Question about Bosch B36IT71SNS (20 cu ft) Bottom Freezer French Door Refrigerator
I can't find the serial numbers on bosch B26FT70SNS fridge
My fridge freezes all my food. The sticker with the serial number must have fell off and i can't find anyone to diagnosis the problem. How do i find help or repair it?
abhishek33
  • 1239 Answers
SOURCE: the bottom of my fridge is frozen alonge with the fridge food
Hi sir
it bis thgermostat problem,(heating element),,,so the heating is not done properly by thermostat,,so u should check iot,,,
thank u,,,please rate it,.,,,
Posted on Jun 30, 2009
Toad tool
  • 33 Answers
SOURCE: bosch fridge keeps freezing all food
put some beers in there
Posted on Dec 15, 2009
SOURCE: I have lost my instuctions for this Bosch
Problem solved went to Currys and looked at the instruction book in there!!!!!!!
Posted on Jan 11, 2010
candgbabu
  • 53 Answers
SOURCE: Find the serial number on a bosch fridge
check the back bottom side or bottom front panel.
Posted on Mar 29, 2011
imufo2
  • 3773 Answers
SOURCE: bosch fridge freezer /fridge wont get cold qute
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Sounds like the cold control has stuck . Unplug the two wires from the cold control and plug them together. Turn one wire over and plug it into the other. away from the cold control.
The cold control is the knob in the ref that turns it on and off and has numbers on it. (Thermostat)
If it runs then that cold control (Thernostat) is the problem.
If that doesn't work DO THIS:
The relay on the compressor may need replaced
A relay starts the compressor with a higher voltage and then quickly kicks out
Thats what is happening with yours
Its best for a tech to replace The relay but you can do it
Take your model number to your Local Appliance parts store they will have a diagram
showing you how to install the relay. Its called a hard start relay
also try hooking the two wires together on the cold control to route around the cold control.
Be sure the BACK COVER is in place and hasnt been accidently removed.
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
MORE TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS____
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Most overlooked dryer energy saving problem EVER!
http://www.fixya.com/support/r5739846-most_overlooked_dryer_energy_savingr
REF THERMOMETERS TIPS
http://www.fixya.com/support/r10177561-second_biggest_refrigerator_energy
Thank you for using fixya
Leo Ponder
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
Posted on Oct 04, 2011
Condensation on the fridge
The veggie draw should be able to control the moisture with the sliding lever on it.
Do you leave your food uncovered while it gets to room temperature? if not that may be your problem sealing it before it does.
Oct 26, 2015 | Bosch B26FT70SNS VitaFresh Refrigerator...
Fridge freezing up
It may be a faulty thermostat,namely the control you are using to turn it down.Also there may be ice in the drain line from the fridge compartment to the evaparator tray at the bottom.Try unplugging it overnight .That would allow any ice buildup to thaw.Once it goes into defrost mode again the resulting water should flow into a tray at the bottom of the fridge near the compressor.
Nov 11, 2014 | Refrigerators
I have recovered my kitchenaid pro 500 mixer that was stolen, but the serial numbers have been removed. is there any other place to look
The sticker is the only number that they have here in NZ. I don't know how they operate in your country but here if it is registered we can just ask the distributor for the serial number of the products that we have registered under our name. Our database is searchable by customer name or serial number.
Dec 01, 2013 | KitchenAid KSM500PSSM Silver Metallic Pro...
Siemens ka..n freezer problem
Look inside the back wall of the freezer to see if you have a layer of frost building. If yes this will indicate that the refrigerator is missing its defrost cycle. When you miss defrost it is usally number 1 the defrost control. Number 2 is the defrost heater has burned out and #3 the defrost thermostat. For you to look up the correct replacement parts you will need to find your refrigerators model number found most times inside the fresh food compartment. Click Here for=> Bosch Refrigerator Defrost ControlsI will be here to answer any questions you may have or if you have your model number let me know and I will help you find the parts you need, Thanks Sea Breeze
Feb 16, 2012 | Bosch Refrigerators
Regarding recent fire risks with Beko FF. I can't
The serial number should be in the top fridge compartment, on the inside. Left hand wall three quarters of the way up and about 4 inches in. A silver or white sticker with the Model and performance data written horizontally and the serial number in bold written vertically.
The model number you have given doesn't match any on the list,.
If you have not already read the following article, it may help you further:
Jul 09, 2011 | Refrigerators
Freezer fan is noisey and can t find serial number
The number you will need is the model number. On side by side models there are a few places to look. 1- inside fridge on right or left wall. 2- Open fridge door and look up near the top front lip. 3- Open both doors and look on body of fridge under the doors. 4- Fridge door sometimes there is a sticker right when you open. Mostly you are looking for a silver sticker or silver plate. It gives you a model number and serial number. If you need further assistance please mail me back.
May 26, 2011 | Kenmore Side by Side Refrigerator
Jan 09, 2010 | Bosch KGU32124 Bottom Freezer Refrigerator
Fan runs freezer and fridge don't cool
Please check the model number again, I can't locate that number. The number should be like for example 194.258978 Look at following areas for the model number
  • Beneath Or Inside Food Compartment On Cabinet Frame
  • On Plate Lower Front Or Rear Of Cabinet
  • Beside Compressor Door On Right End
  • Near Rear Of Cabinet
  • Inside Liner At Top
  • I think your refrigerator has a defrost timer and this may be the problem, Let me know what you find, Thanks, Sea Breeze
Mar 29, 2009 | Kenmore Refrigerators
Hotpoint Fridge freezing the food.
If you give me the model number I can find an exploded view, alternatively enter model number here to get the schematics.
Oct 26, 2008 | Hotpoint FFA90 Bottom Freezer Refrigerator
Bosch B36IT71SNS (20 cu ft) Bottom Freezer French Door Refrigerator Logo
22 people viewed this question
Top Bosch Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Bosch Refrigerator Expert? Answer questions, earn points and help others
