like the selector box at fault but change the auto oil and filter with some treatment and this should solve youre problem
Feb 19, 2009 | Nissan Altima Cars & Trucks
Harley Davidson Lamp Heritage Sound N Light Effects Logo
Top Harley Davidson Toys Experts
Tre Elkins
ray gallant
Mark McGinty
Mark McGinty
Are you a Harley Davidson Toy Expert? Answer questions, earn points and help others
