Question about Phase Linear UDV9010 Car DVD Player
I have the phase linear UV7i I was trying to put in the overide
Code to bypass the Ebrake sequence, Now my remote wont work, and I Still cannot view my screen! I have a toggle switch connected, but it came loose, and wont work, and now i have screwed up my remote, (code wise) somebody help me!!!!!!
Reset it,try with out the remote and change the remote battery,put in dvd wait for the blue screen,then press stop 2x then enter 1264 then,if you have a up,down,l/r control on the deck press down 1x then press play,you dont even have to use the ground wire then go to the rest, when you can see the menu,i dont know if it will work but u can give it a try
Posted on Jun 18, 2009
E brake bypass think this will work?
Go on amazon.con type in micro bypass and buy the 3 wire relay about $10-12 and fallow directions included
Alpine screens may require a different bypass also found on Amazon
Mar 18, 2017 | Clarion VRX785BT Car DVD Player
My remote wont work on my jensen uv10 and i want to bypass the parking brake. Can you tell my how to do it without remote. Thanks
You don't need the remote to bypass the ebrake withe remote use a tago switch to bypass the ebrake hook it up to the pink wire on back of the deck.
May 04, 2011 | Car Audio & Video
How to install a bypass ebrake switch for a dual xdvd 8183 car video player
use a toggle switch.connect the brake wire from your radio to one side of the toggle swith and the other side of the toggle switch will be connected to ground.then when your dvd comes on flix the switch for a few seconds and switch it back.your dvd will come on seconds later
Jun 28, 2010 | Dual XDVD8181 Car Video Player
How to by pass the e brake wire
at this time there isn't a code bypass for this model. the easiest thing to do so that you can play video while in motion. is to put a toggle switch on the parking brake wire of the dual screen. then do the ebrake pattern on the switch instead of the ebrake in the car
1. disconnect the parking brake wire of the dual from ur ebrake wire in your car.
2. take your 2 wire toggle switch and connect one wire to Ground(metal)
3. take the other wire and connect it to the parking brake wire of the dual screen.
if i remember correctly, the pattern for the dual screens is.
1. starting in the off position.
2. on for 2 secs
3. off for 2 secs.
4. then on .. the the video will show.
hope this helps
Oct 04, 2009 | Dual XDVD8181 Car Video Player
E-Brake Problem
you have connected it correctly, that is just how those units work. there is a pattern to the ebrake for it to view video.
1. start with the ebrake off and follow this pattern.
2. on for 2 secs, off for 2 secs, then back on
or you can just put a toggle switch instead of connecting it to the cars ebrake wire. wire as follows
1. use a 2 wire switch.
2. connect one wire of the switch to ground
3. connect the other one to the ebrake wire of your dual unit.
4. then you would do the same pattern with the switch as you would have with your ebrake. this will allow you to view while in motion without your ebrake engage
hope this helps
Aug 26, 2009 | Dual XDVD8181 Car Video Player
I have a alpine cva1003 and cant get the screen off safety mode to play the dvd's. I have the parking break wire from the radio, which is yellow and white connected to the single parking break wire. is...
In order for the video to work you need to hook up both the parking and the foot brake leads so you would have to press in the foot brake pull the ebrake let up on the foot brake then the video should come up but if u want to watch videos all the time moving or stopped youll need to do some custom work so:
Short of making a microprocessor to do the sequence the easiest way is the two switch method. just mount two switches together and do the sequence.
Although the idea of only one switch and the foot brake hooked up correctly might work too.
The best way to go about it is to hook up the system as is should be and use a voltmeter to see what voltage changes are on the lines. Then hook up the switches accordingly.
hope that helps!!
Jul 16, 2009 | Alpine CVA-1003 Car Video Player
Parking brake bypass code on a Dual XDVD9101 head unit
there should be a wire that connects to your e-brake swith, located near the e-brake all you have to do is connect this wire straight to earth and you should be able watch movies all the time,
hope this helps you
Mar 13, 2009 | Car Audio & Video
Jensens UV9 By pass the brake
hook up the ground with the pink and when you are in am/fm mode hit the dvd set up button on the remote, input the no. 5, 4, 3, 2, 1, and 0 make sure it beeps after every no. has been pressed. then it should bring up the hidden menu select the hammer option and turn on the brake bypass option. your done.
i took this from the uv8 brake bypass. it works on the uv9.
Nov 12, 2008 | Car Audio & Video
CAN U HELP ME?
1) Insert the DVD and you'll get the blue screen.
(If you have more than one tv, the unit itself will have the blue screen but the additional tv's you have plugged in will NOT, they will show the dvd menu. Thus you will be able to see the hidden menu on the additional screens after inputting the code, but not on the main unit because of its blue screen.)
2) On the main remote, push stop twice and then 1, 2, 6, 4
3) Push the joystick on the unit SOUTH twice and then click it once.
4) Press SYS SETUP on the main remote twice to save your settings.
It may take a few tries but you'll get it. This method can be done if you don't want to bother temporarily activating the brake sequence, but if you only have the unit and no additional tv's, its #$%^&* damn hardbecause you can't see the settings your changing.
Dec 27, 2007 | Audiovox VM9311TS
How do i bypass the emergency brake wire on a dual xdvd700
Just ground out the Ebrake wire... it will work fine then. Even if you just link the ground and ebrake wire together and ground them together it works!
Dec 01, 2007 | JVC KD-AVX33 Car Video Player
Phase Linear UDV9010 Car DVD Player Logo
673 people viewed this question
Top Phase Linear Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Phase Linear Car Audio and Video Expert? Answer questions, earn points and help others
