Question about LG LHD45EL Dehumidifier
Bucket full light on nd no water in bucket
I have not used the dehumidifier in a while. I went to turn it on today but got the bucket full light and it would not go on. There's no water in the bucket as i have it connected to a drain. I cleaned the bucket and the filter however, was not able to get the front grill off to check the coil.
  • ms_cap Jun 18, 2009
    I'll try it to see if it works
  • 355 Answers
I think that there is a 90 degree bend in the outlet on the bottom right front side of the collection tray that gets pluged with dirt, line etc. You can see this when you remove the collection container from the unit. I used a small piece of wire to clean out the hole and now the water goes into the tank and not onto the floor.
Posted on Jun 18, 2009
  • Rohit  Asthana
    Rohit Asthana Jun 18, 2009
    or check this
    If when you turn your dehumidifier on the compressor runs then you
    should get moisture. Dehumidifiers work on the same principal as
    refrigeration. There is a bad control switch or the compressor start
    relay or capacitor is defective. If compressor runs and
    there is no effect then that is another problem. The filter should come
    out the front where the air goes in front and the filter should be
    washed by hand in warm degrease detergent water, dry and replace. If the disposable type filter I will help you contact LG.Thanks,
  • Rohit  Asthana
    The bucket full light is controlled by a manual 'float' switch in the bucket itself
    -when
    the water level rises...it lifts the float ...turns on the light and
    does not allow the unit to operate because it believes it is full.
    It
    is very common for the 'float' to gets misaligned, hung-up, etc. when
    you remove and re-insert the bucket. Sometimes the 'chain' gets
    twisted, turned...which does not allow the float to ...float...rather
    it is 'hung-up' which indicates it is 'full'...when in fact it is
    clearly not.
    To check this:
    • remove bucket from unit
    • look into the top of the bucket opening to locate the 'float'...generally 2" round plastic ball on a shaft, (or chain)
    • softly cup the float in order to lift this up...with
      the unit stilll plugged in...to see if the light goes off...this is
      very likely
    • then be sure that the float mechanism is able to
      freely 'float' in the space....i.e. you are trying to simulate the
      impact of rising water levels in the bucket
    • as it rises (in your hand the machine will turn
      off/light on...as it drops....the light shuts off, allowing the machine
      to run (when humidity levels demand it)
    • then re-install the bucket....being very careful to
      lift the float, while you insert it...there is generally a little nack
      to it...but you quickly learn how to do it easily (I just reach into
      the space...cup the float...put the bucket on an angle...slide it
      in....release the float into the bucket...(remove hand)...then finish
      pushing the bucket into place
    -hope this helps
When full bucket light comes on water is emptied and bucket put back in position. Fan will start and then the full bucket light comes back on beeps and shuts off.
You have to be sure bucket is replaced exactly where it should go or the bucket will hold the switch in, thinking it is full. If you have a floor drain close by,remove the bucket and set the dehumidifier over or next to drain so water will go down it,then you don't worry about bucket getting full.If it doesn't run with bucket off, maybe defective switch. unhook wires to the bucket switch and hook or tape together,if dehumidifier runs then switch is bad. UNPLUG FROM OUTLET BEFORE DOING THIS. IF YOU DON'T UNDERSTAND ELECTRICITY GET QUALIFIED HELP!!
Sep 17, 2014 | Dehumidifiers
The full bucket light stays on yet no water is collected
if water full light stays on the compressor wont start and remove water from air , investigate why light stays on ? is bucket really full? is sensor knocked out of its fragile holder ? is bucket all the way inside machine so that sensor is connected ?
Jul 04, 2014 | Kenmore 54501 Dehumidifier
Dehumidifier stopped working because "water bucket full" indicator light stays on, although there is no water in bucket.
In the water bucket is a float assm. scale forms on the assm. and causes it to stick. Remove the float assm. and carefully remove the scale. Should start working again once done. If not you may have to replace it.
Mar 11, 2013 | Dehumidifiers
My Kenmore 580.54501 dehumidifier "Water Bucket
Here is a tip that explains what can be happening to make the dehumidifier showthat the bucket is full when it is not.
Dehumidifier Problem It shows Bucket Full
heatman101
May 27, 2011 | Kenmore 54501 Dehumidifier
I noticed that the "bucket full" light is on and
heatman101
Mar 31, 2011 | Comfort-Aire BHD-651 Dehumidifier
Are you supposed to put water in the bucket of the dehumidifier or is the water that is in the bucket now from using the dehumidifier? Dumb question I am sure. But I am renting and have never used one...
The dehumidifier condenses the water on its coils and then it drips into the bucket. Dump out all of the water when the bucket is full. This model has a light that tells you when it is full. If the dehumidifier gets ice on the coils, it needs repair (low refrigerant).
I hope this helps.
Aug 10, 2009 | Kenmore 54701 Dehumidifier
I have a Goldstar GHD30 dehumidifier. I have not used it in awhile. I plugged it in to run it today and it does not turn on. I cleaned the screen and tried different outlets, nothing works. HELP!
Check the condensate collection bucket. If the bucket is not inserted correctly the dehumidifier might think the bucket is full and thus not turn on.
Aug 30, 2008 | Goldstar DH504EL Dehumidifier
LG LHD45EL Dehumidifier Logo
44 people viewed this question
Top LG Dehumidifiers Experts
Bill Long
Craig Butler
Craig Butler
Gil Shultz
Are you a LG Dehumidifier Expert? Answer questions, earn points and help others
