Question about Singer Sewing Machines
How to oil singer 1725
Machine is noisy, have oiled moving parts, still noisy
  • 323 Answers
SOURCE: Hi, Recieved the machine (Singer
Go to this site and you can download your manual.
http://www.singerco.com/accessories/manuals.html
sewman7
Posted on Feb 07, 2009
  • 25 Answers
SOURCE: oil prablem
Remove the bobbin case.Snap the two retraining arms outwards.Remove the hook race cover and the hook. Oil on right hand side about 4 O'clock... 1-2 drops of oil.Turn the hand wheel until the hook race is in the left position...replace the hook...replace the hook race cover and snap back the two hook retaining arms. Good Luck
Posted on Jun 03, 2009
  • 980 Answers
SOURCE: where do i put the oil in for the machine
You can only oil the moving parts that you can see very lightly
Posted on Oct 21, 2009
  • 29 Answers
SOURCE: Singer Samba 6 sewing machine
It would be wise to have the machine cleaned & serviced. Do you have a manual for it? Did it come with oil at one time? I found a free manual at
http://homeappliance.manualsonline.com/manuals/mfg/singer/7442.html
You have to register (free)...choose to skip the popups (2)...and you can save the manual to your hard drive.
I checked the manual...you don't need to oil the machine...but page 61-63 shows cleaning...and it's basic. You take the two screws from the throat plate, remove the bobbin case & brush the inside of the machine bed out...I use a small artists plastic bristle brush, or a small childs tooth brush.
Hope this helps.
Posted on May 14, 2010
Testimonial: "Hi, thanks a lot. I don't know if it came with the oil, we assumed that it maybe needs oil (my father knew this from the old machines ;-) ) Again thank you very much for your quick answer!"
  • 1564 Answers
SOURCE: How do I take of the back cover on my Singer 2250 tradition?
These plastic machines are like computer cases. Get a thin bladed tool and wedge it between the sections... look for those "tab locks" and release them.
Good luck.
Posted on Sep 17, 2012
My sewing machine has stopped working, it was working ok , just a bit noisier than usual but now the needle wont move at all, even if i try to turn the wheel by hand
the machine may need oiling, check in your sewing machine manual to see about oiling it, it's also possible that the machine could have a damaged or broken part inside,,
Mar 17, 2016 | Singer Inspiration 4210 Mechanical Sewing...
How to oil singer model 413 sewing machine?
The best way that you can do this is to observe moving parts starting from the left; the needle arm and pressure arm. Then take off the top and watch the moving parts and oil the moving parts. Do the same underneath the machine. The main thing to remember is to make sure parts that are rubbing against each other have been oiled. There are many parts rotating so ensure the bearings are oiled. While you are doing this it is a good idea to clean the parts with a rag and qtips.
Feb 16, 2015 | Singer Sewing Machines
How do I oil my singer sewing machine
Hi, there are holes on the top of the machine that serve as oil holes. Use a machine oil (as thin as possible- thick oil is no good). Oil any moving parts that you can see. wipe off all excess oil,so as not to mess the material when you sew. Before threading machine, run the machine as though u are sewing ,fast then slow a few times, this will help to lube the machine. Should the machine be used after very long time it is wise to open side covers or any area that can be accessed and clean the mechanism inside with paraffin( this also helps parts that may be stuck to move freely). Do'nt forget to replace (rescrew) any panel or part that is taken out. safety first. All the best.
Oct 01, 2014 | Singer Sewing Machines
How do I take of the back cover on my singer 2250 tradition? Not the cover for changing the bulb, but the one that covers the rear of the machine. The machine became very noisy and after I cleaned it and...
Good luck.
Aug 26, 2012 | Singer 2250 Tradition
How do I oil my5050 singer
Oil all moving parts that you can get to but oil sparingly with sewing machine oil or WD40
Aug 30, 2011 | Singer 5050 Mechanical Sewing Machine
Where do i put the oil in for the machine
Oct 18, 2009 | Singer 2950 Mechanical Sewing Machine
How to oil a singer 6038c?
You can only oil the moving parts that you can see very lightly.
Oct 14, 2009 | Singer 6038 Mechanical Sewing Machine
Oil
Most every machine has an oiling diagram in the instructions but if yours is gone then don't be afraid to take the covers loose and oil anywhere 2 moving metal parts come togeather but only a drop. Over-oiling will cause a heavy collection of lint and dirt possibly causing damage later on. Don't be afraid to remove the covers, just put them back on the way they came off. While your at it, give it a good vacuum, or blow and brush it out. Good luck.
Sep 09, 2007 | Singer 1725
Sewing Machines Logo
26 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Level 1 Expert
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
