Question about Garmin Nuvi 760 Handheld GPS Receiver
Touch screen needs to be calibrated (i.e., when typing an "a", I might get an "o", or nothing at all. Same applies to numbers. I was unable to get to the calibration screen following instrucitons in owners manual; turning unit off and back on, locking the unit, and touching the screen for 30 sec.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 86 Answers
That is actually how you should do it, it's just that it's very hard to succeed. Personally I have to try 3-4 times before making it work. The "trick" is to start touching the screen right after it was turned on, but right before locking it, but still locking it right after it was turned on.
It's stupidly hard on this specific series for some very weird reason.
Also, since it seems to be very calibrated to the left, try pressing far left on your screen, so the touch is registred too, don't know if it helps, but possibly.
Posted on Jun 18, 2009
Access touch screen settings
Open the charms, Search, and type what kind of settings I need (if I wan to calibrate the screen, then I type "calibrate")
Mar 01, 2014 | Toshiba Satellite Computers & Internet
My LED screen on my Quantium xl 1000 in not aligned properly
Check to see if there is some sort of Touch Screen Calibration mode that you can use. I'm not familiar with that model, so I don't know what menu items you have available. Is there a Utilities function? That might be where something like Touch Screen Calibration would reside.
Another thing that I just thought of is you might have a dead battery for the settings. Some devices have a battery that keeps a voltage applied to a chip that contains settings information. If the battery has died (too old), the settings may have been erased. Data such as Touch Screen Calibration values would be stored in this memory. These batteries usually keep the memory alive for several years, but they eventually wear out. More modern devices keep this info in Flash memory that does not need a battery. Screen calibration is usually done at the factory when the machine is manufactured.
Jan 24, 2018 | Singer Quantum XL-1000 Computerized Sewing...
I have a Garmin Nuvi 1450 that I bough in December 2010. This morning, when i try to type in an address, the touch screen is behaving erratic. For example, when N is pressed, it types M. Erase is not...
nuvis do not have a calibration screens or settings, to fix your issue try updating the units firmware with Garmins WebUpdater software this could fix your issue, it can be obtained from this link http://www8.garmin.com/products/webupdater/howtoinstall.jsp
Feb 13, 2011 | Garmin nuvi 1450 GPS Receiver
Samsung Impression touch screen not working, so am unable to retrieve contacts, photos, etc. AT&T said they couldn't help.
Hello
What you need to do is to calibrate your screen.
There is a code to do that,type in the code using the keyboard and use the keyboard "enter key" when done typing. A screen message will come up briefly. Something about processing and that the phone will shut off and restart. After the restart the touch screen should work again.
code: *2767*3855#
If problem persists,you should replace the flex cable and digitizer screen.This should solve the problem
Dec 13, 2010 | Samsung SGH-A877 Impression Cell Phone
The touch screen and the pen do not pair to function
my i9 phone does not apply the touch screen anymore and the pen calibration i cant click on screen . when i try to calibrate it keeps on the same infomation of "touch where the point is , left, center and right.
Dec 24, 2008 | Dual Electronics CECT P168 Cellular Phone
Iphone touch-screen
sir whats ur model\????
May 28, 2008 | Apple iPhone Smartphone
Unable to enter address as keyboard types a letter other than the one selected
press and hold the power button for approx 30 seconds. a calibration screen will appear. perform touch calibration to correct.
Nov 03, 2007 | Garmin StreetPilot C330 GPS Receiver
Touch screen does not work.
(1) Disconnect any external GPS antenna. (2) Do not turn on auto engine. (3) Turn off any other peripheral devices. (4) Simultaneusly hold down the PAGE and MENU buttons while turning on the 2620. A prompt box will appear asking if you really want to delete all user data. Touch the NO selection. Then turn off the 2620. (5) Simultaneously hold down MENU & ROUTE buttons while turning on the 2620. (6) A self-running diagnostic program will appear. Allow it to run for a couple of minutes; check to see that all parameters indicate "PASS" or other indication of being OK. If any parameter is not OK, make a note of it for potential communication to Garmin, then proceed with the following steps (7) Turn off the 2620. (8) Simultaneously hold down the PAGE, MENU & ROUTE buttons while turning on the 2620. A SCREEN CALIBRATION adjustment screen will apear. Quickly touch the points indicated as the calibration program runs. At the end of this procedure, the screen will display a window indicating that the calibration either "PASSED" or "FAILED." If it "PASSED," continue to steps (8)-(9). If it "FAILED," turn off the 2620 and repeat this step. If, after three calibrations attempts, each one is "FAILED," then also turn off the 2620 and proceed to steps (8)-(9). (8) Turn on the 2620. Press the "OK" button each time prompted to do so. Wait for maps to load and for the 2620 to initialize, acquire satellites, and display your position. (9) Press FIND button, then touch the right-hand vertical screen position adjustment to scroll screen display down to reveal WAYPOINT selection box. If unable to select WAYPOINT, or if attempting to do so only selects an adjacent box, then repeat step (7), and return to this step. (10) When various waypoint selections appear, attempt to scroll down to a selection not visible when the list of waypoints first appears, and select one of them. If still unable to select WAYPOINT box, unable to scroll screen down (or if trying to do so selects a stored waypoint instead), once again repeat step (7). If successful,then proceed to step (11). Also proceed to step (11) if you have repeat step (7) but then still can't select WAYPOINT, can't scroll down after selecting WAYPOINT, or can't select a particular stored WAYPOINT. (11) Press the upper-right hand "X" to close out the FIND screen or sub-screen within that function. If unable to close the screen, press the PAGE button. (12) Press FIND button, and when selection screen appears, touch ADDRESS. On next screen, touch the STATE line and touch the ENTER A CITY in (name of state). When keyboard appears on screen, use it to enter your city, then touch OK. Continue this procedure to enter your house number and street name, then press "OK." If all screen keyboard keys not responding, repeat step (7), turn the 2620 off and on again, wait for it to initialize, and then attempt this step again. (13) Repeat this procedure several times if not initially successful. By the second or third run-through, the touch screen should respond fully and accurately. If, after many runs through this procedure, the touch screen still will not respond, the screen sensor probably will need to be replaced ($255). The foregoing procedure brought my touch screen back to life last evening, much to my delight. Do not be too concerned if the SCREEN CALIBRATION step does nto produce a "PASS;" on my third calibration attempt it produced a PASS but all of the touch screen points still had not returned to functionality. I was unable to get a PASS during the screen calibration step after that, but the many repetitions apparently nonetheless made the difference, as by patiently following the above prcoess for five cycles, full screen functionality was restored.
Jun 18, 2007 | Garmin StreetPilot 2620 GPS Receiver
Touch Screen Issue
Hi Troy, same problem with my 2610, It seems to be related to a voltage problem in my ford f-150 07. When starting the truck I think it sends current the wrong way because if i start and turn off the truck it goes back to normal, the problem comes back if i start the truck with the 2610 on. If this can help, the garmin tech also told me about the 225$ repair. Try turning the unit on and off and also your vehicule. Once it is ok, dont forget to turn the unit on and off while the car is on. It worked for me. I also know that this is not a definitive solution but it can help. Patrick
May 31, 2007 | Garmin StreetPilot 2620 GPS Receiver
Calibration of my MobilePro off
We've put together some useful tips on calibrating your MobilePro * When calibrating your touch screen be sure to use the same amount of pressure that you apply during normal use. In general, the lighter the better. This allows the screen to recognize taps consistently. * When calibrating your touch screen hold the stylus over the calibration point until it moves to the next point. Holding it for this period will lead to greater accuracy than just tapping the spot quickly. * When calibrating your touch screen support the screen from the back with your other hand. Try not to grasp the screen from the side with your thumb on the front. * When calibrating your touch screen do not let anything other that the stylus accidentally touch the screen. For example, don't rest part of your hand on the screen to help steady the stylus. * Once you've completed the stylus calibration, be sure to perform the double tap calibration as well. This will ensure greater accuracy.
Sep 14, 2005 | NEC MobilePro 900 Handheld
Garmin Nuvi 760 Handheld GPS Receiver Logo
257 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Steve
Will Halftowaite
Are you a Garmin GPS Expert? Answer questions, earn points and help others
