Question about Kenmore 66942 Dryer
My dryer just started making a funny noise. It
My dryer just started making a funny noise. It sounds like a belt may be loose, but I'm not sure how to check it. The drum does turn by hand and with power, but when I turn it, the noise starts. Suggestions?
  • Anonymous Mar 29, 2014
    When dryer is running has a funny electrical smell.now the lights are lit up when you turn it on but it won't start and it makes a beeping noise. I'm wondering is something electrical has overheated
    Problem Solver:
  • 12 Answers
Un plug dryer and take it apart and see if belt come off or broke
Posted on Jun 19, 2009
Why does my dryer hum?
DRYER MAKES NOISES.
A loose or worn BELT can make funny noises
Or the idler pulley that puts tension on the dryer drum drive belt could be worn out. If the pulley is bad we recommend also replacing the belt.
The glides on drum worn and making metal to metal contact.
The drum slides or glides support the front of the drum. As the drum rotates over the years, the glides wear out and then the dryer makes noise. Replace all of the glides as a set if they are worn out.
CHECK FOR LOOSE BELLOES inside the drum
Sometimes an item can get stuck inbetween the drum and the housing and scrape and grind making funny noises, things like coins, bra wire, nails, hair pins, etc sometimes u can just remove the cabinet and observe by turning the drum by hand or looking for scratch or scrape marks on housing.
The blower:
Clumps of lint, socks, and other small articles of clothing can get past the lint filter and into the blower wheel. If the dryer makes noise, and the noise seems to be at a very fast pace, there might be something caught in the blower wheel. In addition, the blower wheel sleeve might be worn out, allowing the blower wheel to wobble on the motor shaft. If this happens, replace the blower wheel.
The bearings:
The drum bearing supports the rear of the dryer drum. If the dryer makes noise this bearing might be worn out. Replace the bearing if it is worn out. Do not lubricate the bearing, the lubrication will attract lint and dirt and accelerate the wearing process.
The bearings TEST by moving drum by hand u may be able to feel loose or rough movement. And listen to sounds when turning it.
The drum rollers or castors:
It is very common for dryer drum rollers to wear out. If the dryer makes noise, particularly a loud rumbling noise, one or more of the rollers may be worn out. After removing the drum from the dryer, inspect the rollers.
Check for cracks, dryness, or damage and not engaging drum properly. Sometimes u can use high density LITHIUM BASE gear grease to re oil/grease them.
GOD IS GOOD !!!!
Apr 23, 2016 | Whirlpool Duet 7.0 Cu. Ft. Capacity Plus...
It just started to make a squeaking sound. Like metal rubbing on metal.
DRYER MAKES NOISES.
The blower:
The bearings:
GOD IS GOOD !!!!
May 07, 2015 | Whirlpool Duet WED9150WW 6.7 Cu. Ft....
What is making mywhirlpool/admiral electric dryer sound loud and thumping noise
You dryer belt may be shot and a piece of rubber is missing making it jump while working. Needs replacing before it completely quits. It will eventually just break apart.
Apr 13, 2015 | Admiral Dryer. 6.5 cu. ft. Electric Dryer...
My Kenmore dryer model #110.9757 is making a loud noise
DRYER MAKES NOISES.
The blower:
The bearings:
GOD IS GOOD !!!!
Oct 07, 2014 | Dryers
Why is the dryer making a squilling sound
DRYER MAKES NOISES.
The blower:
The bearings:
Aug 18, 2014 | Kenmore Elite He5T Dryer Heating Element...
My kenmore 84052 is making a squeaking noise
DRYER MAKES NOISES.
The pulleys or rollers. Check for cracks, dryness, or damage and not engaging drum properly. Sometimes u can use high density gear grease to re oil/grease them.
The bearings by moving drum by hand u may be able to feel loose or rough movement. And listen to sounds when turning it.
The belt loose or worn can make funny noises
Aug 14, 2014 | Kenmore 84052 Dryer
Drum turns but sounds like a small metal object, possibly a screw, banging around inside . Continued to use and now sound is much louder and sounds like a bigger object.
DRYER MAKES NOISES.
Jun 27, 2014 | General Electric Profile DPSR610EGWT 7.0...
Motor making noise
DRYER MAKES NOISES.
The blower:
The bearings:
Apr 15, 2014 | Frigidaire FGQ1442ES Gas Dryer
SCREECHING DRYER
DRYER MAKES NOISES.
Apr 11, 2014 | Frigidaire Washing Machines
Dryer making funny noise and took top off and there is only one belt on tumbler how many belts is there supposed to be?
they generaly only have one belt and I've never seen a two belted drum on a dryer. The belt could be getting old/loose and this will make noise. As long as the noise is not loud and the dryer is still working I would not worry. If the belt is old and getting loose it would not be too expensive to buy a new belt. Good luck
Oct 27, 2009 | GE 7.0 Cu. Ft. Super Capacity Gas Dryer
Dryers Logo
389 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Marvin
Marvin
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
