Question about LG Microwave Ovens
Tighten loose handle on LG microwave
The handle on my LG microwave LMV1683ST model is detached from the screw. How do I tighten it?
silly girl
  • 513 Answers
SOURCE: loose door handle
DON'T remove the cover yourself unless you fully undertand the SAFETY issues involved in working inside a microwave oven. A microwave oven is possibly THE MOST DANGEROUS common consumer product to service. Usually with these doors, the latching parts tend to loosen up at times, thus requiring some re-adjustment and tightening. Sometimes they get a bit warn and require to be replaced. The handle by itself about $40, apparently GE doesn't know how to make a door handle that will hold up for more than a year or so. I just bought a new door off of eBay for $20 + $20 shipping ... a deal compared to the $135 + tax and shipping that most of the web sites want! All you need is a phillips screwdriver and a 5/16" socket. To get to 3 screws that anchor the TOP hinge, simply remove the vent grill (open the door and remove the 2 white screws that hold it in place). To get to the 2 screws that anchor the BOTTOM hinge, simply remove the 6 screws that hold the grey bottom pan of the microwave in place. The pan will swivel down, remaining attached in the back panel. Once you've removed the 5 hinge screws, the door should pull pretty much straight out. Reverse the procedure with the new door, which should come with hinges attached. Could be that the place the spring sits in is a little broken, so theres no stop for the spring. open it up and see if there's anything you can do with it, try some epoxy putty maybe. Good luck
Posted on Apr 30, 2006
gwshaw71
  • 83 Answers
SOURCE: bottom screw on handle loose
open the door and you will have to peel and pry apart door.It is abot a 1-2" frame around inside door.that peels off it just snaps in.
Posted on Nov 25, 2007
SOURCE: kitchenaid model KHHS179LSS Microwave oven handle replacement
There is a pin holding the door on upper right hand corner of the door. Holding the door in the open position, lift up on the door a little and remove the pin. The door will come off. There are two screws on the edges of the door on the end where the handle is located. Remove the screws. Now, Take a slim screw driver, and carefully pry between the inside door panel and the ourside door panel starting at the end where the door handle is. Lift the inside of the door out. The opposite end of the inside door panel will come out last. Believe me, this works. Getting it back together is a little bit different, but it snaps back together without using tools. Just put the inside of the door back by laying it down with the handle side down after you have replaced the handle of course. Now, pushing in on the inside of the door panel starting on the handle side, start with lining up the panel and push gently. It will go back into place much much easier than it comes out.
Posted on Feb 06, 2008
  • 42 Answers
SOURCE: GE Model Spacemaker Microwave Model #JVM1650WB008 handle broken.
Appliance Repaired: General Electric Microwave
Model: g
Age Of Appliance: 5 - 10 years
took a screw driver and pride off plastic on inside of door. be carfule not to break it. only one of two screws that go into handle were visable. had to drill a hole in metal braket to get at second screw. you can just bend the metal braket back inorder to use drill. bend it back when done. took off handle and replaced it. snapped plastic piece I took off back in place and finished.
ge told me i needed to replace whole door. which they nolonger stock and I could not find a whole door for my model on web. found handlw on this website and did it my self
Posted on Mar 27, 2009
  • 949 Answers
SOURCE: GE Microwave model JVM1650CH01. Trying to replace door handle
This image might help. If not it looks like you have to disassemble the door until you get to the very outer frame, as that is where the handle screws are
Posted on May 07, 2010
Goldstar Mv1526W
is the lock/screw was loose//?
Jun 11, 2008 | Goldstar MV-1526 Microwave Oven
I have a neff combination microwave model B7740N0GB the door handle is loose I can see the screw fixing but can't see how to tighten it
Hi, if you ever want to sell this microwave for spare parts can you please let me know as I am unable to repair mine as spare parts are no longer being produced. Thank you
Aug 28, 2017 | Neff Microwave Ovens
It is not heating up and turn table is not working.
could be a fuse unless the light is on
consider this , a new unit cost half the price of repairs and parts and it could be a magnatron that is shot
Feb 15, 2016 | LG LMV1683ST 1.6 Cu. Ft. Over-The-Range...
Loose microwave handle
The handle screws are installed from inside the door, so it would be necessary to disassemble the door to tighten them. You have to decide whether the time and labor involved are worth it.
May 19, 2013 | Microwave Ovens
How do you tighten the handle on the microwave JKP78G0K2BG
You need to remove the screws that are holding the frame of the door to gain access to the rear of the handle assuming that the handle is not stripped out to start with.
Jan 30, 2013 | GE Microwave Ovens
The handle is loose on my icon microwave
Some of the handles have a cover like that you pop off and then there are the screws. good luck hope you have this kind.
Jul 17, 2012 | Electrolux ICON Built-In Microwave Oven
Bottom part of the handle has become detached, how do you reattach handle
We have the service manuals for these models and have uploaded them here and here to help you.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
You can find handy exploded views and order parts by model number here.
Aug 22, 2010 | Frigidaire PLMV169DC Microwave Oven
Microwave Ovens Logo
50 people viewed this question
Top LG Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
