Question about Konica Minolta magicolor 2400 Laser Printer
Does not print on right 1/4 inch of page
The printer fails to print for all toner colors, including black, on the right 1/4 margin.
I bought the printer refurbished and have not replaced any of the starter cartridges. Also when I print color, but not in black, it leaves yellow blotches down the right margin. Also I opened the printer up and there is yellow dust all over the place.
I am most concerned about printing in black, do you have any idea why it is cutting off the right 1/4 margin. It is not a formatting problem because the letters fade off rather than an abrupt stop.
  • 3 Answers
Try cleaning the laser lens cover - a 4" x 1/2" glass surface down inside at the front - you need to take out the bit with the green handle to see it. A soft cloth used gently should do it fine.
You would be advised to gently remove as much of the toner dust as you can, but be gentle and follow the cleaning instructions in the manual.
Posted on Nov 19, 2007
How do I change margin setrtings foe Lexmark P4350
If you are preparing to print a document that you have created in Microsoft Word, you may be concerned that all the text on the page will print exactly as you see it on your screen. This is not always the case. You can adjust your print margins to ensure that your text prints on each page exactly the way you would like it to appear.
Opening Your Document
Open your Microsoft Word document by double-clicking the Word icon on your desktop. If you do not see the icon on your desktop, then you can locate it where it is buried on your "Start" menu. Click "Start," followed by "All Programs." Then click "Microsoft Office," followed by "Microsoft Office Word." A new document will open on your screen. Click the "Office Button," followed by "Open." Scroll through the files listed, and double-click the one you would like to print. It will open on your screen.
Check Your Margins
By default, your page margins are set to 1-inch margins on the top, bottom, right and left of your page. You can check your margins or change them by clicking "Page Layout," followed by the "Margins" button.
Select New Margins
Select a different margin size, such as "Narrow," which indicate 1/2-inch margins, or "Wide," which indicate one-inch margins on the top and bottom and two-inch margins on the left and right. You also can select "Moderate," which indicate one-inch margins on the top and bottom and 3/4-inch margins on the left and right. Finally, you can select "Mirrored," which indicates one-inch margins for the top, bottom and outside. The inside margins are set at 1 1/4 inches.
Print Your Page
Print your page. Press "Control" plus the "P" button. The printer dialog menu will come up. Make sure that "All Pages in Range" is selected. Press "OK." If your printer cannot print your new margins, then a new menu will pop up telling you to adjust your margins.
I hope you find it very helpful. Best regards.
Aug 22, 2011 | Lexmark P4350 All-In-One InkJet Printer
Hp 2605dn Black cartridge is printing 1/8" LEFT of other colors.
That problem is frequently on HP 2600 series.
You must try to change all remanufactured toner cartridges with HP OEM with no exception, the best alignment it is when you change the black cartridge and the printer make a cleaning page process. Cartridge HP OEM should be almoust empty. It Is not necesarry to be a new one. After the alignment process, you can put the remanufacturated cartridges back on.
This was work for me. 100%
Sep 27, 2009 | HP Color LaserJet 2600n Printer
4 - black ink smudges (1/32" wide x 1/16" high) in right margin
Very nice trouble shooting. The image defect you describe point to the OPC or drum unit this is essentially the toner cart. In your case black. Measureing the distance between repetitive defects is a sure way of diagnosing problems such as yours. Again nice work.
Google repetitive defect ruler for your model to help in the future.
Hope this helps
Apr 07, 2009 | HP Color LaserJet 2600n Printer
HP Laserjet IIIP starting printing thin vertical black line
Was this happening before you swapped toner?
Is there toner streaks on the drum? Yes? Defective.
What if you stop the printer (open cover) as it passes through the fuser to determine if image is from drum or fuser?
But really....isn't it time to move on anyway???
Mar 20, 2009 | HP LaserJet IIIp Printer
Toner cartige
clean the roller. the toner you have installed may be defective.
did you have the same black squares before you change the toner???
Oct 29, 2008 | Brother HL 1440 Laser Printer
Stripes down left margin
Hi, I have the same problem, which has just been diagnosed as a defective developer drum by a repair specialist. The new part is $120.00. Should have the serviced unit back
Oct 16, 2008 | Ricoh Aficio CL3500N Laser Printer
Black ink smudges for color print mode only, not for grayscale
- Try to reallign the cartridge, run a print test, after that if the issue still persist - uninstall and reinstall software - run test and re-allign again the cardtridge using software. run print test again.
Oct 08, 2008 | Samsung CLP 300 Laser Printer
Color toners are empty
Press Green Tick, Right, -> System Setup -> Right, Right, -> Print Quality, Right -> Replace Supplies. Change from stop at out, to override at out. It'll let you print, and you'll get loads more out of your toner before the pages start to fade.
Dan :-)
Sep 30, 2008 | HP Color LaserJet 2600n Printer
Xerox 7700 intermittant banding on a diagonal black only
You most likely have a bad black developer housing.
You can try removing the waste bottle and using that bla\ck stick inside the cover to clean the laser ****.
But it sounds like the developer housing has failed.
Sep 07, 2008 | Xerox Phaser 7700 Laser Printer
Installed new toner. Printer prints well, except approx 1 inch of vertical line doesn't print about 1/2 inch from right margin. Have gently shaken cartridge, run a cleaning paper, reiserted cartridge.
Assuming none of your print area margin settings have been changed, it sounds like you may have a defective drum. You can try carefully cleaning the corona wire, a hair thin wire, with a dry cotton swab. Do not touch the drum! The drum is an integral part of the toner cartridge. Return it to the store as defective.
Aug 17, 2008 | HP LaserJet 1022 Printer
Konica Minolta magicolor 2400 Laser Printer Logo
314 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
