Question about Cell Phones
Excessive downloading on PC
This is the second time-the site went down previously. I have 6MB per month but this month it was all used in 3 days from 29th March-1st April. As none of this was authorised I would be grateful for an explanation of this excessive use. I never go over my limit but the following downloads-1646MB, 587MB, 645MB & 465MB over 3 days are totally unacceptable and I would like an explanation. NO I DIDN'T HAVE INTRUDERS OR UNAUTHORISED USE OR SCHEMING GRANDCHILDREN. Please explain
  • kakima Apr 16, 2014
    Excessive downloading from where? 6MB per month with whom? FixYa does not put any limits on downloads. If you're having problems with another company, could you at least name that company? Otherwise we have no idea whom you're talking about.
  • Cell Phones Master
  • 3,895 Answers
It might be system updates being done in the background by your operating system.
Another possibility is video being watched online that will chew through bandwidth like the figures you mentioned.
Posted on Jun 06, 2017
  • 3 Answers
OK. I hear you. that really sucks. have you installed your phone into your PC ? if you did then you should try double checking on the files you send to your phone e.g : songs should be mp3 files. maybe that will help
Posted on May 24, 2007
my k600i doest turn on after i playaed a game.. how can i repair dis
Posted on Feb 07, 2008
  • 304 Answers
This can happens when Automatic Updates Feature is Turn On. Your antivirus definitions updations. By using peer to peer softwares like bitcomet, bittorrent, Bitlord etc., These can work in bacground and downloads the updates and softwares and shares the resources of the downloads. By these the limit can exceed.
To reduce these risk factors
Change 250 Plan to 500 limited plan or 750 Home unlimited.
If not disable the autoupdates feature.
Hope this will be usefull
Thanks & Regards.
Nanda Kishore
Posted on Mar 10, 2009
  • 71 Answers
SOURCE: laptop problem
you can try this: unplug from power, remove battery, press power button for about 30 to 60 seconds, connect back to power leave battery out, turn power back on. see if that works.
Let me ask you this, when you turn the power on: do you see or hear the hard drive spinning?
let me know if it works,
good luck
Posted on Apr 10, 2009
SOURCE: Games download
go on upload game to there and press submit then another page will come it will say somethink lyk game.jar make sure its jar file tho
Posted on May 21, 2009
Alienware 17" notebook with windows 8 shutting self down at startup
If it's 3 weeks old return it. Or you can do a System Restore/Recovery. Take a look at this forum for the Restore/Recovery Procedure:
Mar 01, 2013 | Alienware PC Systems Alienware M17X with...
First My sister inlaw has a 3/4 recirc line. used the by pass h&c under last faucet to use cold as recircu line. Note acutal 3/4recirc is in kitchen but even thou closer to water htr. it is last for...
I don't understand everything being asked, so add a comment any time.
Problem1 is excessive electric bill.
Suspect is new 120Volt Taco recirculation pump.
Look at motor nameplate for amps and watts and HP. Taco pump is usually robust 1/3 HP which is 252 watts or same as running four 60 watt light bulbs.
If pump runs 18 hours per day x 252 watts = 4536 watts or 4.5 Kilowatts per day
Buy a kill-o-watt meter that plugs into outlet, and plug Taco pump into the meter for 48 hours.
This will give you total watts used for that time period.
1000 watts = 1 kilowatt.
Electric bill is probably 12 to 20 cents per kilowatt.
So if Taco uses 4.5 kilowatts per day, that is $.54 to $.90 per day multiplied by 30 days.
So cost is $15 to $30 per month.
Problem2 is Taco runs too long.
Taco operates either by thermostat or by timer. You choose which mode by using slide switch that is usually located under the timer dial. Set switch to TIMER to use timer, and ON to use thermostat, and off to turn TACO off.
If Taco is set for thermostatic operation, the Taco might be defective. Or there could be crossover problem at single handled faucet.
Another problem could be air in the water line: install air vent.
Jul 17, 2011 | Taco 1/2" 006 BC4-TAC Circulator Pump/...
How to change the date and week?
1. Pull the crown out one click.
A. Turn dial until function hand rests on "CAL"
2. Pull dial out one more click (should be all the way out)
A. hold down button "A" (top button) until the second hand completes one counter clockwise rotation (should be pointing at current month)
B. Press "A" button a second time and the Day/Leap year hand will move.
3. At this point spin the crown either backwards or forwards and watch as the Day/Leap year hand spins clockwise or counter-clockwise. The Date will adjust per each revolution.
Hope this helps as it took me using the correct movement number on the url in the previous post (for Calibre 8700 the movement number is "E870").
Mar 22, 2010 | Citizen Eco-Drive Calibre 8700 Wrist Watch
Download speed only 107kbps on 1Mbps line
ok when they say 1 Mb= mega that is 1/8 of a MB=megabyte you are getting full use/ srry i couldn't make your connection go zingo
Mar 10, 2010 | Compaq Presario S4300CL (DK333AR #ABA) PC...
I have the same problem since 1 year. getting worse every months.
its more than likely going to be the camshaft dephaser, this is quite a costly job as it requires replacing along with the cambelt and auxillary belt, its a common fault
Aug 10, 2009 | 2004 Renault 181
Does anyone know how much energy the traulsen urs48dt should be using per day/month or year? Note that the compressors in my case have moved to the garage which I assume impacted efficiency. I love the...
Ok, next question, when he replaced the compressors, did he modify the evap sections with TX Valves and remove the cap tubes? Per Traulsen specs, all remote units are factory set with TX valves while local units are equipped with cap tubes. If this modification was not done, it may be your cause of excessive electical consumption. Then again, re-reading your recent post, the compressors were changed to 3/4 hp? From Traulsen specs your unit came with a 1/6 fridge compressor and a 1/3 freezer compressor, is that correct? Electrical consumption on these are URS48DT 11.2 Amps 1/6 HP & 1/3 HP (1288 watts) at full load, while a 3/4 compressor is 14.9 amps 3/4 HP (1713.5 Watts) at full load X2 = 3527 Watts, or about 3 times original. I may be off target, but from what I can assume, I am beginning to think your compressors are over sized, drastrically and that the evap units may not have been modified to TX Valve. Let me know if this helps or if there is any additional information you can provide. Current compressor model numbers, previous compressor model numbers, complete unit model/serial number would all be a help in determining your exact specifications.
Jun 23, 2009 | Traulsen Commercial 2 Door Cooler /...
VAIO VGNTZ150N Laptop battery runs down when not in use
If the laptop is gone into a suspended mode it is still powered on but sleeping. This will continue to use power and will power down the battery over time.
You could enable hibernation which saves the current state of your pc so that when you activate it again it restores to your previous state of work. This will use close to no battery power to perform.
Apr 24, 2008 | Computers & Internet
Tv shutting off
How many times per second does the POWER led blink? (dont worry about the OPC).
1x per second (constant, steady blink) = bad inverter/lamps
2x per second = bad power supply
3x per second = bad main board
You can buy the parts online and fix if yourself!!
Dec 02, 2007 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
