There was a power cut last night and now I cannot get the washing machine to switch on .............. NO LIGHTs when dial is turned??? My question is this related or is this a seperate problem.
  • KEN LaPOINT
    KEN LaPOINT May 11, 2010
    Have you tried pressing and holding the start button if so equipped?
Let's start with the basics....first have you checked the breaker for the outlet the machine is plugged in to? If not start there...if so we had a similar problem where I unplugged the machine for about an hour, then plugged it back in and it was fine. Third thing to check and this is more for top loaders along the bottom of the front of the machine there is sometimes a reset switch if one exists on your machine push it in...Good Luck.
Posted on Jun 18, 2009
Help my washing. Machine lights up but it's dimmed light not as bright as normal will not start
Could be a bad circuit breaker or outlet. You need to check the outlet with a voltmeter. If it is ok then i would think the washing machine internal power supply is going out.
Jul 06, 2016 | Washing Machines
Ariston Washer not running Programme
It sounds as if the brushes in the motor have worn,when the motor stops it wont go through the program,try turning the ddial around to spin to check the motor
Mar 07, 2014 | Washing Machines
LG WD-1265TP washing machine household electricity cut out switches off the power
I think that either:
A: you have too many things running on that circuit (space heater perhaps?) or...
B: your washing machine needs a repair.
Best of luck
Dec 18, 2011 | Indesit Washing Machines
Washing machine wont stop it has been going from last night
turn off at wall and unplug .after a few minute's plug back in and try and reset machine by putting dial on one of the dots switch on the red light should flash 3 times and switch off .I this works try and put machine on again a spin only will do if the same problem returns you probable need a new pc board . cost about £55to 90pounds before fitting .
Feb 11, 2010 | Indesit W 123 Front Load Washer
Washing machine suddenly stopped working only 17 months old
unplug from the wall about 1min then plug back in this will reboot the cpu on the machine
Aug 23, 2009 | GE WPXH214A Front Load Washer
Samsung washing machine F1245 control panel stuck??
I have Samsung/korea-SW905Washer.When power is switched on the Fault-'1E' appears. what could be the reason.( narrate list of control component failure).
Bought in the year 1996 at India ( voltas mega washer top loading-7.5kg) and working till last month.
after few wash cycles the machine stopped at aforesaid indication and it is not functioning due to above fault indication'1E'
provide me remedial measures or electronic control board circuit.
May 29, 2009 | Samsung WE356A5W Washer/Dryer Laundry...
Power switch will not turn on machine.
There is a power switch at the right rear of the machine. Is this on?
Jul 09, 2008 | Solis Palazzo Espresso Machine
Washing machine problem
I would also think it is a lid switch although this sounds like a pump is freezing up the works, can you hear a hum when you pull out the dial? If you can I would pop the access panel on the back and pull the dial out watching the motor to see if it pulls to one side.
FYi pic below
Jun 23, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Power cuts when 'on' switch is released!
Easy, remove the top the switch unclips and slides out from the front panel, you cannot sucesfully repair these switches so a replacement should be obtained
Dec 31, 2007 | Neff W4380X1 Front Load Washer
AEG L1250 Washing Machine
possible interlock, the switch that stops it from working when the door / lid is open start here
Oct 01, 2007 | AEG LW1250 Front Load Washer
Washing Machines Logo
57 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
