Question about Refrigerators
Kenmore model # 596.72913200 refrigerator with bottom freezer drawer - making noises, ice maker quit. When the freezer drawer is opened noises stop but whenyou close it again the noises start. Ice make still not working.
  • 172 Answers
SOURCE: Kenmore Coldspot w/Ice Maker Not Making Ice
hi LOP7,
In most cases you can easily solve this problem.
step one would be to make sure your freezer is getting cold enough. If you have icecream in your freezer is it frozen solid or is it soft. Most icemakers cycle around 0 degrees and if your freezer is not getting to 0 then it will not cycle and it will not make ice.
Step two would be to make sure you icemake is cycling. To do this simply lift the little shut off arm on your icemaker and wait about an hour then go back to the icemaker and drop the arm down. The icemaker should start going through a cycle. You should notice the arm slowly begin to raise and the ice dispencer fingers will begin to turn. Then you will hear it call for water. You may hear a humm.
If the freezer is cold enough and the icemaker is cycling that only leaves the inlet valve. replace the valve and enjoy the ice.
If the freezer is cold enought and the icemaker does not cycle, then you have a bad icemaker. Simply replace the icemaker and viola.
Third if the freezer is not cold enought 0 defrees. Then you may have a defrost problem. In this case post more info and I will be happy to help. Good luck mca0824@aol.com
Posted on Apr 30, 2008
  • 8 Answers
SOURCE: Ice maker is making hollow ice cubes, some only half frozen
Most ice makers have an adjustment screw to control the cube size. Its usually hidden behind a plastic panel on the front of the ice maker. A quarter turn either way and some trial and error testing should get you pointed in the right direction to your ideal ice cube.
Posted on Nov 05, 2008
Maanita
  • 1142 Answers
SOURCE: fan runs constantly, freezer ice melting, bottom drawer in refrig
  • If your refrigerator temperature is closer to 35 degrees, try turning the temperature up slightly.
  • If you find that the temperature varies a lot from the top shelf to the bottom (where it is coldest), try putting produce and other sensitive products on a higher shelf.
  • If the temperature is too low and you can't make it warmer by adjusting the thermostat, you probably have a defective thermostat. If so, you need to replace it, because they cannot be repaired. Other possible problems are a leak in the sealed (refrigerant) system, cold air migration (in side-by-side models) or a defective air damper. These problems can be quite difficult to locate and correct, we recommend you contact a qualified appliance repair technician.
  • Posted on Mar 24, 2009
    rogrrabbit
    • 986 Answers
    SOURCE: Oue Kenmore Coldspot ice-maker quit working. Any
    Wake up one morning and Boom no ice left in the bin. What happened and What can I do to fix it without calling someone? Some ice makers will get a piece of ice in the wrong place and jam the extraction. Get a hair dryer and heat up the ice maker to release the fouled ice cube and that baby will start going. No water in ice mold?Do this easy test: pour some water in the ice maker mold and wait. If it kicks out a batch, but it has no water in it, most likely the water valve is bad. water%20valve%20for%20water%20and%20ice%20through%20the%20door.jpg Watervalve for SxS box Since it is the cheapest part and you can do it yourself replace it. If it turns out you need a new ice maker then you have a new water valve already to go with it. What if the ice maker has ice in it but won't harvest any? One cheap and easy item for the do it yourselfer to replace is the ice mold thermostat. Check for voltage between T and H if you have 120 volts then the bi-metal (inside that ice mold thermostat) is bad. If it's good you will have 0 volts. ice%20mold%20thermostat%28modular%29.jpg Ice mold thermostat Located in the plastic housing and seated against the ice mold is that thermostat. This looks intimidating but is easily fixed by anybody who could change a spark plug. There is no wiring. One more thing to look for: You can put a jumper between L and V and this will activate the watervalve. Have rags ready! If you are a cheapskate and want to be frugal and not buy a new ice maker or a new head(brain) head1.jpg modular crescent ice maker you may want to remove the main gear and clean the copper plate behind it. That plate gets dirty and won't allow for a good contact with the water valve connection and does not power up the valve...Shhh! They will all be doing it! Modular crescent Icemaker test points: With NO power to the icemaker, and ice ejection fingers in the freeze position: Your ohm meter should read 8800 ohms between L and M, and 72 ohms between L and H. With power ON to the ice maker: If meter reads 0 volts between L and N you have no power to the ice maker. If the meter reads 120 volts then you have power to the ice maker. If you have 0 volts between L and H heater is off if you have 120 between L and H the heater should be ON. If you have 0 power between L and M the motor is off. If you have 120 between L and M then the motor should be ON. If you have 0 volts between T and H the thermostat is closed If the meter reads 120 between T and H then the thermostat is OPEN. If the voltage is 0 between N and V the water valve is closed. If the meter reads 120 water should be filling the mold.
    Posted on Nov 11, 2009
    Sheikhtijani
    • 1284 Answers
    SOURCE: my ice maker quit making ice.
    Hi, If your ice maker has stopped making ice then you need to check these things.
    The lever that controls the ice maker has been pushed up which turns it off. If you have a red lever, pull it down to the wire and if you just have a wire then just pull down the wire to start your ice maker up.
    Make sure the freezer temperature is below 10 degrees F If the freezer is too warm ice production will be poor because the ice maker will not cycle properly.
    The ice maker fill tube may have ice formed in it, blocking it. Use a hair dryer to melt the ice. Watch out for the plastic parts, so that you do not melt the plastic. Also check the water inlet valve and the shut off valve, to make sure it is not plugged with debris. The openings in those valves are very small.
    Check the gears in the ice makers to see if they are broken or stripped. Also look to see if the ice rake is broken. All parts in the ice maker are replaceable individually, If you find broken parts replace them.
    Take care
    Posted on Jul 23, 2010
    Kenmore refrigerator making high pitch noise top front
    could be the ice maker or the evaporator fan motor.you can try lifting the arm up on the ice maker and see if it stops,this will shut off the ice maker.also when you open the freezer door to lift the arm on the ice maker the evap fan motor should start when you open the door,you should hear it blowing around,is this the noise you hear?these are the two things i can think of that could make a noise up top,if not it could be the compressor or the condenser fan motor but these are down the bottom back of machine but still could be the problem,if the ice maker and evap fan motor both in the freezer are ok pull out the machine and remove the bottom back panel and check to see if the noise is coming from there where the condenser fan motor and compressor are,you're going to have to do some detective work to find the noise,hope this helps you out.
    Aug 19, 2012 | Refrigerators
    Our Kenmore Elite (new last summer) bottom freezer double top doors, stopped making ice. The wire that seemingly controls the ice maker is hanging down in a way that is causing difficulty opening the...
    Well, that wire is likely the cause of your issue, somebody probably bent it, and now it gets caught on the door or a basket or a food item or what have you, and since it cannot move, the ice maker will not make ice.
    Aug 13, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
    Frig is driving me crazy---weird noise and no ice!!
    That might be the fan. Making that noise, because fan stops when you open the freezer. The ice maker might be a totally diffrent problem. The solenoid may not be opening to let the water in, which is usually cause by a bad solenoid.
    Nov 28, 2009 | Jenn-Air JFC2089H Bottom Freezer French...
    Freezer making grinding noise ice maker not working
    Sounds like the icemaker may need to be replaced. When you open the freezer drawer it cuts power to the icemaker.
    Jun 18, 2009 | Maytag MBL2256KES Stainless Steel Bottom...
    A very unusual 'croaking' frog like noise from the back of the freezer compartment. It stops if the freezer door is opened and starts again once closed. The freezer light switch is involved: With the...
    I have a Kenmore Elite Trio and the freezer was making a frog sound. I found the solution.
    My model number is 596.75523400. The sound will stop when the freezer is opened. It will stop again when the freezer drawer is open and the light switch is pressed to turn off the light. The ice drawer was full but it had stopped making ice.
    Here is the fix in less than 10 minutes using only a screwdriver.
    • Take out the two freezer baskets
    • Remove the freezer door from the two slide tracks.
    • Unplug the icemaker electric connection at the back wall. Depress the clips on the side of the plug and wiggle it loose.
    • There are 3 screws that attach the icemaker to the left freezer wall. Remove the lower screw and unscrew the top two about ½ way out.
    • Slide the icemaker up so the slots slip over the 2 screws.
    • Put the icemaker in the sink and run a bit of water on the frozen cubes until they fall out.
    • Take the screwdriver and check the water inlet hose/pipe for ice that obstructs the flow of water into the ice maker.
    • Re-mount using the 3 screws and plug in the electric connector. Make certain the water inlet tube is positioned thru the retaining hole before you remount the screws.
    • Replace freezer door and baskets.
    Jun 05, 2009 | Maytag MBF2556HEW / MBF2556HEB /...
    Kenmore elite bottom freezer. Frost, Ice tray
    The adjusta cube ice maker has an on/off switch. To stop the ice from overfilling and being knocked off when you open the freezer door turn the ice maker off and then back on as needed.
    Mar 28, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
    Ice/frost buildup & loud noise
    this is classic compressor failure. the core is freezing due to unregulated pressure in the lines. repairing the compressor will correct this issue.
    Mar 11, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
    Funny fridge noise, kenmore elite trio
    Nov 01, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
    Trio 596.76502500 Mystery Noise
    Does the noise only occur when the compressor is running ? My unit has this problem, similar symptoms to your unit, they stop when the freezer door is opened, etc., Several service calls have not completely eliminated it - yet ! The problem seems to be that the compressor coils are too close to each other and rattle. Adjusting them helps for a awhile.
    Jul 31, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
    Kenmore bottom freezer 795.75092402 freezer doesn't open
    After several hours working and moving the door, I was able to slide open the door. Found out that the ice maker was leaking and the water was in the bottom an it frozen and that was stopping the door to open.
    Jun 15, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
    Refrigerators Logo
    43 people viewed this question
    Top Refrigerators Experts
    Charles T Nevin
    Charles T Nevin
    John Tripp
    John Tripp
