Question about GE A1255 Digital Camera
What is the install software camera so I can upload pictures on my computer
When I plug the camera into the computer it will not acknowledge it...I don't know what the problem is
Panasonic DMC-155 camera no longer uploads photos to PC
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa ( http://picasa.google.com ).
Jun 02, 2013 | Panasonic Lumix DMC-FS5 Digital Camera
HOW CAN I UPLOAD PICTURES FROM MY DIGITAL CAMARA WITHOUT A SOFTWARE DISC?
Hi Amimbue 1985,there are a few ways to upload pictures without using a software disc.
Option1 :
Transfer your photos to your computer with a use of a USB cable provided with your camera.
Connect the USB cable to your camera and computer. Your PC will recognize it as an external storage and you can copy your pictures from it.
How to copy pictures:
1. Go to my computer
2.Select the drive for your camera and go to the folder where all your pictures are
3.Ctrl + A (to select all pictures)
4.Create a folder for your pictures on your local drive (or you may also paste it on any existing folder)
5.Ctrl + V to paste pictures on folders
Once you have a local copy on your computer you may then upload on any web applications that you wish, such as facebook or flicker etc.
Option 2:
You may also use Google's software called Picasa, it's free for downloading.
Please visit this link for the application:
http://www.google.com/picasa/
How to download Picasa
1. Download Picasa by visiting:
2. Click " download Picasa "
3. Click save file once prompted and save it on your desktop for easy viewing.
(if you are using firefox, wait for it to download and just double click on it to run the application once done)
4.Run the picasa application on your desktop to install the software.
5. It is recommended to restart your computer after installation.
6.Plug the USB cable from your camera and computer and picasa will automatically get your pictures from your camera.
(you may now have the option to upload your pictures )
I hope this helps.
Once you have download and installed the application, it will automatically get the pictures on your camera once plugged in. You may upload it directly to picasa or any web application of your choice.
Jan 02, 2011 | Cameras
Uploading photos without software being installed ?
Yes. The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive.
May 24, 2010 | Kodak Easyshare C813 Digital Camera
I have recently installed the solution disk after realizing that the computer would bot be able to upload images from the camera to the computer because of a missing PTPUSB.DLL File. The installation of...
Do you really need the software?
The best way to upload pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
There are also plenty of photo catalog software packages out there, some free, some not, that can transfer and catalog your pictures so you can quickly find pictures from Susie's birthday party, for example. Just do a google search for "photo catalog software".
Mar 02, 2010 | Canon PowerShot SD1200 IS / Digital IXUS...
My pictures won't upload
You need to install the software for your camera and allow it to start when windows starts. That way, your pictures from your camera will be uploaded as soon as you connect it to your computer. Or try also to start the camera software and plug the camera to automatically upload images. To automate it, you need the software to run when windows starts. Simply add the software at system startup.
Dec 28, 2009 | Canon EOS Digital Rebel XS / 1000D IS...
Where do i get the software online to get my pictures uploaded
Get your pictures off your camera to a website, or your hard drive?
I will assume your hard drive, so first make sure you install your camera drivers so computer recognizes your camera when you plug it in.
Download picasa software from google, It is free, and that will import your pictures from your camera to your hard drive, and also let you upload your pictures to the web right from within picasa program.
http://picasa.google.com/
Happy transfers
Mar 03, 2009 | Cameras
Laptop doesn't acknowledge canon a460 camera when connected
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Aug 05, 2008 | Canon PowerShot A460 Digital Camera
Sony Cybershot P93A - Uploading Pictures Question
Many still image digital cameras available are Plug-n-Play type and Windows XP detects them easily to transfer pictures/ data.
Jun 25, 2008 | Sony Cyber-shot DSC-W35 Digital Camera
Canon powershot sd600
I am having the similar problem with my cannon sd600 camera. I have the pictures in my card but not able to upload to the computer. I used the memory card reader to upload the pictures and when I plug that to the computer the camera will be shutting down the power and system not able to see the pictures to upload. Please some one help me. thanks!
Apr 20, 2008 | Canon PowerShot SD600 Digital Camera
Computer does not recognise camera to upload photos.
Download the drivers specific to your operating system from
http://h10025.www1.hp.com/ewfrf/wc/product?product=213533&lc=en
&cc=us&dlc=en&lang=en&cc=us
(no space after en and &cc in the url)
Hint: Look under " software and drivers"
Troubleshooting, software & driver installation help is given under "setup & Install" in the same above link.
Hope this would solve your problem.
Jan 24, 2008 | HP Photosmart 435 Digital Camera
GE A1255 Digital Camera Logo
18 people viewed this question
Top GE Cameras Experts
Steven Wander
Steven Wander
jjanesic
jjanesic
Level 1 Expert
Are you a GE Camera Expert? Answer questions, earn points and help others
