Question about Craftsman 22" Gas Hedge Trimmer
The blade stopped moving
I took off the plate that covers the revolving cam. I cleaned the cam and regreased it. Then I noticed that the end of the blade assembly that has the hole which fits over the cam was bent at about a 45 degree ange from the edge of the hole to the end of the assembly. Is it supposed to have this bend or was it damaged somehow and caused the blades to stop scissoring? If so, can I just hammer it back flat again
efs_perpends
  • 1996 Answers
SOURCE: Table Saw Blade Won't Cut Straight
Inside the saw, on the end of the trunnion is a stop that is adjustable to zero the saw in to exactly 90 degrees. Either there is sawdust or something accumulated there or it needs to be adjusted. You say you cleaned it out, So you'll need to unplug it an have a look up in there. See how there's a geared piece of steel that moves when you crank the saw over to 45 degrees. Usually there's a bolt or stud with a locking nut on it, either on the trunnion itself or the lower surface of the table top. You need to break the nut loose and screw the bolt in or out to adjust, then crank the saw over to hit it, check for square with a known square, crank it all the way out of the way and readjust, etc. Until you get it right. Make sure to tighten that lock nut when you're done.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread. If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
Posted on Apr 02, 2009
  • 10865 Answers
SOURCE: I bought a Sears edger #536 796526. It dies on me.
Hi Tom. You are not doing anything wrong. That being said, your edger has a slightly gummed up carbeurator. I would go to an auto parts store and get a can of a product called seafoam. this is a gasoline additive. Add one ounce per gallon of gas and use this as the fuel for your edger. You will solve your problem in just a few minutes after using this product, I believe. Give it a try and let me know.
Posted on Jun 13, 2009
GM Elec
  • 1000 Answers
SOURCE: mower stopped moving
If this is a manual transmission, check the drive belt from the engine back to the transmission. With the clutch pedal up (engaged) there should be no slack in the belt.
If it is a hydrostatic drive, check the drive belt and make sure it is tight. Check the transmission fluid level and make sure it is full. Refer to your owners manual as it will describe the fluid check proceedure.
Good luck, let me know.
Regards,
Posted on Jul 14, 2009
  • 32 Answers
SOURCE: How do I get my mower deck set properly? Any tricks?
check your front tire air pressures
Posted on Jul 26, 2009
mickey813
  • 472 Answers
SOURCE: I have the DYT 4000 model. My tractor will start
SOUNDS LIKE YOU HAVE ONE OF YOUR OTHER SWICHES ARE BAD LIKE THE SEAT
Posted on Sep 30, 2009
Why does my kubota lawn mower die when i mow in reverse even when i push the button?
Check the blade housing and any build up of waste which can cause too much tension on the blades when they are operating as the unit moves in reverse. The rotor head could could be jamming. With the unit turned OFF try to move the blades clockwise and counter clockwise. There should be equal force required to move the blades in either direction. If not then clear and clean all the area and especially where the spindle comes through the body from the engine. Oil and regrease all required points.
Jul 22, 2014 | Kubota Garden
I have a Bernina 135S and I managed to get a pin caught in between the plate and the feed dogs. I removed the plate, took out the pin and put it back together although now my feed dogs only move up and...
Check whether the feed dogs are coming above the stitch-plate at their maximum height. They should be about 1mm above the stitch plate when driving the material under the foot. I assume, by the way, that you haven't got the feed-dog drop button pushed-in at the handwheel end !!! If the feed-dogs are lower than 1mm, or not above the stitch-plate, the dog cam cam-foller will need adjustment. You have to remove the front cover to get at this and it should be done with a special gauge, so really its a service agent job, however, for what its worth;
With the front cover removed to gain access to the free-arm mechanism, look to the right of the hook race and on the end of the bottom drive shaft there are two black plastic cams . The right-hand one regulates the movement of the dogs front-to-back in association with the stitch-length stepper-motor, which drives the upper shaft in the free-arm. The left-hand cam regulates the up-down movement of the dogs and the cam follower (a piece of right-angled plated metal) has to be adjusted to determine the maximum height of the dogs aboe the stitch plate. The cam follower rubs against the top edge of the dog cam. There should be a small spring that pulls the cam follower down onto the cam at the front - if that's missing, the feed-dogs probably wont move quite correctly. To adjust the dog height, turn the hand-wheel until the feed-dogs are at their maximum height, unscrew the small screw in the left-hand side of the cam follower a couple of turns (dont, for goodness-sake, take it out !) - the feed-dogs should then pop-up above the stitch-plate. You now have a problem without the proper gauge ! You need to gently push the dogs back down against spring pressure until they are the correct height above the stitch-plate and tighten the screw on the cam follower. This should, at least, get over the problem - it wont be exactly right without the gauge and there is another adjustment that should be done to ensure the front and back of the dogs are at slightly different heights, but it should be good enough without this.
Good Luck !!!
Sep 01, 2011 | Bernina Activa 130
HAVE TO TAKE THE BLADE OFF. took bolts off and that is all cant move th plate off.
the plate can stick tightly sometimes...take the end of the bar and gentelt move to the side to pop the plate out and off...
heatman101
Aug 29, 2010 | Husqvarna Chain Saw 20" Bar
My 2012NB has served me well for about 10 years, but lately lumber does not feed through smoothly and the result is a "ribbed cut" - there are gouges running across the board at about 2 inch intervals. My...
I just read the owners manual online at Makitausa.com and I don't see the reference to the feed rollers and pressure.. I would look at the condition of the planer blades to ensure they are sharp and not pitted. Then I would look at the feed rollers for being out of round. Let me know, it has been a couple years since I worked on one of them.
Jun 30, 2010 | Makita 2012NB Electric Planers
No power on electric durabuilt 1400 pressure washer
sounds like a pressure switch is sticking. usually causes this problem especially after being stood for a while not used.
have to remove cover to get to pressure switch, remove pressure switch piston clean regrease with silicon grease refit it m and all should be good.
Aug 01, 2009 | Coleman Powermate DuraBuilt 1400 PSI...
There is a continuing blinking noise after the blinker turns off
The fix for this is easy and free. The problem is caused by contaminated grease which has bridged contacts of the multifunction switch. This cause a short circuit which cause the hazard flasher to cycle. You need a #25 torx and a # 10 torx. Remove the 3 #25 torx screws which hold plastic surrounding the steering column. Remove the plastic. Remove the 25 torx screw on the top of the multi function switch. Detatch the wiring connectors. Remove the multifunction switch. Use the #10 torx to remove all the #10 torx screws. Remove the cover and clean the grease off the contacts and copper switch plate.You will notice grease has bridged the some of the slots in switch plate. Clean it up and regrease. reverse steps to reinstall. Notice the metal peice protruding from the multi function as it facing you. This is the turn signal reset switch. When you turn this is what resets the turn signal when the wheels straighten. This needs to be pushed in so no more than 1/8 " is protruding. If you dont do this before reinstalling your horn may go off when ever you move the steering wheel after reinstallation. This whole job should take 20- 45 minutes based on your mechanical apptitude.
Jul 18, 2009 | 2004 Pontiac Grand Am
Replacing timing gear on 300 6 cylinder and noticed that the camshaft moves in and out about a quarter inch.
End play is pretty much normal on most cams. If yours has a thrust plate holding it into the block, check it for wear (though it won't account for 1/4") On racemobiles & some GM engines a thrust button is used on the end which rides against timing cover to lessen movement. BUT, I would not worry about it! More important is that you index the gears properly. TIP: oil the chain before closing it up... it helps to avoid dry start up wear. The cam gears/chain see the oil last out of everything in the engine.
Dec 30, 2008 | 1993 Ford Ranger SuperCab
Print smears
Hi Allan:
Sounds like you need to replace the drum pivot plate assembly. This assembly is what cleans the drum assembly prior to putting the image on the drum. The pivot plate assembly has a rubber drum cleaning blade on it and when the printer begins to print a page it cleans the drum first. If the cleaning blade or the pivot plate are deffective then the drum will not be cleaned properly leaving smudgy areas on the drum.
Aug 13, 2008 | Xerox Phaser 8560DN Laser Printer
Craftsman 22" Gas Hedge Trimmer Logo
60 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
