Question about Refrigerators
WHERE IS THE DEFROST TIMER LOCATED ON A SAMSUNG SR335NME REFRIGERATOR
FREEZER WORKING, FRIDGE NOT, NEED TO REPLACE DEFROST TIMER, WHERE IS IT LOCATED
  • 195 Answers
SOURCE: Kenmore fridge Model# 106.56542400
Open the fridge side, look up.
Posted on Dec 07, 2008
MNTECH
  • 1543 Answers
SOURCE: freezer freeze up
Your model TFX20JRBKWWW uses a defrost timer part number WR9X489 located behind the light shield in the fresh foods compartment. (top back area). Just in case you need to know, the defrost heater is a part number WR51X10101 located behind the back wall of the freezer.
Posted on Dec 26, 2008
SOURCE: Maytag PBF 2255 HEW refrigerator defrost timer location?
These look like schematics that might help you.
http://www.partselect.com/AdvancedModelSearch.aspx?ModelNum=PBF2255HEW&mfgModelNum=&fkMfgID=1
Posted on Dec 27, 2008
  • 115 Answers
SOURCE: fridge and freezer not staying cold but lights and fan working
the problem is going to more then likely in the main control board which is on the back of the refrigerator in a little compartment this board is bad about going out if you have power surges or outages
Posted on Jan 03, 2009
  • 531 Answers
SOURCE: defrost timer location on Kenmore model 106.56542400
carry control board part#2149705
Posted on Apr 06, 2009
My refrigerator side is not cooling well. I see ice behind the fan unit when I take out the veggie drawers at bottom. Also fan on fridge side is making lots of noise. Noise stops when I open the door and...
.When you open the door freezer door will get stopped and so, no sound. It will work only when door is closed. Fan sound comes due to malfunction of defrost. If defrost does in right time it won't happens. Unplug and let fridge get defrost all icing. After 3 to 4 hrs,start run again, and set temp @ 5degree freezer. It will start cooling fridge compartment also. But, this is a temerory solution. To solve permanently, find out why defrost not functioned properly?
Follow this steps.
Check defrost timer working which is back of the refrigerator down corner. By with small tip screw driver in some models located in the ceiling of the fresh foodsection or behind the cold control cover. In the defrost timer,slowly turn the screw like wheel in the middle of the defrost timer withstraight screwdriver until the fridge shuts off. Now it's in defrost. If thedefrost heater(s) starts, replace the defrost timer and defrost thermostat. Ifthe heater(s) does not start, unplug wire cord to check ohm test for continuityof heater. If continuity is there, plug cord wire which gives power 120volts(check specification) to heater. If heater no starts, bypass defrost thermostatby join the 2 wires in the defrost thermostat. If the heater now comes on,replace the defrost timer and defrost thermostat. If the heater itself is bad,replace it. Thanks and hope helpful.
Jan 28, 2011 | Samsung RS2630SH Side by Side Refrigerator
My 20+ year old top freezer fridge sometimes leaks water from the freezer into the fridge through the air vents. Is this from the defrosting of the freezer and how do it get it to stop?
You will need to take the freezer compartment apart. Remove the ice build up. Clear the defrost drain located under the coils near the center of the drain pan. Usally some very hot water will work in clearing the drain. Once it is clear and the ice is all removed from the bottom of the freezer you will need to check and or replace the defrost bi-metal and the defrost timer. The bi-metal is located on the coils in the freezer. It looks like a little can with two wires going to it. The defrost timer depending on the brand can be located in the refrigerator near the controls,or under the refrigerator behind the kick plate. Or in the back of the refrigerator near the compressor
Oct 14, 2009 | Refrigerators
Freezer works great, but refrigeration section stopped working
Check the door seals on fridge and freezer to make sure there are NO leaks.
Try manually adjusting air flap that controls air from freezer to fridge, the flap may be frozen or the actuator that controls the flap may be faulty.
Aug 25, 2009 | Whirlpool GD5SHAX Side by Side...
Samsung model rs2577sl. fridge side not working
5 reasons for fridge and/or freezer getting warm: 1- the evaporator coils are icing up and won?t let air circulate. 2- the evaporator fan is not working to circulate air. 3- there is no refrigerant in the system. 4- no power to fridge or compressor. 5- the condenser coils have no air circulation check under the fridge behind the vent. if it is too dusty or the fan isn?t working, it is not getting enough airflow to cool down. replace fan and/or vacuum out the dust. if there is no power to the fridge, the light will be off. if the compressor is not running, there is a defrost timer that cuts the power temporarily to the compressor to melt ice on the coils. it?s located under the fridge behind the bottom vent. If the timer is off and the compressor is not going, the compressor or the main board is bad and needs replacing. there is also a temperature sensor on the evaporator coils that tells the defrost coil to turn on and when to turn off. if the defrost timer is on but the coil is not heating up, replace the sensor. if it still won?t heat up, it?s the timer or the coil. the easiest way to tell if there is no refrigerant- the freezer wall is warm and the compressor is loud. if there is no refrigerant, it may be more cost effective to replace the fridge. if you feel no air coming from the freezer vent, the fan needs replacing. If you feel air moving in the freezer but not the fridge, the channel from freezer to fridge is blocked. if the freezer has air and the rear freezer wall has frost on it, the evaporator coils are iced up and need defrosting. causes: 1. low refrigerant 2. no fan 3. too much humid air in fridge/freezer due to door open or bad door seals 4. the condensate drain tube is clogged if the seal around the door is ripped or not completely sealing, or there is condensation at the bottom or the walls of the fridge, replace the seal(s). no air, no fan. Replace if the refrigerant is low, it just needs a top off. but you need to be certified by the epa to move refrigerant, so get a professional. defrost solutions: unplug the fridge. remove the wall of the freezer that is frosted/icing up. use a hair dryer to melt the ice. do not get too close. you will see a drain under the evaporator coil. make sure it is not blocked. the water should run freely to a condensate pan under the fridge that evaporates the condensation with the hot line from the compressor. once the coil is free of ice, frost, and water, replace the panel and repair any of the problems that caused the icing up. plug the fridge in and turn it on. If it frosts up within a week, there is still an issue that not been taken care of.
Aug 25, 2009 | Samsung Refrigerators
Automatic defrost no longer works
If freezer is icing up, you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model
Aug 19, 2009 | Refrigerators
GE Profile - fridge not cooling
Aug 17, 2009 | Refrigerators
My Samsung side by side fridge is not cooling properly. The freezer is fine but the refrigerator does not cool enough. I cleaned it recentley but just wiped it down - nothing odd
If freezer is icing up, you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, ie defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
Aug 11, 2009 | Refrigerators
The fridge part of my fridge freezer appears to have stopped working
Look to the freezer for your problem. Frost free refrigerators are cooled by air from the freezer compartment. If the freezer cooling coil freezes up air flow to the refrigerator is lost. Look for signs of frost on back wall of the freezer section.
Located the defrost timer, turn the clutch head screw clockwise SLOWLY until you hear one audible click. The system will then be in the defrost mode. During the 18-22 minutes of the defrost cycle heaters are energized and defrost should take place. If defrost happens and the timer does not restart into the cooling mode, rotate the screw one more time SLOWLY to the second click and the system will restart in the cooling mode. Replace the timer in this case.
If the timer restarts the cooling after the defrost period and defrost does not happen your problem is in the defrost heaters or defrost thermostat. They are located inside the back wall of the freezer on the cooling coil.
Jul 05, 2008 | Samsung Refrigerators
My refrigerator is warm and ice build up is happening in the fridge
There is a timer that controls the refrigerator defrost cycles. This is located behind the kick panel at the bottom of the refrigerator. Remove the panel and look for a dial-like device toward the front. Try to manually turn the timer dial and listen for an audible click. No click, no defrost. Call a NEW repairman and have him check the defrost timer. Hope this helps.
Jul 27, 2007 | Samsung RB1955 Bottom Freezer Refrigerator
Refrigerators Logo
22 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
