Question about Bosch 12-Amp Formula Canister Vacuum with Hepa Filtration Bagged Vacuum
Cord want retract in my bosch vacuum - Bosch 12-Amp Formula Canister Vacuum with Hepa Filtration Bagged Vacuum
2 Suggested Answers
  • 38 Answers
SOURCE: Bosch Formula vacuum cord stuck
You need to take apart the reel. The cord is wound over itself and kinked. Be careful taking apart because if it gets away from you, you will have to wind the spring by hand and it is difficult to do and frustrating.Good luck
Posted on Jul 26, 2009
Bissell momentum canister vacuum retractable electrical cord not retracting
Either the cord inside is caught on something or the retraction spring is broken.
Try to pull it out further, if you can feel any spring-back then most likely the cord is caught, maybe on itself.
Either way, the canister will probably have to be disassembled to fix the problem.
Sep 17, 2016 | Bissell Vacuums
Bissell Hard Floor 1161 Bagless Canister Vacuum cord won't retract
You have to find a way to turn the drum the cord rolls up onto. Just move it par enough o allow it to retract. Hopefully you will hit that point before the spring lets go.
Dec 21, 2014 | Bissell Vacuums
Kenmore canister vacuum retractable cord jammed
go and buy it from www. repairclinic.com
God bless you
Jul 06, 2012 | Vacuums
I have a Kenmore Vacuum cleaner 116.24212. The retractable electric cord won't retract. How can I fix it?
The retraction mechanizm is likely jammed. Mostly likely the cord has jumped it's groove in the retraction wheel/hub. If you are good with tools there is a 70% chance you can get it to work again with a basic DCR operation. Most mechanical problems can be solved using this simple rule: Dissassemble Clean and Reassemble.
CAUTION: The retract mech has a powerful spring inside, avoid exposing. Most retract mech units are rivoted closed so consumers won't poke thier eye out.
CAUTION: UNPLUG THE UNIT
Open the unit from the bottom and the top lid of the canister should come off.
The retract mech should be obvious as it is where the cord comes into the unit.
Look for the cord being bound by iteslf either on top or underneath (lie two cordes in one groove)
Remove any binding.
If you see no debris or obsticals for the cord to retract (where it is getting stuck)
Your spring could have sprung!
Do you feel and retract at all?
Can you locate the releae mechagnism?
Does the Release button seem to function? When Pressed it should take pressure off of the cord hub.
The retract mech may need replaced. Overall the cost will be about $60 for parts.
Feb 12, 2011 | Vacuums
I have bosch forumla vaccum and cord got stuck. It is very hard for me to see the screws to open it. Could somebody help me how to open this safely.
This problem is solved easily after I found the third screw to open the top cover. You will find the third screw under the top cover where the variable regulator is. But be patience, your small mistake can screw up whole system. You will need a torx screw driver set.
Remember, dismental step by step. top cover/screw/top housing.
I found my cord retract mechanisam spring broken, I didn't put new one. Cause it could cost me more. However I just took the cable out which was tangles and kinked.
Dec 28, 2009 | Bosch BSG71360UC Bagged Canister Vacuum
Electric cord won't retract
Depends on the machine. If its a Sebo K model then usually pulling on the cord will re-automatically retract the cord anyway. Any other brand and it will need to be replaced by a qualified repair.
May 06, 2009 | Vacuums
Electrolux EL 7001 Oxygen 3 power cord continually retracts
The button has two parts - the inner part (button) and the outer part (surrounds the button). The press the outer part to deactivate (pop out!) the inner part.
It took me a while to figure this thing out, but I was glad the vacuum wasn't broken.
May 02, 2009 | Electrolux EL7055A Bagless Canister Vacuum
Yanked the cord out of the vacuum
Wasn't able to find any diagrams either, but there should be some screws to take out, and the top and bottom should separate. Don't let the cord reel spring unwind if it hasn't already done so. If it hasn't, one half of the reel should come aprt so you can re-attach the cord. then put the reel back together and let it wind the cord on the reel. If the spring is unwound and/or the reel wasn't made to come apart, then you will have to replace the cord reel asm.
Feb 28, 2008 | Bosch BSG71360UC Bagged Canister Vacuum
Retractable cord
I'm assuming that you have bought the new retractable cord assembly. If you have so, I believe the cord should retract going counter-clock wise (pulling it makes it spin clockwise).
Feb 22, 2007 | Kenmore 23613 Progressive PowerMate Bagged...
Sebo K 3 Vacuum
I had a problem with my K1 Komfort model which sounds similar to this. I initially thought the cord was too short but the machine wouldn't give out anymore and retracting was difficult. A Sebo engineer/helpline told me to pull roughly on the cord, of which I did and was rewarded with 2 metres more than what I thought I didnt have! So, perhaps if your machine isn't retracting properly, give the cord a rough pull with gloves on, or a strong grip - the cables on the K series are notorious for stopping up. Afterwards wipe the entire cord down with furniture polish; it will retract much more quickly.
Feb 21, 2007 | Sebo Air Belt C3.1 Bagged Canister Vacuum
Bosch 12-Amp Formula Canister Vacuum with Hepa Filtration Bagged Vacuum Logo
27 people viewed this question
Top Bosch Vacuums Experts
Cleverer2
 John
John
Are you a Bosch Vacuum Expert? Answer questions, earn points and help others
