Question about Kenmore Dryers
Loud end of cycle signal. How do I silence
Kenmore Dryer 110.64202200
  • 883 Answers
SOURCE: Loud/Soft signal
all i can figure is it is a strange method by kenmore to alert the user to throw in an antistatic cloth that gives softer clothes (clothes softener sheets)
Posted on May 25, 2007
SOURCE: how to disable buzzer on kenmore dryer model#417.977962701
Same problem! Any advice beyond taking the dryer apart and trying to find the wires to disconnect?
Posted on Oct 07, 2008
SOURCE: signal
Kenmore 70 series. Model/Stock 66702692 Serial MG2402832
Cycle Signal works but then won't shut off until I open up the dryer door - it just keeps buzzing for hours. Also the dryer will turn on if I close the door ( and arrow is within a number and not on off) without pressing the start button. So if door is closed - the dryer will run or buzz (depending on arrow). How do I fix this?
Thank you
Posted on Nov 25, 2008
  • 1214 Answers
SOURCE: Kenmore dryer buzzes but does not run
You could have any one of several problems with that gas dryer -
Turn dryer on.
Go out to where dryer duct exits house.
Feel the amount and strength of air blast coming from vent.
Air blast should be strong and cover the full face of the vent.
If not, check that dryer hose is not crushed/collapsed behind dryer as it is pushed back into position.
Clear any restrictions in the vent pipe.
Clean lint screen.
Check that there is no restriction where air is pumped into or discharges from the dryer drum on the inside.
If you are able to, check to see if you can see the pilot ignitor lighting.
Reply back your findings for further instruction or information.
Posted on Feb 04, 2009
SOURCE: Kenmore stackable washer dryer. Dryer buzzer is
Just solved this problem for a Kenmore stackable washer dyer! Sorry I don't have the model number. I have a baby on the way and a small house. I was pretty sure I would get no sleep between the baby crying and the baby crying because of that darn buzzer!
The buzzer is attached to the timer with a quick connect post. Access the controls by unscrewing the large panel above the washer door. You will need a square screwdriver or a very small flathead and some vice grips to get it started. The panel will fall forward onto the washer. In mine there was a pouch with an electrical diagram of the unit. To release the controls, two more screws must be removed from the sides of the small panel housing the controls. Once again you need a square screwdriver or a very small flathead and some vice grips to get it started. Once these are out you should be able to lift the control panel up and it will fall forward. Get a small box or stand to put on the washer. This will support the panel as the wires are not that long. On the left side of the timer controls you will see a quick connect post marked with an "H". Disconnect this wire and your problems are solved. Beautiful silence! I put electrical tape on the quick connect wire. Not sure if I needed to as I'm not an electrician. Hope this helps.
Posted on Aug 26, 2009
Why won't the buzzer alarm go off at the end of a drying cycle
Search Results
    Why does my Kenmore dryer model 417.94802/94862 end ...
    www.shopyourway.com > Manage My Life > Questions
    Why does my Kenmore dryer model 417.94802/94862 end of cycle alarm go off ...washer/dryer unit I do see that it is normal for the end of cycle buzzer to go off ...Why won't my Kenmore dryer model 110.86872100 shut off at the end of the ...
    Why won't the buzzer shut off on my Kenmore 80 Series ...
    The buzzer won't stop buzzing after the load is complete. ... or turn on the timer and the dryer will start just by selecting a cycle and closing the door. ... The dryer should continue to run and at the end the buzzer should only stay on as long as ...
    FIXED The Buzzer At The End Of The Dryer Cycle Comes On But Won't ...
    www.applianceblog.com/.../21739-The-Buzzer-At-The-End-Of-The-Dry...
    Dec 11, 2010 - 10 posts - ‎2 authors
    My maytag dryer has operated wonderfully until today. All of a sudden the buzzer that goes on at the end of the drying will go on but will not shut off unless I open the door.... To test it: by-pass the push-to-start switch and see if when you turn the timer on and close the door, the ... VERY annoying dryer End of Cycle Signal
    Jun 29, 2012
    Maytag DE8410 electric dryer - End of cycle buzzer stuck ...
    Mar 27, 2011
    Kenmore 80 series, buzzer won't shut off
    Sep 10, 2005
    More results from www.applianceblog.com
Feb 08, 2016 | Whirlpool Dryers
How-To Unlock The Controls For A Whirlpool Duet washer
I have unplugged the machine and plugged it back in and restarted, just like when a computer needs to be reset/cold boot.
Jul 03, 2015 | Whirlpool Duet GHW9150P Front Load Washer
Cycle Signal keeps beeping loud-soft every 15 seconds while dryin
Hi Celine, I just experienced the same exact problem. I came here looking for a solution. I got mine to stop by holding down the cycle signal button for 3 seconds, releasing it for three seconds, and repeating until both lights (loud and soft) went off. Hope it helps.
peter
Apr 21, 2010 | Kenmore Elite Oasis 6808 Electric Dryer
Kenmore dryer beeps constantly
End of Cycle Signal
The End of Cycle Signal produces an audible sound when the
drying cycle is finished. Promptly removing clothes at the end of
the cycle reduces wrinkling.
@ H_GH
@ LOW
@ OFF
END of CYCLE S_GNAL
Press END of CYCLE SIGNAL to adjust the sound level or turn off
the signal.
NOTE: When WRINKLE GUARD _ is selected and the End of
Cycle Signal is on, a tone sounds every 5 minutes until the
clothes are removed, or WRINKLE GUARD _ ends.
Sep 15, 2009 | Dryers
How to get more volume on dryer buzzer
How can I change the tally.erp9 words font.It's automatic change i am in trouble please help me
Aug 19, 2009 | Kenmore Dryers
How to disable buzzer on kenmore dryer model#417.977962701
Jul 18, 2008 | Dryers
Signal
Thank you
Jan 04, 2008 | Kenmore 64892 Electric Dryer
Dryer buzzer
Depending on the model some have a separate buzzer you can disconnect and tape off the leads to it. If it is an electronic timer you can muffle the sound by taking a piece of electrical tape and covering the whole on the small black speaker attached to the timer.
Dec 18, 2007 | Kenmore 98702 Stacked Washer/Dryer
Loud/Soft signal
May 25, 2007 | Kenmore 67052 Dryer
Dryers Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
