Question about Casio EXILIM Card EX-S770 Digital Camera
Grey line on certain pictures after I have uploaded them
The pictures look fine on the camera but then when I upload or view them on the computer, certain pictures have a thick grey line on the side. I dont know why it does this, Its a brand new camera and memory card. What do you think is wrong? Is there anything I can do to make up ruined pictures not have a grey line on them?
5 Suggested Answers
SOURCE:
  • 374 Answers
SOURCE: Can't Upload Pictures
What kind of system are u using? Mac or PC? What version of windows? If you are using their photoloader software please check the following: In picture taking mode press menu Go to setup tab Go up to USB press right arrow and highlight mass storage. press set. try that. If that doesn't work then try this: In picture taking mode press menu Go to setup tab Go to USB press right arrow highlight PTP press set. This will allow you to chose which program to open with. Chose the Microsoft scanner/camera wizard and then just follow prompts.
Posted on Jul 08, 2007
SOURCE: Casio Exilim Z-9: Upload pictures from internal memory?
Don't think you really need to use the software do you? I think you can simply plug in the usb port and browse to "my computer", it should show up as a "removable device" in the dialog window, or may call it "Casio" or similar. Open it and browse to the pictures folder, and "copy, "paste" to your hard drive, but I'm only guessing...hope it helps :)
Posted on Feb 16, 2009
  • 11967 Answers
SOURCE: I can't upload my pictures from my EX-Z29 camera onto my Mac.
Easiest way...buy an inexpensive card reader that fits your card and is Mac compatable. Create a folder on your desktop and name it. Plug your card into the reader and the other end into a USB port and an icon will appear on your desktop as "no name". Double-click it and your picture files will appear. Click " command a " to select them. Then press alt/option and click and drag them to the folder you named. Now, right-click the no name icon and choose eject to safely remove it.
Posted on Jan 01, 2010
SOURCE: CASIO camera says screen card is locked, mem. card is on unlock..
thank you very much, it was the card when i removed the card it worked. again thank you
Posted on Feb 17, 2010
Uploading photos "camera Error"
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
May 26, 2010 | Kodak EasyShare LS755 Digital Camera
Downloading pictures that are sideways...
All you need is some editing software, click here. If this problem is occuring after uploading to a website, try rotating the picture before uploading so the "problem" will actually correct the picture.
Jun 23, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
LCD is blank (grey) but camera is still functioning.
call Kodak it is a known problem they will do it FREE just call them dont worry if ur model is not there just call and ask them about BAD CCD
Kindly rate me WELL !
May 31, 2009 | Kodak EasyShare M1033 Digital Camera
UPLOADING PICTURES
use the usb charger and connect it to your computer, turn on your camera and choose connect to computer then click ok/menu,
on your computer click on my computer and double click on the drive that says removable disk (F:), then it will upload all the pictures to your computer you can only view and delete, but if you want to save it to y our computer you have to select all the pictures right click on the mouse and choose copy and save it to your computer or make a new folder on the deskstop.
other way:
if your computer has a memory card slot reader, then take out your memory card from your camera and place it to the computer and again go to your my computer and double click on the removable disk (F:) drive.
hope this will helps.
Mar 31, 2009 | Samsung Digimax L730 Digital Camera
My finepix camera will not upload pictures
Mine doesnt have this problem - sorry it sounds like it is a malfunction.
If u dont wanna lose ur pics u can use ur cardreader, if you have one. But get the camera replaced.
sorry
Dec 11, 2008 | Fuji Finepix Z20fd Digital Camera
Improper upload of pictures to computer from camera Canon EOS 40D
Try getting a card reader, they are cheap. It sounds like the software is having a problem communicating.
Oct 16, 2008 | Canon EOS 40D Digital Camera
Uploading pictures form canon powershot sd500
first thing, you have to have the camera in playback (The way to view images on the camera) ((If the lens goes out you have i wrong))
If you have XP / Vista it will come up in my computer and you can copy and past images / videos from it that way. Else Scanner n camera wizzard in XP will pull images off
May 06, 2008 | Canon PowerShot SD600 Digital Camera
if you are using a cpmputer that has photo imaging software installed then you should be getting a prompt to choose what software you need to view photos with, or you should have received a cd rom from the manfacture to upload them to your computer afterwards you can use picassa from google to set them in photos ablums ect good luck
Jan 03, 2008 | Canon PowerShot SD500 / IXUS 700 Digital...
Cannot upload pictures on my laptop or open library~~~help me...:-(
Make sure you have completely uninstalled AOL, as this can still cause certain problems. When you connect your cam you should be able to view pics within Windows my pictues and should ask to import files. It should also show up in my computer as a drive if it's recognised by windows, if so you can explore it and open the folder with pics in
Mar 07, 2007 | Casio EXILIM ZOOM EX-Z600 Digital Camera
Sony Cam CCD-TRV37 side view error
my guess ...it fell... sorry! the lines r there to stay unless u'll replace it with new 1
Sep 14, 2005 | Sony Handycam CCD-TRV37 Camcorder
Casio EXILIM  Card EX-S770 Digital Camera Logo
70 people viewed this question
Top Casio Cameras Experts
atollminsk
Level 1 Expert
Parshiv Luthra
Steven Wander
Steven Wander
Are you a Casio Camera Expert? Answer questions, earn points and help others
